Old 01-02-2023, 01:03 AM   #15
grumpysnapper
grumpysnapper's Avatar
Originally Posted by Joon525 View Post
Any pictures of this? (assuming this is a custom setup)
The mid muffler.
The break was midway above this.
Heat could definitely be a factor.
grumpysnapper is offline   Reply With Quote
Old 01-02-2023, 01:52 AM   #16
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Is it also possible that the muffler could have bounced or been bumped into the drive shaft?
Haven't seen harmonics mentioned so I'll throw it out there as a possible contributing factor. If you are racing around off road it's possible you hit some weird frequency between the front and rear bouncing around at different rates and moving around relative to each other. If it's a track, that might be repeated each lap.
More likely heat or muffler related though.
Also: "Build Thread"
Old 01-02-2023, 02:10 AM   #17
Originally Posted by grumpysnapper View Post
Of course having said all that, it was always a risk running carbon on this car!
At least it was spectacular.
Old 01-02-2023, 02:42 AM   #18
whataboutbob
AutoX-10/10ths every run
There's evidence of a polish mark on the muffler (cover?) and the weld looks like it's missing some material?
Build thread:Here
Old 01-02-2023, 08:03 AM   #19
grumpysnapper
...it was spectacular when my wife asked the actual cost...
Old 01-02-2023, 08:07 AM   #20
grumpysnapper
I like your thinking, but there is not enough upward play in the exhaust system to get close enough to the shaft (it would hit a solid mount that I have fitted off the gearbox cross member first).
Old 01-02-2023, 08:11 AM   #21
grumpysnapper
Well spotted.... although that pic was from an earlier escapade, pre break
Old 01-02-2023, 08:53 AM   #22
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
^^^this
How much design factor to account for scratches/divots? Stress risers lower actual critical speed.
Also interesting but might be coincidental, the failure occurred approximately where the stock driveshaft is divided.
I was looking at the same thing. My DDS AL shaft broke exactly in the middle due to exceeding its critical speed.
Old 01-02-2023, 02:44 PM   #23
Ah, that was yours! Now I remember. You were on a dyno and felt no warning.
Old 01-02-2023, 07:24 PM   #24
Grady
Grady's Avatar
Drives: BRZ Yellow, Ranger, Evora, WCM S2K
Since you already have the machined end parts have you considered buying a CF driveshaft blank and bonding up a new one?
Old 01-02-2023, 07:52 PM   #25
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I don't trust anything DSS makes after your failure. That was a huge oversight by a company that has "drive shaft" in their name.
Old 01-02-2023, 07:55 PM   #26
blsfrs
blsfrs's Avatar
Yes that was the initial thought at the time by everybody, but we all became less sure that it may have been the (only) factor when we removed the shaft.
I'm confident that it hasnt had a "big" rock strike in that particular area (and even the more exposed portion closer to the diff is in very good condition).
The area surrounding the failure is quite well protected.
However of course I cant rule out some sort of impact at some point.
I have refitted the alloy driveshaft that it replaced.
Alloy? Chrome moly or Al or ? 2 piece? At this point I'm a big fan of the stock drive shaft.
Old 01-03-2023, 02:18 AM   #27
churchx
churchx's Avatar
Drives: 2014 GT86
Wasn't stock 2-piece made such, so that to allow it to buckle in case of frontal crash impact, so that engine can be pushed under passenger compartment?
It's drawbacks .. i guess slight (but probably not that immense) play in extra joints, slightly more expensive .. and a bit heavier .. hmm .. i wonder if it's not worth to leave it as is, if it's designed/engineered for extra safety ..
Old 01-03-2023, 02:34 AM   #28
Yes. Also with all other properties being the same, shorter driveshaft will be able to spin faster without failing. I'm not a fan of any of these single-piece driveshafts. The only upside is a few kilos trimmed. Not worth it.
Driveshaft Shop 1-Piece Carbon Fiber Driveshaft Jordan Silveira Transmission and Driveline 4 04-07-2022 02:25 PM
SOLD Please Remove. (Dallas, TX) Driveshaft Shop Carbon Fiber 6MT Driveshaft Brzzee Transmission and Driveline 1 09-14-2018 09:22 AM
Driveshaft Shop Carbon Fiber Driveshaft (MT) $650 [SOLD] acj47 Transmission and Driveline 2 10-25-2017 05:07 PM
