Old 01-06-2022, 12:30 PM   #15
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
Originally Posted by FR & S View Post
Hi. I have a 2015 AT FRS and have been hearing rod knock from my engine. I wanted to get an idea of what I can expect to pay for the repairs. Any mechanics here or people who've had it done that can chime in? (Please also let me know which state you got the work done in since cost can vary.)
Is it cheaper to repair it or do an engine swap? How much can I expect to pay total for an engine swap? Thanks!
I had a spun rod bearing and got a used engine.
Paid 2500 for the engine in 2015 and 500 to have it installed. In retrospect, I would've installed it myself. This is one of the easiest engines to install.
Getting it rebuilt is probably not a good option. If you're wanting a built engine, you could buy a short block but they typically have a high core charge and your crank could be bad requiring additional cost.
I was able to get my used engine for 2500 with no core charge. So I still have my other long block. Well actually full engine minus accessories.
Jaden
Jaden is offline   Reply With Quote
Old 01-28-2022, 03:45 PM   #16
rbail1
Drives: 2016 Scion Frs, 2008 Mercedes CLS
Man.....I am new to these cars but I have never heard of a knocking rod lasting two years. Something would have let go by now.
rbail1 is offline   Reply With Quote
Old 02-07-2022, 11:42 AM   #17
Ogt
Ogt's Avatar
Drives: ‘13 AT FRS
I don’t think you’d last 2 years with what was originally even a “slight” knock unless the miles driven don’t reflect a normal two years. At least from prior experiences…
Ogt is offline   Reply With Quote
Old 01-22-2023, 03:16 AM   #18
Osidepirate
Drives: 2014 Frs
Thanks Tommy.
It actually sounds a lot like this... (specifically the sound you hear more clearly at the 0:09 and 0:19 marks) If the problem is one in the same, looks like it is the vacuum pump.
humfrz, the sound does seem to be coming from the passenger side. if it is the vacuum pump, i'm thinking that's a significantly cheaper job. i wonder if it's something i can tackle on my own. i'll need to see if a DIY exists on Youtube.
Hey fr&s did you ever find out what caused this issue? My engine started having the same issue recently and don’t know where to start.
Osidepirate is offline   Reply With Quote
Knock Knock? Expired Warranty Frivo Issues | Warranty | Recalls / TSB 20 08-17-2020 09:04 PM
Estimated costs for out of warranty repair work? tracerit Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 03-24-2016 02:03 PM
Estimated Max HP for a N/A setup. kayoh Engine, Exhaust, Transmission 67 02-19-2016 12:43 AM
Repair Costs discretion Scion FR-S / Toyota 86 GT86 General Forum 29 11-24-2015 10:27 PM
Estimated Price.. SLeRoux92 Scion FR-S / Toyota 86 GT86 General Forum 44 05-25-2011 11:58 AM
