| GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
#15 |
Drives: 2020 toyota 86
Kiss your warranty goodbye upon installation..
#16 | |
Based on the pictures out there, debris that is getting caught in the pickup screen is mostly large strips and chunks, which is what our pre-filter will stop. |
| The Following User Says Thank You to KillerBMotorsport For This Useful Post: | blsfrs (02-15-2023) |
#17 |
Master Collaborator
That depends on where you live. In the US, the Magnusson Moss Warranty Act specifically states that the aftermarket part must be the reason of the failure as grounds for the manufacturer to deny your warranty claim. That would be like a dealer claiming that your new aftermarket head unit caused your brakes to fail and denying your claim for that reason. Without proving this as fact, the dealer would have no legal grounds for denying your claim.....and in this example, if they tried, social media would have a field day with it, and shame them into submission. Also, the MMWA states that you may disassemble to make repairs to your own property, without voiding the warranty. Many manufacturers that put those little stickers on their product that state "Warranty Void If Removed" don't realize it, but that is not in line with the MMWA. Some manufacturers have even been fined for doing so. |
| The Following 3 Users Say Thank You to FR-S2GT86 For This Useful Post: |
#18 | ||
Drives: 01 911 Turbo, 03 G500
https://www.tacomaworld.com/threads/...ss-act.609911/ If you don't want to follow link, here is the text.... Quote:
| The Following 6 Users Say Thank You to smoltz For This Useful Post: | Clipdat (02-18-2023), Griever423 (03-25-2023), Marrk (02-20-2023), Pat (02-16-2023), soundman98 (02-15-2023), Sport-Tech (02-16-2023) |
#19 | |
ProCrastinationConsultant
#20 | |
so to use a gasket would require a thicker oil pan. not difficult. but also, the block mating surfaces would need to be lapped after the block is assembled to ensure a perfectly flat surface for the gasket to seal against. which is really where a sealant works better than a gasket.
#21 |
Meow
Drives: GT86 (now sold)
I was thinking more along the lines of a pre-cut silicon gasket like this for example:
#22 | |
Only addressing the oil pan is mostly an exercise in futility. Just went out to the shop and snapped these pics of the block-to-upper oil pan RTV. These are only the areas that can be seen, but there is a lot more that can't. Anyone can also go pop the hood and look on the timing cover and other places to see RTV oozing out everywhere. |
| The Following 5 Users Say Thank You to KillerBMotorsport For This Useful Post: | Clipdat (02-21-2023), NoHaveMSG (02-21-2023), Ohio Enthusiast (02-16-2023), soundman98 (02-17-2023), timurrrr (02-19-2023) |
#23 | |
The upper pan mating surface is only 4mm (.156") wide. So even if you had a billet pan with machined a flange, it's not wide enough to support using an o-ring groove, and marginally wide enough to support a traditional gasket. Having designed and made Suby oil pans for over a decade, we've tested many methods of pan sealing and none are anywhere near as effective as RTV. With our thick precision machined flange, the ONLY time we use a rubber gasket or pan with an o-ring groove is for in-house testing where we put the car on the dyno, make a dozen or so pulls and the pan comes back off. It's almost always wet somewhere, even after that short of a period of time. |
| The Following 4 Users Say Thank You to KillerBMotorsport For This Useful Post: |
#24 |
Drives: 86 GT
Since we're on the topic of gaskets...
Just sharing that a shop in Taiwan has created a gasket for the oil pan for FA20/FA24. Not sure if that's the original oil pan, or other details which I have missed. https://www.facebook.com/10005757693...LNHb4TpuQXai7D
DIY stuff at Compelica Works
| The Following User Says Thank You to Compelica For This Useful Post: | Clipdat (02-18-2023) |
#25 |
You can get a gasket from AutoZone if you want. They work... but not nearly as well.
That is an OEM pan. |
| The Following User Says Thank You to KillerBMotorsport For This Useful Post: | Compelica (02-18-2023) |
#26 | |
Drives: '23 BRZ Limited
I'm glad someone else posted the the legal thing regarding M-MA.
People don't seem to get you'll have to prove to the dealer X didn't cause Y, not the other way around. Quote:
Especially because if the OFHG fails and you don't notice, it leaks down and causes the belt tensioner to fail, causing the crank pulley to potentially suck the belt past the front crank seal and possibly into the bearings.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
#27 |
Drives: Honda Fit
Off-Topic: The engine is what keeps me from buying this car. I'm not a hater. I would like to be in love with the GR86. But really.
#28 |
Drives: FR-S,GTI
Enjoy your Fit then.
| New Release: Killer B Motorsport Dual Air Oil Separator | KillerBMotorsport | BRZ Second-Gen (2022+) — General Topics | 50 | 02-29-2024 07:19 PM |
| High Flow Oil Pickup by Killer B Motorsport | KillerBMotorsport | Engine, Exhaust, Bolt-Ons | 4 | 04-26-2022 10:51 AM |
| Beta Testers Wanted- Fuel Pressure Sensor | GSpeed | Tracking / Autocross / HPDE / Drifting | 5 | 08-16-2015 05:03 PM |
| OpenFlash Tablet: v1.60 OTS Maps (beta)-- USDM testers wanted | Shiv@Openflash | Software Tuning | 142 | 07-22-2014 11:21 PM |
| OpenFlash Tablet: USDM Stage 2 EL/UEL testers needed | Shiv@Openflash | Software Tuning | 13 | 01-05-2014 01:42 AM |
