timurrrr
Old 12-27-2022, 01:32 AM   #1065
mycrors7
mycrors7's Avatar
Drives: zd8 brz
From what ive seen since this fiasco has started... we still dont have solid evidence that the oil pan rtv is the main cause of engine failure.
We can complain all we want, but Subaru(and Toyota) wont do anything until they have actual failed engines in their hands.. and not just a handful. These motors have to be blowing left and right... similar to the valve spring recall and it's whole situation of motors blowing left and right due to techs over-applying sealant on the timing chain cover.
that being said.. there are tons of brz/gr86 that have A LOT of miles with no issues on em.
someone posted their brz with 50k miles already and claims he hasnt had issues. im currently waiting to see if he ever got his car checked for RTV or not.
mycrors7 is offline   Reply With Quote
The Following User Says Thank You to mycrors7 For This Useful Post:
Tcoat (12-27-2022)
Old 12-27-2022, 01:37 AM   #1066
We know of very few that have actually failed.
It has been discussed over and over that the sealant in the pickup alone is not likely to be the issue.
Of the failures that we have details (about 8) all were on a track and at least 3 had records of overrev.
At this point it would appear to be much ado about nothing.
DriveDriftDogfight86 (12-27-2022), DylanJZA (01-05-2023), mycrors7 (12-27-2022), OND (05-24-2023), Rustyoid (12-28-2022), Spektyr (12-28-2022)
Old 12-27-2022, 01:41 AM   #1067
mycrors7
mycrors7's Avatar
Drives: zd8 brz
doesnt help that people were dropping their pans and cleaning out the rtv. sure they may have avoided a failed motor(with zero proof that cleaning it will avoid failure), but should this have been a big issue, those potentially failed motors would have helped convince Subaru to do something about this.
edit-
Just confirmed the guy with 50k miles on his BRZ has not opened up his oil pan and doesnt plan to.
he hasnt done any track days, but does drive on backroads often
Old 12-27-2022, 09:15 AM   #1068
Blighty
Drives: WR Blue Pearl 2022 Subaru BRZ
That is EXACTLY what you have said.
Nobody is defensive.
You are suggesting an action that is a total waste of time is all.
They do not care if your engine MAY die they only do if it DOES die and creates a safety issue. If that happens THEN call them. IF you live in the USA!
Dude.
Chill.
Blighty is offline   Reply With Quote
Old 12-27-2022, 10:24 AM   #1069
Tokay444
Originally Posted by OkieSnuffBox View Post
Nope. The only way a recall will happen is if engine failures from it become so prevalent that it becomes cheaper to recall 10k+ engines for a repair vs replacing the few engines that actually fail because of it.
Rule number one is we don't talk about fight club.
The Following User Says Thank You to Tokay444 For This Useful Post:
soundman98 (12-27-2022)
Old 12-27-2022, 01:55 PM   #1070
Arthur-A
Arthur-A's Avatar
Drives: 2020 BRZ/86, 2020 BMW 330i
All were using 0W20 oil I assume?
Arthur-A is offline   Reply With Quote
Old 12-27-2022, 05:24 PM   #1071
Originally Posted by Blighty View Post
Dude.
Chill.
Dude.
Make some sense.
OkieSnuffBox (12-31-2022), Spektyr (12-28-2022)
Old 12-27-2022, 05:55 PM   #1072
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The Following 7 Users Say Thank You to NoHaveMSG For This Useful Post:
Dzmitry (12-28-2022), norcalpb (12-27-2022), RippedManiac (01-02-2023), soundman98 (12-27-2022), Spektyr (12-28-2022), Ultramaroon (12-27-2022), villainous_frx (12-27-2022)
Old 12-27-2022, 08:18 PM   #1073
Blighty
Dude.
Make some sense.
Yep.
RTV poses no issue, the government auto safety body forms go to /dev/null, and we should all just understand that the auto manufacturers have our best interests at heart and will sort stuff out without factoring in its reputation or sales of its vehicles.
There, that better? Can I join your club now?
m|np
Old 12-27-2022, 08:34 PM   #1074
Yep.
m|np
I asked you to make sense, not for yet another misdirection, distortion, or otherwise generally sarcastic remark. It has been clearly and correctly explained to you not just that, but why following your call to action would be wasted effort. Please let it go.
NoHaveMSG (12-28-2022), villainous_frx (12-27-2022)
Old 12-28-2022, 12:19 AM   #1075
mycrors7
mycrors7's Avatar
Drives: zd8 brz
mixed from what i recall. some using 0w20. some using 5w30 as recommended by most track guys for track use
Old 12-28-2022, 01:50 AM   #1076
Arthur-A
Arthur-A's Avatar
Could be oil thinning out due to excessive temperature as well.
Old 12-28-2022, 08:53 AM   #1077
KillerBMotorsport
KillerBMotorsport's Avatar
From silicone in the pickup? Nah. Higher oil temps would only improve flow through a clog or partial clog, and any decent synthetic (even a 0w-20) is going to have proper lubrication at higher temps. Although, at some point if temps are excessive: 1) you'd see it on the OEM gauge, and 2) the ECU would likely start pulling power to keep things safe. Unlike the oil pressure switch, the oil temp switch does interact with the ECU.
KillerBMotorsport is offline   Reply With Quote
The Following User Says Thank You to KillerBMotorsport For This Useful Post:
Old 12-28-2022, 05:58 PM   #1078
new2subaru
Weight Weenie
Drives: 15 FR-S
They made a booboo with some of the production cars. This almost never happens...2013 anyone? People still drive them today without the recall.
Better than catching fire like some other brands
I'd be concerned if I bought one but I'd either unload it or keep it and beat on it. Either way, life goes on.
oh no not again
New stock GR86 '22 Dyno Runs: Twins packing more power than advertised!! steel86gt GR86 General Topics (2nd Gen 2022+ Toyota 86) 14 03-09-2022 02:15 AM
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 07:09 PM
Is my engine blown? dallenj Engine, Exhaust, Transmission 39 01-30-2017 05:18 PM
Blown engine due to 0W-20? Benschneider06 Engine, Exhaust, Transmission 45 07-23-2015 03:33 AM
Subaru BRZ complete engine gasket & seal kit 2.0L JPxM0Dz Engine, Exhaust, Transmission 0 12-18-2012 12:11 PM
