Old 03-03-2023, 07:42 AM   #1
pym19109
WRBLUE BRZ
pym19109's Avatar
Drives: 2016 Subaru BRZ
Unhappy !!NEED HELP!! Over tighted pedal nut
Hi guys,
I just removed my pedal to install Cusco gas pedal. While I'm putting everything back, It's quite small space for turn the wrench so I keep turn it because I can't feel the tight and accidentally I over tighted the upper bolt. It's broke into piece like the pictures below.
Any suggestion to fix it?
pym19109 is offline   Reply With Quote
Old 03-03-2023, 10:42 AM   #2
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Oof that’s a tricky one.
You could try and knock what’s left of the stud out and then see if you can bond a new one in there?
You could also drill it out and slide a nut in from the backside, then thread a piece of threaded rod into the nut.
You could also drill it out, install a rivnut, and then use a bolt or threaded rod in the rivnut.
The Following 2 Users Say Thank You to Yoshoobaroo For This Useful Post:
pym19109 (03-03-2023), Ultramaroon (03-04-2023)
Old 03-03-2023, 12:02 PM   #3
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Hard to tell from the pictures, but you may be able to get a rivnut in there that will work.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
pym19109 (03-03-2023), soundman98 (03-03-2023)
Old 03-03-2023, 01:08 PM   #4
Yoshoobaroo
TRACKBREAD
It's amazing how applicable your signature is to this thread.
The Following 3 Users Say Thank You to Yoshoobaroo For This Useful Post:
NoHaveMSG (03-03-2023), soundman98 (03-03-2023), Ultramaroon (03-04-2023)
Old 03-03-2023, 01:17 PM   #5
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
lol it's there for me as much as anyone. I have broken so much stuff in my time "learning."
The Following 4 Users Say Thank You to NoHaveMSG For This Useful Post:
RT-BRZ (12-20-2024), soundman98 (03-03-2023), Ultramaroon (03-04-2023), Yoshoobaroo (03-03-2023)
Old 03-03-2023, 02:28 PM   #6
pym19109
WRBLUE BRZ
pym19109's Avatar
Thanks for the suggestions.
Will rivnut fits in side tiny space in the back of bracket?
or just weld a stud in will it work?
Old 03-03-2023, 02:52 PM   #7
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Rivnuts are installed from the front side with a special tool, or using a bolt and nut. The hole that you have may be too big though for one so you will have to check/measure.
Old 03-03-2023, 07:01 PM   #8
norcalpb
norcalpb's Avatar
I don’t have a solution, but for small things like this I like to take an extension and the 10mm socket to use as a compact screw driver.
The Following 2 Users Say Thank You to norcalpb For This Useful Post:
NoHaveMSG (03-03-2023), Ultramaroon (03-04-2023)
Old 03-03-2023, 09:31 PM   #9
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I do that all the time even though I have a set of nut drivers
norcalpb (03-03-2023), Ultramaroon (03-04-2023)
Old 03-04-2023, 12:32 AM   #10
All day long. Less tools to switch out. Better balance between grip and ability to spin on or off.
Nut drivers have their place but socket+extension is way more versatile. Some extensions are knurled for just that reason.
NoHaveMSG (03-04-2023), soundman98 (03-05-2023)
Old 03-04-2023, 08:29 AM   #11
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Hi guys,
not really helping at all but just for future reference most stuff "IN" the car are usually only around 20-25 n/m so pretty much a light hand tight. except stuff that's bolted to the frame of the car like seatbelt or seats...
The Following User Says Thank You to chaoskaze For This Useful Post:
pym19109 (03-04-2023)
Old 03-04-2023, 03:01 PM   #12
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
20-25nm is boarder line too tight for those. 6mm mid grade fastener should only be like 8ftlb which is like 10-11nm.
bcj (03-04-2023), chaoskaze (03-07-2023), soundman98 (03-05-2023), Ultramaroon (03-04-2023)
Old 03-04-2023, 03:50 PM   #13
pym19109
WRBLUE BRZ
pym19109's Avatar
After I did a search for similar problems, there is not much information for me. I will try to hammer the stamped stud out first (maybe with a extractor also) and wish the god of subie is kind to me XD. if not, cutting the leftover piece and drill will be my only option but this will be a difficult job for sure with a little room there and yes like many of you said "ONLY HAND TIGHT ANYTHING INSIDE THE CAR"
Old 03-04-2023, 04:36 PM   #14
It's not so much inside-versus-outside. Everyone has over-torqued fasteners. Everyone has cross-threaded fasteners. The lesson here is to understand that it's natural to want to get in there an really cinch it down tightly so it doesn't come loose. We must learn to fight that urge.
For newb friends I've had under my wing, I put old screws in the vise and had them turn nuts slowly until they strip. Materials vary. Aluminum is super tricky because the threads yield - begin to strip - more gradually than steel.
Use a torque wrench.
That one will be a bitch. Cut the weld stud down flat. Drill & tap to 6x1.0 mm thread. You might need a bottom tap to finish the job but it's doable. Cut a hex head cap screw to the correct length and clean the threads until it starts nicely.
pym19109 (03-04-2023), soundman98 (03-05-2023)
Cusco Pedal Install & Pedal Lateral Stiffening (Sideways Loose Pedal) BOND007_LTK DIY (Do-It-Yourself) Guides 5 05-20-2022 05:12 PM
Beastronix pedal box, Nardi Gara Sport 350mm, Velox and Cusco pedal brackets etc. captain awesome Interior Parts (Incl. Lighting) 2 04-21-2021 11:56 AM
FS: OEM Pedal Box MicheleAbbate Interior Parts (Incl. Lighting) 14 02-26-2020 03:02 PM
Painting pedal covers + dead pedal iconic DIY (Do-It-Yourself) Guides 4 12-22-2019 01:39 AM
Gas pedal tintumz22 Scion FR-S / Toyota 86 GT86 General Forum 12 08-22-2012 10:42 AM
