| DIY (Do-It-Yourself) Guides For all DIYs. |
Drives: Don't yet have a Toyobaru
Anyone have a full list of socket/wrench sizes needed* for the 2nd Gen?
*Needed for maintenance and common mods, mostly - if the big ends use an odd size external torx, that's interesting, but it probably won't affect me. I'd search the service manual, but I haven't found it.
Thanks |
#2 |
ProCrastinationConsultant
i don't think there was ever a list for the 1st gen.
8mm, 10mm, 12mm, 14mm, and up for more serious tasks phillips screw drivers e-torx bits normally that covers the typical stuff. but all the sockets and every e-torx usually come in a set
#3 |
Thanks. Do you know the largest external hex?
#4 |
most everything that one would typically work on for fun or maintenance is covered with just the 8-14mm socket and phillips screwdrivers.
anything larger, or oddball like e-torx is stuff that they don't fully intend a typical person to get into. so it really just depends on how far down the rabbit hole you're going.
#5 |
Thanks - I wanted to check if external hex needs would be covered by a standard SAE/Metric set and it sounds like that's the case.
#6 |
Drives: 2020 toyota 86
A good torque wrench will be helpful.
#7 |
You mean I can't just eyeball the dyne-yards?
#8 |
i just go by ugga-dugga's.
#9 |
Drives: 2017 GT86 + 2005 C2VTS
#10 |
Drives: 2013 frs base
| The Following User Says Thank You to blsfrs For This Useful Post: | soundman98 (12-30-2022) |
#11 |
Wheels for Brains
You can be pretty sure that the car uses JIS Metric Standard for hardware (being a Japanese made car and all).
99% of things you do on the car, you will encounter the following:
Shit kinda hits the fan when you start adding aftermarket parts. Companies vary where they get their hardware from, so the socket sizes will differ from JIS (usually ISO or DIN), sometimes even including SAE! --------------- If you don't already have a toolkit, I recommend the Harbor Freight 301 pc Mechanic's set (especially right now that Harbor Freight has a 25% off any single item coupon!). It has practically everything on the above list and then some, with almost no missing pieces, and a bunch of other handy stuff to have. I bought one when I first started wrenching, and haven't needed to add much to it other than specialty and quality-of-life type tools. The single exception is that it's missing a 14mm combo wrench, but that's easy to add. Last edited by EndlessAzure; 12-31-2022 at 03:07 AM. |
| The Following 3 Users Say Thank You to EndlessAzure For This Useful Post: |
#12 |
Thanks for the detailed reply. I have a good socket set, but, like most, it tops out at 19mm, so I was curious what I might encounter outside of that range. Is there a practical difference between JIS Metric Standard fasteners and other metric standard fasteners? I presume the size difference in head is axial, meaning there's less material and a greater risk of rounding, for a given alloy? If so, good thing I have six-point sockets...
#13 | |
Wheels for Brains
The practical difference is that in the JIS standard, there is a specific table linking bolt diameter to both socket size and pitch. There are a few exceptions on the car proper, but generally you don't have to guess at a fastener.
https://www.boltdepot.com/fastener-i...ead-Pitch.aspx https://www.boltdepot.com/fastener-i...Head-Size.aspx |
| GR Cup car full modification list? | br33z | Tracking / Autocross / HPDE / Drifting | 2 | 11-16-2022 03:53 PM |
| So your bucket list is full... But.... | carbonBLUE | Off-Topic Lounge [WARNING: NO POLITICS] | 16 | 10-05-2015 08:59 PM |
| McGard wheel lock, wrench socket size | dssence | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 02-27-2014 02:09 PM |
| Socket set and torque wrench | Ty89m | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 10 | 07-29-2013 12:46 AM |
| Torque Wrench Needed For Exhaust Installs? | FR-S Matt | Engine, Exhaust, Transmission | 13 | 02-13-2013 01:40 PM |
