Old 01-22-2023, 06:10 AM   #1
darkofrs
Drives: 14 frs; drift spec
86nanny AND pedal commander?
has anyone ran both a beastronix 86nanny and pedal commander?
is it redundant to have both? or will having both benefit my car in the ways that it's supposed to...
darkofrs is offline   Reply With Quote
Old 01-22-2023, 10:54 AM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
it really depends on what you're looking to get out of things.
86 nanny really only manipulates traction control, abs, radiator fans.
pedal commander alters the gas pedal application curve.
of note, pedal commander inherently can't improve responsiveness as it doesn't alter the speed of the oem vehicle network, but improves the perception of responsiveness by telling the car you've stepped further into the gas than you have. if you're bouncing on/off, the gas, there's going to be a perceptible difference in this, which can lead to the car feeling like it's more jumpy. you'll have the same result just banging on the gas harder in stock form. so imo, pedal commander is a solution looking for a problem that the driver can't properly adjust to vehicle dynamics.
personally, i don't have any issues with the oem gas pedal curve. i can consistently put the motor right where i need it, even weeks apart after i've been driving other vehicles, essentially 'un-learning' myself from the 86.
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
NoHaveMSG (01-23-2023), x808drifter (01-23-2023)
Old 01-23-2023, 11:59 AM   #3
Do the pedal dance and forget about placebo add ons
Grady (01-23-2023), x808drifter (01-24-2023)
Old 01-23-2023, 02:01 PM   #4
Grady
Grady's Avatar
If you want different throttle response just get a tune.
The Following 2 Users Say Thank You to Grady For This Useful Post:
soundman98 (01-26-2023), x808drifter (01-24-2023)
Old 01-23-2023, 02:08 PM   #5
Or a lightweight crank puly.I hear they have a massive impact on throttle response!
Old 01-23-2023, 05:32 PM   #6
Grady
Grady's Avatar
Is this some of that Canadian humor?
Old 01-23-2023, 05:42 PM   #7
Humour. It would be Canadian humour
Grady (01-23-2023), Ultramaroon (01-23-2023), x808drifter (01-24-2023)
Sold - Beastronix 86Nanny Volkyrie Audio/Visual, Electronics, Infotainment, NAV 2 09-21-2022 11:22 AM
Cusco Pedal Install & Pedal Lateral Stiffening (Sideways Loose Pedal) BOND007_LTK DIY (Do-It-Yourself) Guides 5 05-20-2022 05:12 PM
Used Beastronics 86Nanny PD + ABS Crashdummy Audio/Visual, Electronics, Infotainment, NAV 3 12-18-2019 06:08 PM
FS: 86Nanny PD superleggera Engine, Exhaust, Bolt-Ons 2 10-18-2018 10:21 PM
SOLD! Beastronics 86Nanny PD + ABS Crashdummy Miscellaneous 1 05-27-2017 01:40 AM
