Old 01-21-2023, 07:49 PM   #1
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Steering Rack Bushings: Grease or No Grease
Ok, this will probably seem like a dumb question. I am installing Whiteline steering rack bushings. They came with a packet of grease and no instructions. I have seen both that one should apply grease and should not apply grease to steering rack bushings. Which is right?
My quite fallible logic would say the bushings are fully constrained by normal forces so any shear would just serve to wear/squeak/etc., and thus I should apply the grease that was included in the package clearly for this purpose, just like all the other poly bushings.
Also: "Build Thread"
Old 01-21-2023, 08:19 PM   #2
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Because poly I would agree, and it shouldn't hurt in this instance. iirc I did my delrin bushings dry, no regrets.
Whiteline usually has instructions easily available to download on their website, looks like the link is broken for the 86 steering rack bushing kit. Their customer support may be able to provide it with an email to them.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
Spuds (01-21-2023), x808drifter (01-22-2023)
Old 01-22-2023, 11:33 AM   #3
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
As @stratcaster61 mentioned check the website. I greased mine.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
The Following User Says Thank You to Capt Spaulding For This Useful Post:
Spuds (01-22-2023)
Old 01-22-2023, 11:48 AM   #4
Ohio Enthusiast
Drives: 2018 BRZ
I greased my Energy Suspension rack bushings.
The Australian Whiteline website says this, so I assume you should grease them:
Supplied with extreme pressure molybdenum disulphide (LM) based grease for extended life.
Internal grease reservoirs provide continual self-lubrication for optimum friction management.
The Following User Says Thank You to Ohio Enthusiast For This Useful Post:
Spuds (01-22-2023)
Old 01-22-2023, 03:01 PM   #5
nissanfanatic
nissanfanatic's Avatar
Drives: 2023 BRZ
OT: where did you get your delrin steering rack bushings?
nissanfanatic is offline   Reply With Quote
Old 01-22-2023, 03:19 PM   #6
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Mine are Diftec.
The Following 2 Users Say Thank You to dragoontwo For This Useful Post:
nissanfanatic (01-22-2023), strat61caster (01-22-2023)
Old 01-22-2023, 06:23 PM   #7
strat61caster
@nissanfanatic as above diftech, good quality, no issues.
Personally I don’t think they’re worth it, oe bushings are stiff enough, others disagree.
ineedyourdiddly
Old 01-23-2023, 01:19 AM   #8
Spuds
The Dictater
Spuds's Avatar
The clear right thing to do is contact Whiteline support to get the official instructions. So I just greased the bushings and installed them lol.
The Following 3 Users Say Thank You to Spuds For This Useful Post:
Ohio Enthusiast (01-23-2023), strat61caster (01-23-2023), x808drifter (01-23-2023)
Old 01-23-2023, 02:14 PM   #9
Capt Spaulding
Persona Non Grata
Just for fun, when I installed mine I did call Whiteline. Had a nice chat with a technician who said the grease is mostly to prevent squeaks. The knurling on the inside of the bushing is to help hold the grease in place.
The Following 2 Users Say Thank You to Capt Spaulding For This Useful Post:
Spuds (01-23-2023), x808drifter (01-24-2023)
Old 01-23-2023, 05:16 PM   #10
norcalpb
norcalpb's Avatar
For anyone who doesn’t own a tub, I highly recommend ordering this large tub of energy suspension grease. So nice to have on hand if you find a poly bushing is starting to groan on you.
https://www.amazon.com/Energy-Suspen...s%2C272&sr=8-4
The Following 3 Users Say Thank You to norcalpb For This Useful Post:
Capt Spaulding (01-24-2023), Spuds (01-23-2023), x808drifter (01-24-2023)
What steering rack bushings to get? Pho20 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 09-17-2017 10:11 PM
Steering Rack Lockdown/Bushings Apex_BRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 08-18-2014 02:01 PM
TiC steering rack bushings review mokinbird87 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 07-21-2014 01:43 PM
Are our wheel bearings and bushings sealed or are we able to grease them up ? ScionFR-S Issues | Warranty | Recalls / TSB 4 01-28-2014 09:49 PM
CMS SEMA 2013 coverage - Whiteline anounces new black Grease-less bushings Circuit Motorsports Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 11-11-2013 05:19 PM
