Old 01-03-2023, 12:44 PM   #1
ajacob
ajacob's Avatar
Drives: 2020 BRZ
Transmission and diff fluid for 2020 BRZ
Been trying to get my hands on the Motul gear 300 75w90 fluid, but of course they’re still on back order everywhere. Going to start doing all the fluid changes myself. Can anybody recommend tranny/diff fluid for a 2020 BRZ that’s comparable to Motul? I was looking at Redline 75w90 & MT-90. Not entirely sure what the differences are. Any help is much appreciated
ajacob is offline   Reply With Quote
Old 01-03-2023, 03:09 PM   #2
ihavefat
Drives: 2018 BRZ
I initially wanted the motul for the ease of pouring but it was OOO so I went with red line. You can Google the difference from specification/additive perspective but it is my understanding MT90 is designed for transmissions.
No regrets. The complaint with the motul is that when cold, it shifts worse than stock because of its viscosity (which is also what probably makes it perform best in track conditions ). Red line shifts well in cold and warmed up.
ihavefat is offline   Reply With Quote
Old 01-03-2023, 05:35 PM   #3
ajacob
ajacob's Avatar
Drives: 2020 BRZ
What about the rear diff? What fluid goes in there?
Old 01-03-2023, 09:44 PM   #4
Grady
Grady's Avatar
I had shift issues in the heat and coming off the track with 300 75W90. Switched to Motul 75W140. No issues since. In the winter the first couple of miles you can not get to 1st unless you are at a complete stop but after that it is all good.
Old 01-03-2023, 10:52 PM   #5
SCFD
I'm currently using Redline MT-90 and Amsoil Severe Gear 75W90. I've always been a fan of Redline and it has worked well in all of my past cars.
SCFD is offline   Reply With Quote
Old 01-05-2023, 02:20 PM   #6
CSG Mike
CSG Mike's Avatar
Check out the CSG Maintenance packages for frs/brz/86 specific packages.
MT-90 is for transmission only, but 75W90NS can be used in both.
Pakelo DLS is great as well.
x808drifter (01-09-2023)
Old 01-05-2023, 02:40 PM   #7
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
There's also AMSOIL 75W90 GL-4. They list 2 products under the same designation
spcmafia is online now   Reply With Quote
The Following User Says Thank You to spcmafia For This Useful Post:
Old 01-05-2023, 05:17 PM   #8
SCFD
Is the 75W90NS safe? I thought it was GL-5 but our transmissions use GL-4.
Old 01-05-2023, 09:41 PM   #9
CSG Mike
CSG Mike's Avatar
Yes
It's more shear resistant than a GL-4 rated fluid.
Old 01-05-2023, 10:42 PM   #10
SCFD
Yes
I thought there was something about GL-5 fluid that is bad for synchros though? Or, maybe it's something that doesn't universally apply to all GL-5 fluid?
Old 01-05-2023, 11:31 PM   #11
CSG Mike
CSG Mike's Avatar
It's likely not universal, but as a general rule, modern formulations wont have incompatible components.
E.g. old Motul 300V (think over a 2 decades ago) did not get along with E85. Modern 300V does.
SCFD (01-06-2023), x808drifter (01-09-2023)
Old 01-10-2023, 11:36 AM   #12
terboboost
terboboost's Avatar
Drives: 2013 BRZ HKS Turbo
Have tried Motul 300V and Redline MT-90, street and track...both are great when the car is warm, Redline is marginally better when the car is cold. I'm using MT-90 from here...
IG: @terboboost | Twitter: @terboboost | youtube.com/@terboboost | D-corp.co
terboboost is offline   Reply With Quote
Old 01-18-2023, 09:54 AM   #13
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
I use Motul's Gear 300 because everyone and their mother uses it - and I've used it in my WRX autocross car over the years. In the BRZ, it was a big upgrade over the stock 25k mile fluid when I initially did it, so I've stuck with it.
Redline would be my second choice and might even be technically better. I feel like many fluids are so darn close in performance, feel, and lubrication/protection.
Personally I haven't found any fluid that completely fixes the cold 1-2 shift issues these cars have.
cmiovino is online now   Reply With Quote
DIY - Transmission / Diff Fluid Change Reference Guide F1point4 DIY (Do-It-Yourself) Guides 295 05-13-2023 03:34 AM
OS Giken Diff Fluid Desain2137 Mechanical Maintenance and Tools 1 10-30-2021 07:51 PM
2020 BRZ tS Fluid Question Alistia Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 07-15-2020 09:13 PM
Diff fluid question Mr_YUzU_FRS Engine, Exhaust, Transmission 2 04-07-2017 09:11 PM
Trans/Diff Fluid. DanoFA20 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 01-11-2013 04:11 PM
