#1611 | |
Wears Pants
Drives: 14 FRS K24 swap - SOLD
Here's the factory diagram CLICK ME What ECU are you using? Haltech like the Kpower kit? If so how will you sort out the jumper board? Last edited by captain awesome; 02-22-2023 at 04:49 PM. |
#1612 | |
Drives: Q5 + BRZ + M796
#1613 |
Drives: Turbo K24 BRZ (in progress)
Yes I bought a haltech elite 1500 and will be pulling the trigger on the jumper board today or tomorrow. Just trying to build the engine harness myself. I will look into his diagram and attempt to make it this weekend. And thats exactly right, bought a "tucked" harness that I want to hack up to recreate that one you pictured.
#1614 |
Drives: None
If you're using their jumper board then you need to copy the KPower 54 pin exactly since it will not match stock pin for pin. I wrote down what some pins were when troubleshooting mine, but I don't have a full pinout anywhere. Your best bet is going to be begging KPower to send it to you or to map your adapter board output -> input -> haltech and build a 54 pin diagram from there.
I asked them for pinouts and they weren't supplied to me, so if you do get ahold of them please post them.
| The Following User Says Thank You to RedReplicant For This Useful Post: | Irace86.2.0 (02-23-2023) |
#1615 |
Drives: 13 White MT FR-S
Here is what I ended up doing with the exhaust around the cd009 and mounts. Its still really tight and it may need a hammer in a few places. I just slipped it over the cut header so we will see how bad the exhaust leak is lol. Don't mind my damn fluxcore welds
| The Following 5 Users Say Thank You to ML For This Useful Post: | captain awesome (02-23-2023), endless_pain (02-24-2023), funkjaw (02-24-2023), Irace86.2.0 (02-23-2023), RedReplicant (02-23-2023) |
#1616 | |
The electrical wiring diagram is a bit of a bear; you will have to trace the lines through multiple pages back to the harness and ECM and compare with the jumper board. Ugh
| The Following 3 Users Say Thank You to Irace86.2.0 For This Useful Post: |
#1617 | |
#1618 |
Wiring is not for the faint of heart. It is a tedious process to sort through the wiring diagrams and cross reference everything with the jumper board for accuracy with the wiring diagrams. It would be far easiee doing a custom harness without using the stock harness, and it would be even easier without integrating CANBUS. Frankly for me, some things are better worth my time to buy the part and work some overtime. This is one of them. Good luck either way.
| The Following 2 Users Say Thank You to Irace86.2.0 For This Useful Post: | funkjaw (02-28-2023), RedReplicant (02-26-2023) |
#1619 |
Drives: None
If anyone else was curious about the Ichiban 74mm Bosch to B Series (kpower flange) adapter, mine finally showed up from Thailand last week.
![]() ![]() I haven't test fit it yet, but it seems like it'll work. Currently looking into another intake manifold to throttle body option that has cropped up though.
| The Following 3 Users Say Thank You to RedReplicant For This Useful Post: |
#1620 |
So if anyone needs to get access to the oil pan I have successfully done that last night. You will need a engine support bar like the one below but the way I did it was have one hook and slid it from under the intake manifold there is a gap between the middle runners and the head. Just put on hook through there to support the engine from above.
Then basically unbolt the sway bar supports (that go from the chassis to the subframe) but leave the bolts that hold it to the chassis in, just loose. unbolt the lower control arm connections to the subframe, steering rack, on one side I found it easier to loosed the strut/knuckle bolts, and disconnect the tie rod from the knuckle, and the sway bar connections to the lower control arms. Then it was just unbolt the motor mounts from the bottom and drop the subframe out while moving the lower control arms out of the way. All said and done it took 3 hours to drop it, take the oil pan off, reseal it, and put the car back on the ground. Really not too bad ![]()
| The Following 6 Users Say Thank You to ML For This Useful Post: | captain awesome (03-01-2023), endless_pain (03-01-2023), funkjaw (03-01-2023), Irace86.2.0 (03-01-2023), redlined600 (03-01-2023), RedReplicant (03-01-2023) |
#1621 | |
Wears Pants
How thick is the spacer vs the Kpower one?
| The Following User Says Thank You to captain awesome For This Useful Post: | RedReplicant (03-02-2023) |
#1622 |
Drives: None
Throttle bodies from flange that goes against adapter gasket to outer edge of TB inlet:
BRZ 65mm: 69mm Bosch 74mm: 57mm KPower BRZ 65mm Adapter: 24mm + 1-2mm for gasket KPower Bosch 74mm Adapter: 21mm + 1-2mm for gasket Ichiban Engineering Bosch 74mm Adapter: 22mm + no gasket thickness since it uses an o ring instead of a flat gasket (also note that you also lose the flat 1-2mm gasket between the manifold and the adapter) This kinda highlights how much shorter the stack height from the intake manifold to the intake tube adapter is for the Bosch vs BRZ TBs (and therefore more flex afforded by the coupler). Over half an inch more flex in the Bosch setup vs BRZ.
| The Following 2 Users Say Thank You to RedReplicant For This Useful Post: | captain awesome (03-02-2023), funkjaw (03-03-2023) |
#1623 | |
Wears Pants
Fingers crossed this one fits well. I'd like to just rely on an o-ring seal instead of the Kpower stuff.
#1624 |
Drives: None
I'll test fit it later today, just been lazy about going into the garage lately lol.
| Rigid Industries SR-Series Pro Light Bar on my BRZ | Stang70Fastback | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 12-29-2019 03:13 PM |
| Airlift from industries finest | J_Nasty | Member's Car Journals | 0 | 02-04-2017 01:59 PM |
| Carbox Industries - Introduction | CarBox | CANADIAN Sales | 5 | 04-22-2014 01:22 PM |
| 86 industries | Duthebarber | Northern California | 70 | 03-28-2014 04:10 PM |
| Another 86 Industries another bad experience | sikest | User/Vendor/Sponsor Reviews, Feedback, Comments | 3 | 03-13-2014 01:00 AM |
