Old 01-04-2023, 09:29 AM   #1
Desertnate
Spelling Impaired
Drives: 2022 BRZ Limited WR Blue
Michelin PS4's wearing out really fast?
I was going over my car the other day since I hadn't driven it much this month and noticed the PS4's mounted on the car when I bought it are only about a 1mm above the wear bars. This surprised me since I've only owned the car for a year and driven about 9800 miles.
I fully understand/expect summer tires wear out faster than all seasons, but this is half the life I've seen from a set of PSS's on a GTI or a set of PS4S's on a RWD BMW 435. Both of those cars were autocrossed as well, just like my BRZ, but the tires seemed to wear much slower.
Wear is even across the entire tread area and there are no indications of feathering/cupping/etc that would indicate an alignment issue or something else which would cause pre-mature wear. They just seem to be wearing out far faster than what I've experienced with other Michielin summer tires.
Anyone else who's car came equipped with these tires have the same experience?
Desertnate is offline   Reply With Quote
Old 01-04-2023, 10:37 AM   #2
ZDan
ZDan's Avatar
Drives: '23 BRZ
What's your front and rear toe?
Old 01-04-2023, 01:36 PM   #3
Desertnate
Spelling Impaired
Right now I'm running the factory alignment as the car was delivered about a year ago. I was holding off on doing an alignment on the car until I get my dedicated wheel/tire set for autocross this spring, so I haven't had it up on a machine yet.
If toe is way off would there be any visible signs? I'm not seeing anything abnormal when looking at the tire. My last car had an issue with toe up front and I'd see feathering on the outside tread blocks. That's not the case in this instance.
Old 01-04-2023, 02:25 PM   #4
SCFD
I'm assuming your alignment was off. Every new car I purchased I've always got an alignment done almost right away (usually within the break-in period).
Edit: For what it's worth, the last 2 new cars I purchased I was able to get the alignment covered by the dealer.
SCFD is offline   Reply With Quote
The Following 3 Users Say Thank You to SCFD For This Useful Post:
churchx (01-04-2023), Desertnate (01-06-2023), x808drifter (01-09-2023)
Old 01-04-2023, 11:16 PM   #5
churchx
churchx's Avatar
Drives: 2014 GT86
This. Very often factory alignment in completely new car might be really off. And passing values of still within OE acceptable range extremes make handling VERY different, potentially with handling artifacts. Do proper alignment at very least once.
Old 01-05-2023, 09:18 AM   #6
Desertnate
Spelling Impaired
Thanks everyone for the suggestions. I would never have considered alignment since I wasn't seeing the tell-tail signs of tire wear I'm used to seeing with a bad alignment.
Old 01-05-2023, 02:13 PM   #7
ZDan
ZDan's Avatar
Drives: '23 BRZ
When you get it checked, you should tell them the specs that you want rather than just letting them get it "within spec". The spec is a very broad range. For max tire life you'll want close to zero toe, front and rear. That's what I run, 0.0 front and rear, for road and track.
The Following 3 Users Say Thank You to ZDan For This Useful Post:
Desertnate (01-06-2023), PerCompLLC (02-08-2023), SCFD (01-05-2023)
Old 01-05-2023, 04:26 PM   #8
SCFD
I refuse to take my car to any shop that is unwilling to set the toe to exactly what I want. It isn't something hard to do for the shops that knows and cares about their work.
Old 01-07-2023, 01:56 AM   #9
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
how many autox runs on the tires?
ineedyourdiddly
Old 01-07-2023, 06:37 PM   #10
H380
H380's Avatar
Drives: 2022 BRZ Limited WR Blue MT
PS4's are 20K mile tires. So they are 1/2 life now
H380 is offline   Reply With Quote
Old 01-08-2023, 08:17 AM   #11
ZDan
ZDan's Avatar
Drives: '23 BRZ
He’s 1mm from the treadwear indicators, so they’re pretty much done as far as being ok to drive in the rain.
Old 01-09-2023, 09:36 AM   #12
Desertnate
Spelling Impaired
I had 44 runs this season with this car, so not that many really.
I had double the number of runs AND road mileage out of sets of PSSs and PS4Ss on other vehicles. I figured the PS4s would last similar, if not longer, since they didn't seem to be as soft as the "top shelf" Michelin summer tires.
That's actually better than what I was expecting consider my usage. I would have been happy with 20K which is about what I normally get from a set of summers.
Yep. That's what got me concerned when I checked them out. I'll have new shoes on the car in a week or two.
Since we're having another abnormally warm winter in this area, I wasn't in much of a rush. Now it's wear rather than weather that's driving events.
The Following User Says Thank You to Desertnate For This Useful Post:
strat61caster (01-09-2023)
Old 01-09-2023, 11:16 PM   #13
JohnH
Professional wrench
Drives: 2020 BRZ ST RS
I have owned 2 brand new cars, one a custom order, and one right off the showroom floor, as well as one bought with very low mileage/as new. All of them were off a considerable margin.
Also, as I work on countless cars and do lots of alignments I see tons of nearly new ones that also need alignments.
Many shops will say "its good" if its just all "in the green" or just out of the green a bit. This might have been good with domestic front ends from decades ago, but on a quality modern performance suspension, this is absolutely not good.
In other words, take it to a GOOD alignment shop, one with a tech who not only will do more than just "put it in the green" but actually understands what they are doing and WHY they are doing it.
put some camber bolts in the front and go get it done
And if the tech doesn't correctly set all your tire pressures, and make sure nothing is worn out before they start, they aren't the right one
Also, if your tires are worn unevenly, the alignment might not be able to make them wear evenly again, but the next set will wear more evenly
2020 BRZ Sport Tech RS World Rally Blue
'18 TS Suspension, camber bolts, align.
Gruppe-S UEL header/overpipe
Wayne Rom Stg 2+ tune
225/45VR17 RT660s
JohnH is offline   Reply With Quote
The Following 3 Users Say Thank You to JohnH For This Useful Post:
Desertnate (01-10-2023), PerCompLLC (02-08-2023), x808drifter (01-11-2023)
Old 01-24-2023, 03:31 PM   #14
Flarpswitch
Flarpswitch's Avatar
Drives: 2022 BRZ Ltd, 2025 Ascent Touring
I just replaced my PS4 tires with the All Season version after only 4,000 miles. It was seasonal driving conditions that prompted the change. I estimate about 8/32" on the front and 7/32" on the rear of tread depth. My tires were wearing evenly with no signs of misalignment. The summer tires handle nicely, but they certainly would not last long.
The ants are our friends, they’re blowing in the wind, that ants are blowing in the wind.
Flarpswitch is offline   Reply With Quote
Carpet wearing off ironsurfer129 Scion FR-S / Toyota 86 GT86 General Forum 30 07-29-2013 03:02 PM
What Shoes Are You Wearing Today Thread? M-17 Off-Topic Lounge [WARNING: NO POLITICS] 62 07-15-2013 01:28 PM
Mats wearing out Gp1666 AFRICA 85 02-20-2013 06:40 PM
Drivers mat wearing out nzer AUSTRALIA 91 01-17-2013 06:04 PM
Fast car Fast driver vinyl decal I need help francosolracer Cosmetic Modification (Interior/Exterior/Lighting) 18 10-20-2012 03:43 AM
