#29 | |
Drives: Crapcan
#30 | |
Drives: Supra MKV, FR-S
| The Following 2 Users Say Thank You to zeroomega For This Useful Post: | nissanfanatic (01-18-2023), timurrrr (01-18-2023) |
#31 | |||
Of course! We love forums just for these kinds of things!
Teams like this place no value on what it costs to shave a few tenths off a lap time. As much as I love Subaru, for anyone with THIS kind of budget I'd recommend another platform for sure! From my knowledge, a DS system is used because they significantly lower (and push back) the engine in the chassis (on a custom engine cradle of course). Moving the CG has a profound effect on handling performance.I don't think they added a DS because it's a weakness of the OEM oiling system. I think they did it because they were building a specialized highly competitive track car and were changing everything anyway. If it needed it or not. At that level you don't test first, you install the best parts money can buy, and then test. Here's a great read on oil, temps, and viscosities, for anyone interested... https://penriteoil.com.au/knowledge-...-viscosity/180 |
| The Following 3 Users Say Thank You to KillerBMotorsport For This Useful Post: |
#32 | |
The crank is far. On the dyno we've tested +1 quart and -1 quarts and there's zero difference. Although, that's on a chassis dyno, not flogging around a road course. Adding additional oil may or may not improve conditions, depending on the cause. |
#33 | |
#34 | |
For the pressure change from 210F to 250F, internal bleeding or not, it still translates to the necessity of adequate oil cooling. And if it is caused by internal bleeding instead of just oil viscosity drop, we cannot fix it. With Setrab Series 9 15 rows oil cooler core, under 100F California summer, it is not rare to see oil temperature closes to 250F, unfortunately. For dry sump system, I guess we cannot say the cause why Subaru add that to their race spec engine for sure unless their engineer claim it. But I think we can all agree it is a nice thing to have if we can have it :-). Whether or not boxer engine has an inherited oiling problem compared to a inline engine, the fact that FA20 and FA24 has oil pressure drop behavior under high G load doesn't change. Whether or not this oil pressure will become an issue depends on the engine tolerance and that is something we don't know. I prefer to play it safe, doing anything economically to mitigate the pressure drop instead of just wishing this engine can withstand single digit psi under high load. I wish next gen 86 can have a Toyota inline engine. At least it will make service it easier. |
#35 | |
Drives: zd8 brz
on my old e36 m3(and pretty much any e36 m3 that tracks heavily with the stock s52), its common to just dump a whole quart of oil in before going on track. its gonna burn it off when vanos is active at high RPM(much like how vtec tends to eat through oil as well). seems like i may end up doing half a quart before going on track and keeping an eye on it throughout the day. |
#36 | ||
Would be nice to see a bit more data here. Where were the temps measured from? Timing cover or sump? There's generally a 20° difference between the two, with the sump being colder. There could be various reasons for this, but in motorsports, taking temps at the sump is the standard. Quote:
![]() Careful what you wish for on this one! |
#37 |
Drives: Mini Cooper S
I see a lot of people talking about going to 5w30 for track usage but I don't really get why. If you're trying to mitigate the oil being too thing at higher temps why increase the low end viscosity? Wouldn't 0w30/0w40 make more sense?
That being said, I agree that keeping the oil within operational temperatures is preferable to trying to guess what viscosity the engine likes at any given temperature. Looking @ the Jackson racing one since it keeps the conditioner, since I live in the NE I need that. Last edited by BioRebel; 01-20-2023 at 11:03 AM. |
#38 | |
Drives: 2023 BRZ
Multi-viscosity isn't a panacea though (with the exception of ester oils as they are naturally multigrade) as it is created through the use of polymer additives. Generally, more polymer additives = faster loss of viscosity (shearing) which is one of the top concerns esp in hard driving. IDK about you, but I'm less concerned with "year round" usage and more concerned with not having to change the oil after every two track days because it's sheared down to a 20w at 100*C. Those are, of course, generalizations best confirmed through testing, which is why I tend to review UOA's in applications/use cases similar to my own. |
#39 | |
#40 | |
| The Following User Says Thank You to zeroomega For This Useful Post: | BioRebel (01-24-2023) |
#41 | |
Yes, very familiar with the OEM setup. It's terrible, lol. If you're at a point where you're tracking regularly and considering an oil cooler, a dedicated oil temp gauge should be in use. As far as taking temps from the sump, we carry a bunch of adapters specifically for that purpose. |
#42 |
Drives: 2023 BRZ
| AD08R tire pressure Drag Race | pro_turbo | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 11-13-2021 04:04 AM |
| Oil pressure drops to zero after a cold start? | MINOCIN | Engine, Exhaust, Transmission | 24 | 07-10-2014 02:57 PM |
| Darren drops his phone onto the Formula D track... | DarrenDriven | Northwest | 2 | 07-22-2013 03:30 AM |
| No Race Track Seats in Race Car Drivers Every Day Cars..!! | JohnnyNight | Cosmetic Modification (Interior/Exterior/Lighting) | 24 | 10-16-2012 04:42 PM |
| FRS @ willow springs (1.8 mile race track with 12 corners) | scionnut | Southern California | 7 | 08-04-2012 02:29 AM |
