#225 | |
Rust bucket enthusiast
#226 | |
Drives: Bone stock
Sent from my SM-F936U using Tapatalk |
| The Following User Says Thank You to Joveen For This Useful Post: | DarkPira7e (12-19-2022) |
#227 |
Got the intercooler on! MAF deleted w/ GM IAT. Had to re-weld the top pipe so it hasn't been cleaned up or smoothed out.
Need to work on the fueling map, boost comes on MUCH harder than before. Extremely happy so far!
| The Following 4 Users Say Thank You to DarkPira7e For This Useful Post: |
#228 |
Spent most of today tuning the VE table, no MAF to blend automatically reveals a lot of underlying issues with fueling! Mostly good now, drove the car for hours around town and on the interstate. Love this thing!!! Can't wait for warmer weather so I don't just light the tires up in ever gear. Onset of boost spins 4th at 55mph easily
#229 |
New 3" front pipe and over pipe from JDL! Current setup is 2.5" and it's a harsh change right at where the wastegate merges into the downpipe.
#230 |
Have you considered going with a better IAT sensor? We ditched the old-style GM sensors years ago because the response rates are horrible compared to something more modern. T1 makes some nice fast response IAT sensors that work exceptionally well.
| The Following 3 Users Say Thank You to KillerBMotorsport For This Useful Post: |
#231 |
I hadn't, I went with GM because it's familiar and I was able to get an adapter to connect to my OEM MAF harness. I'll definitely keep this in mind if I need something snappier. Does the T1 use the same pinout and connector? Thanks for the info!
#232 | |
Drives: 2018 Subaru BRZ
She needs a wash, that I'd be more than happy to work on it haha!
| The Following 2 Users Say Thank You to spcmafia For This Useful Post: | DarkPira7e (01-30-2023), Ultramaroon (01-30-2023) |
#233 | |
It gives much better feedback than that mid-80s GM sensor. I highly recommend it for high RPM boosted applications. |
| The Following User Says Thank You to KillerBMotorsport For This Useful Post: | DarkPira7e (01-30-2023) |
#234 | ||
Do you really think the faster response is necessary for IAT? I understand the appeal but as long as I'm under a certain range, I wouldn't think polling speed is something to be too concerned with (unless running something like water meth ). Thanks again for the input!!
#235 | |
The bigger question is why wouldn't you want a sensor that has a much better response rate? |
#236 |
*Need to detail intensifies*
| The Following User Says Thank You to spcmafia For This Useful Post: | DarkPira7e (02-09-2023) |
#237 |
Drives: Bone stock
How does the new exhaust sound
Sent from my SM-F936U1 using Tapatalk |
#238 |
Haven't gotten to move the car yet, we had a foot or two of snow drop and temps as low as -20f. Soon hopefully I'll have everything cleared so it can roam freely! I suspect it's just going to be a little deeper, the cat should flow very well so I doubt resonance or volume will be impacted much
| Tags |
| brz, frs, iag, jdl, turbo |
| Joel's BRZ - Low Budget Time Attack Build | DIY | Member's Car Journals | 403 | 11-19-2024 07:39 PM |
| Cxracing turbo problem | Kalebhall | Forced Induction | 10 | 11-16-2017 07:57 AM |
| Tony's Budget Turbo Build | glorydays | Member's Car Journals | 22 | 01-25-2015 11:02 PM |
| My boosted build...on a budget | PineappleFriedRice | Member's Car Journals | 95 | 08-17-2014 09:29 PM |
| Aznsky's budget STX build | Aznsky | Tracking / Autocross / HPDE / Drifting | 13 | 05-12-2014 08:44 AM |
