| Engine Swaps Discussion of engine swaps. |
#15 | |
Meow
Drives: GT86 (now sold)
#16 | |
Drives: 2013 GT86 fully standard
| The Following User Says Thank You to CedN For This Useful Post: | alex87f (12-25-2022) |
#17 | |
Drives: Crapcan
I really don't see this as being practical in a car for reasons you already stated. Vibration is going to be a key one. Maybe circle track guys could tolerate it, or builds that vibration isn't going to matter. I could see rock crawlers being all over this thing, I would have loved to have this as an option over the OM617 I went with in my Toyota. I think the 300/500 numbers they are talking is just without having to upgrade internals.
#18 |
Meow
What kind of Toyota do you have an OM617 in?
#19 |
Drives: '23 BRZ
Should make it a V4 instead of inline!
#20 |
ProCrastinationConsultant
.5/LS?
someone get the band saw!
| The Following User Says Thank You to soundman98 For This Useful Post: | NoHaveMSG (12-25-2022) |
#21 |
Drives: Crapcan
85’ 4Runner. Not finished yet. Sold it incomplete to a friend, I should have it done by June.
#22 |
Drives: Q5 + BRZ + M796
Kind of defeats the whole purpose of making a block compatible with existing LS heads. They aren’t trying to make a one-off engine, so while it would be cool to bend the FA24, bore and stroke it, lop off a set of valves, and relocate the camshaft to the block, I don’t think they will be making a high displacement V4.
If they were going to make a high displacement V4, and if they were building it off existing heads, then there are only a few options, and those options would be the EJ, FA and Porsche 718 engines, and they would be heavily stroked. Probably not going to happen.
#23 |
Stig's dark passenger
140lbs off the front with a proven platform…..would love to see something better
| The Following User Says Thank You to D K For This Useful Post: | venturaII (12-26-2022) |
#24 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Motus MV4 did the 100 cube V4 and there's a few kicking around.
Wasn't too successful though. Spec sheet link About the same specs as an FA20.
"I gotta rock." -- Charley Brown |
| The Following User Says Thank You to bcj For This Useful Post: | NoHaveMSG (12-26-2022) |
#25 | |
Only users lose drugs.
Drives: All the time
EDIT: my bad...the Motus appears to have a divorced transmission, given that there are two sets of specs for dimensions...one with and one without transmission.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
#26 | |
Drives: JRSC BRZ SOLD
What specs were about the same? It does make 100hp/l but at 1.6L its down 30hp and 30 tq. Super light tho. |
#27 | |
Why would they not use EJ heads at that point???
#28 |
