Old 12-24-2022, 05:57 AM   #15
alex87f
Meow
alex87f's Avatar
Drives: GT86 (now sold)
Originally Posted by CedN View Post
I like the work Frankenstein Motorworks have done with the Toyota 2ar four cylinder, seems cheaper and easier to make power than the k24. Though its not like you can buy swap parts of the shelf for whatever car you have.
Over here the engine with most after market is probably a Volvo B23 series engine, and other Volvo engines. They've been swapped into everything , and heaps of cheap parts available for high hp builds.
Though the B23 is a 4-pot, I've had dreams of putting a friend's T5 motor (B5254T7 according to wiki) in the 86. It would have everything: the smoothness, the noise, the torque, the potential .
alex87f is offline   Reply With Quote
Old 12-24-2022, 06:44 AM   #16
CedN
CedN's Avatar
Drives: 2013 GT86 fully standard
The 5s are also common nowdays in rwd configurations, adapter plates for different gearboxes(bmw for example), turbo manfolds etc are all of the shelf parts ready for swapping.
2013 GT86, fully standard daily and occasional track day car
CedN is offline   Reply With Quote
The Following User Says Thank You to CedN For This Useful Post:
alex87f (12-25-2022)
Old 12-24-2022, 05:20 PM   #17
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I saw the weight of the longblock, but I don’t know how it compares to alternative longblocks in terms of weight. I believe it is heavier than the K24, but maybe less than a VR6 or Q37. Exhaust for LS, K, 2JZ are off the shelf or already available for aftermarket swaps, which is one reason why people swap those three engines so much. Same with the intake manifold and other accessories such as AC. Want a lightweight or Fluidyne damper then it is available. Having done a swap, and having done one-off parts, the more that is available the better. If Blueprint takes care of everything then cool.
It's about the same as a K series.
I really don't see this as being practical in a car for reasons you already stated. Vibration is going to be a key one. Maybe circle track guys could tolerate it, or builds that vibration isn't going to matter. I could see rock crawlers being all over this thing, I would have loved to have this as an option over the OM617 I went with in my Toyota. I think the 300/500 numbers they are talking is just without having to upgrade internals.
Old 12-25-2022, 08:52 AM   #18
alex87f
Meow
alex87f's Avatar
What kind of Toyota do you have an OM617 in?
Old 12-25-2022, 12:27 PM   #19
ZDan
ZDan's Avatar
Drives: '23 BRZ
Should make it a V4 instead of inline!
Old 12-25-2022, 01:39 PM   #20
soundman98
ProCrastinationConsultant
soundman98's Avatar
.5/LS?
someone get the band saw!
NoHaveMSG (12-25-2022)
Old 12-25-2022, 02:59 PM   #21
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
85’ 4Runner. Not finished yet. Sold it incomplete to a friend, I should have it done by June.
Old 12-25-2022, 03:15 PM   #22
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Kind of defeats the whole purpose of making a block compatible with existing LS heads. They aren’t trying to make a one-off engine, so while it would be cool to bend the FA24, bore and stroke it, lop off a set of valves, and relocate the camshaft to the block, I don’t think they will be making a high displacement V4.
If they were going to make a high displacement V4, and if they were building it off existing heads, then there are only a few options, and those options would be the EJ, FA and Porsche 718 engines, and they would be heavily stroked. Probably not going to happen.
Old 12-25-2022, 11:41 PM   #23
D K
Stig's dark passenger
140lbs off the front with a proven platform…..would love to see something better
D K is offline   Reply With Quote
The Following User Says Thank You to D K For This Useful Post:
venturaII (12-26-2022)
Old 12-26-2022, 01:04 PM   #24
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Motus MV4 did the 100 cube V4 and there's a few kicking around.
Wasn't too successful though. Spec sheet link
About the same specs as an FA20.
NoHaveMSG (12-26-2022)
Old 12-26-2022, 02:18 PM   #25
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Except at 150 pounds, it's a fraction of the size and weight as the FA20, and that's including the transmission.
EDIT: my bad...the Motus appears to have a divorced transmission, given that there are two sets of specs for dimensions...one with and one without transmission.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
Old 12-26-2022, 09:03 PM   #26
PulsarBeeerz
Drives: JRSC BRZ SOLD
What specs were about the same? It does make 100hp/l but at 1.6L its down 30hp and 30 tq. Super light tho.
PulsarBeeerz is offline   Reply With Quote
Old 12-27-2022, 12:00 AM   #27
D K
Why would they not use EJ heads at that point???
Old 12-27-2022, 12:24 AM   #28
D K
This thing needs to get boosted…yesterday!
