#71 |
Drives: 2017 BRZ
Plenty of room to remove the cap and fill with a bottle. The pics are kind of deceiving, but the panel is far lower than what the stock dash top is.
| The Following User Says Thank You to gt5759 For This Useful Post: | blsfrs (12-28-2022) |
#72 |
Drives: 1999 Miata
I am seriously disappointed with the level of dust on this hood! Just kidding of course. The quality of this build astounds me. This looks to be turning out really nicely. Hopefully it will be as fast as it is pretty.
DJ
1999 Miata VVT swap "Maggie" 2013 BRZ "Nancy-Drew BRZ" |
| The Following User Says Thank You to MX-5RACER For This Useful Post: | gt5759 (01-03-2023) |
#73 | |
Drives: 2017 BRZ
Thank you! and it better be fast or i'm burning it to the ground!
#74 |
Drives: 2017 BRZ
More work done in between holiday stuffs! Wing mounts are done and had to change wing manufacturers since the communication level with top stage composites was complete shite
so now I am going with AJHartman's fulcrum 14. Only bad thing is the wait time, which is about 2 months right now but at least I know I am getting it as AJ's communication is great.Coolant reservoir/tank is almost done as is the crank case breather tank, just need a few more fittings to complete. Still kind of debating on the breather tank design, its simple and functional but I just feel like it's pretty plane, having a bit of designer's block . Both of them will be painted with the satin black steel-it like the dash. I plan on doing the intake manifold and valve covers anodized/candy red.![]() ![]() ![]() ![]() ![]()
| The Following 5 Users Say Thank You to gt5759 For This Useful Post: | captain awesome (01-04-2023), Dzmitry (01-04-2023), jflogerzi (01-04-2023), Kelse92 (01-03-2023), RedReplicant (01-03-2023) |
#75 |
Drives: 2017 BRZ
Not much done but had a moment between cars to mount up some temp slicks to check fitment and what I need to do for clearance. Fitment is great, just need some upper control arms in the rear and they will clear like the fronts. Don't mind the stance at the moment, its not even remotely right and almost all the suspension in the back is just finger tight so it kind of flops around.
![]() ![]() I'm pretty happy with the look. Figuring out livery will be a bit of a challenge but that's half the fun! |
| The Following 3 Users Say Thank You to gt5759 For This Useful Post: |
#76 |
Drives: None
That looks soooo good. I also always laugh a bit when I see what a 225 Hoosier looks like on a 10.
Bumper grille looks like it could have been OEM.
| The Following User Says Thank You to RedReplicant For This Useful Post: | gt5759 (01-17-2023) |
#77 | |
Drives: 2017 BRZ
Speaking of tires, I am thinking the first set of tires I try will be the maxxis RC1 vs the toyo RR. I feel like they could be a solid contender especially at about 255.00 a tire shipped, but I do feel toyo's contingency for winning is better. With either tire I can have 240whp at 2400lbs in ST4. |
#78 |
Drives: 1999 Miata
The Toyo and the Nitto NT-01R's are very similar and suck compared to a Hoosier, but they suck for a LONG time (In other words, they are not as fast as a Hoosier, duh, but they last a long freaking time). I prefer the NT-01R's over the Toyo's as the Nitto's handle a bit more slip angle on exit than the Toyo's. Let me also add that I have zero time in a Twin on either, but hundreds of laps in a Miata on both, so take it with a grain of salt.
DJ
| The Following User Says Thank You to MX-5RACER For This Useful Post: | gt5759 (01-18-2023) |
#79 | |
Drives: 2013 frs base
#80 |
Drives: None
His whp graph is going to be a flat line from like idle to rev limit lmao
#81 |
Drives: 2017 BRZ
It can be a bit confusing if a person doesn't know what the class rules are. NASA ST/TT4 is power to weight class so that's where the limitation comes from. I will be running in other classes and unlimited style ones for things like GTA/SLB and GL in which all of the power will be attempted to be used. ST4 is my primary focus though.
RedReplicant hit it on the head, it will make 240whp from idle to a 8k rpm redline and sound fantastic while doing it. One of the main reasons I went down this powertrain path was to combat the BMW's that are doing basically the same thing in ST4 but I decided to turn the knob to 11. |
| The Following 2 Users Say Thank You to gt5759 For This Useful Post: | blsfrs (01-26-2023), RedReplicant (01-25-2023) |
#82 |
Drives: 2017 BRZ
Much stopping power! I decided to throw on the front brakes last night to make sure fitment is good and was very pleased. Sakebomb garage makes a great kit that you can upgrade a little bit as I chose to do so. Wilwood superlite calipers that use 20mm thick pads, APracing 325mmx32mm 70 vane floating rotors. Kit comes with all nicely plated hardware, jet nuts and floating clips. Rotor hats and mounting brackets are nicely anodized and machined well. Rotors come pre assembled. Wheel spoke clearance is beyond safe as well, I can shove my hand in between the caliper and spoke.
![]() ![]() ![]() ![]() ![]() ![]() Dont mine my rusty as parts I need to get to doing the suspension soon.
| The Following 4 Users Say Thank You to gt5759 For This Useful Post: |
#83 |
Drives: 2023 BRZ
I think your rotors are on the wrong side of the car.
Director of Rocky Mountain 86CUP
| The Following 3 Users Say Thank You to Pat For This Useful Post: |
#84 |
Drives: 2017 BRZ
Correct! So, no one use these pictures for rotor direction reference!
That'll teach me to throw something on the car and not pay attention if I'm taking pictures!
| The Following User Says Thank You to gt5759 For This Useful Post: | RedReplicant (01-25-2023) |
| Jensen NASA ST4 race build | thin2win | Member's Car Journals | 18 | 04-14-2021 01:15 AM |
| Beginner STX Build Whiteout FRS Build Thread | Hachi86Roku | Tracking / Autocross / HPDE / Drifting | 21 | 03-31-2020 08:52 PM |
| PC Build Thread | WingsofWar | Off-Topic Lounge [WARNING: NO POLITICS] | 126 | 01-22-2017 10:59 PM |
| Superpenguin's "Not Another Build Thread!" Build Thread | superpenguin | Member's Car Journals | 7 | 06-17-2015 05:00 PM |
| Car 986 Scion FR-S NASA PTD Race Car Build | phastafrican | Member's Car Journals | 70 | 01-03-2015 10:32 PM |
