Old 02-23-2023, 12:44 AM   #1
chiefshayan
chiefshayan's Avatar
Drives: 2013 AT Firestorm FRS
Electric Power Steering Gone
Hey all! I have a '13 with around 75k miles that's never been in an accident. A few days ago, the steering became very light and almost felt as if the steering input had a deadzone. Checked the tire pressure and everything is OK. This happened in the middle of a nice drive.
I'm thinking my electric power steering EPS has overheated and may have failed. I've found some older threads on this, but just wondering if anyone has dealt with this issue. I spoke with someone at my local Toyota dealership because this EPS failure was part of a Toyota Australia recall and covered, but is not a recognized recall in the United States. Dealership basically said not our issue. Has anyone had any experience with this? I'm looking at a ~$1,000 in parts alone if the work is done by myself and a buddy. Would rather put that to a few track days coming up
I always thought if the electric steering motor went, the steering would become very stiff, as if the ignition wasn't on. But the steering almost feels as if the wheels aren't on the road. Lost complete feel of the road, so it may have overheated and became faulty.
chiefshayan is offline   Reply With Quote
Old 02-23-2023, 01:41 AM   #2
pope
has a funny hat
Drives: 2014 BRZ Limited
Any codes?
I would also expect it to fail heavy if it completely failed, but if the control circuit is having issues or there’s a bad sensor it could be in fail safe mode which sets the assist level equal to the assist at something around 45mph.
I picked up a couple EPS units and columns (for other projects) from a salvage yard for under $100ea. Might be a little more costly in your region, but you should be able to get a better parts price than $1000 if you need.
pope is offline   Reply With Quote
The Following 3 Users Say Thank You to pope For This Useful Post:
chiefshayan (02-26-2023), humfrz (02-25-2023), NoHaveMSG (02-24-2023)
Old 02-23-2023, 05:22 PM   #3
chiefshayan
Originally Posted by pope View Post
Any codes?
Really appreciate the response. I think you're spot on - there is definitely some assisted steering still active and it does feel like a safe mode setting to protect from further damage.
No lights on dash but will plug the car in this weekend. Was thinking of picking a used unit for under $200 in my area, worst case scenario I can just return it if the part is faulty.
Old 02-24-2023, 11:50 AM   #4
jeffchap
jeffchap's Avatar
Drives: 2013 Scion FR-S Raven 6MT
The steering assist went out on my '13 a couple of weeks ago. It was intermittent, usually working while after start and then quitting after a few miles.
Took it in for repair, expecting at least a $500 repair. It turned out to be a corroded connection which they cleaned and reconnected for less than $100. The tech said this is a very common problem in these cars. Hopefully this is your problem too.
Sent from my motorola one 5G ace using Tapatalk
Stay squatchy, my friends
jeffchap is offline   Reply With Quote
The Following 4 Users Say Thank You to jeffchap For This Useful Post:
chiefshayan (02-26-2023), humfrz (02-25-2023), soundman98 (02-25-2023), Ultramaroon (02-25-2023)
Old 02-25-2023, 10:48 AM   #5
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Any chance you could you elaborate on exactly what connections were corroded?
The Following 3 Users Say Thank You to blsfrs For This Useful Post:
norcalpb (02-26-2023), soundman98 (02-25-2023), Ultramaroon (02-25-2023)
Old 03-06-2023, 03:08 PM   #6
chiefshayan
Update: I purchased a replacement EPS column unit for 100 bucks used off eBay. I'm also going to replace the Damper Electric Power Steering Motor Shaft (cog) which is a $15 part.
I'm opting to leave the EPS computer module as is for now.
Will report back if this fixes my issues
Old 03-15-2023, 09:14 AM   #7
Clem
Drives: Gt86
Good morning ,
here I come to you because I have a problem with my direction of gt86 2012.
1 year ago I bought a hub with a tuliper steering wheel, but unfortunately I did not fit the steering wheel properly.
following this I have the abs and esp warning lights which came on after a few kilometers and went out after stopping the engine.
I changed my sensor in the bracing but not the airbag sipriale. but I always have a problem with the car when I drive fast I have the impression that the car deports from left to right.
Clem is offline   Reply With Quote
Old 03-15-2023, 09:17 AM   #8
Clem
Drives: Gt86
the lights are no longer on but I still have a weird behavior.
as if the direction had a game or that it does not harden.
these asser disturbing .
I made a gear adjustment (geometry + parallelism)
Old 03-15-2023, 02:40 PM   #9
JD001
JD001's Avatar
Drives: Subaru BRZ
Steered the thread well and truly off the track..
Old 04-04-2023, 03:10 AM   #10
Nmstec
Drives: Frankenstein of parts
It went to limp mode. It lost can communication with ABS most likely.
Nmstec is offline   Reply With Quote
The Following User Says Thank You to Nmstec For This Useful Post:
blsfrs (08-16-2023)
Old 08-15-2023, 03:43 PM   #11
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
BUMP for updates on this.
Originally Posted by humfrz
I'm old and lazy
blsfrs (08-16-2023)
Old 08-16-2023, 01:45 PM   #12
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
Originally Posted by Clem View Post
Good morning ,
Your steering angle sensor needs to be recalibrated....
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
Old 04-18-2024, 03:24 AM   #13
WhiteRose
Drives: 2013 Genesis Sedan
Any updates on the fix? My Steering wheel light just came on and my Power steering is gone. If there was a fix I would appreciate the update!
WhiteRose is offline   Reply With Quote
Old 04-21-2024, 09:54 AM   #14
Opie
Opie's Avatar
What codes are present?
eps, steering, steering motor
Electric Power Steering with no CAN ML Software Tuning 9 03-12-2023 01:51 PM
Electric power steering and steering column part info raspec Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 10-12-2021 06:27 PM
Electric Power Steering oziel Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 01-24-2021 02:06 AM
Electric Power Steering ArtS Electronics | Audio | NAV | Infotainment 0 10-31-2016 09:19 AM
Electric power steering madfast Scion FR-S / Toyota 86 GT86 General Forum 33 10-13-2011 11:11 AM
