Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 01-30-2022, 09:57 PM   #15
Shub Deetle
Large Member
Shub Deetle's Avatar
Drives: 2022 Subaru BRZ
My new BRZ shows a moving vertical bar (which grows wider as the temp climbs), with a temp readout below it. After about 15 minutes, it reads 90C. I have never seen it more than that, although I’m still breaking it in. It’s the first vehicle I’ve owned that shows oil temp. The water temp indicator is a single bar that moves left to right as temp increases.
I never drive hard for at least the first 15 minutes anyway - no matter the age or mileage of the vehicle. Maybe I’m old-school.
Shub Deetle is offline   Reply With Quote
Old 01-31-2022, 01:33 AM   #16
Midnightsky
Midnightsky's Avatar
Drives: 2022 BRZ WRB
This is a simple fix, cheap, effective.
More permanent options do exist as well, wired straight to your OBD2 port. I knew a guy who was tracking a Gen 3 Mazda3 and that's the route he went. He did a clean install and gained the readouts he was looking for. There is also a way to get it to display on your main screen but it's not necessarily a simple process thru android auto.
Midnightsky is offline   Reply With Quote
Old 01-31-2022, 01:44 AM   #17
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
That approach is decade+ old at this point.
On MY2018+ cars (or older with aftermarket head unit), you can project the screen on the head unit using Android Auto, like I do in this video:
I also have a bunch of customized gauges one swipe away.
The Following 2 Users Say Thank You to timurrrr For This Useful Post:
Midnightsky (01-31-2022), T-Steve (03-06-2022)
Old 01-31-2022, 02:00 AM   #18
Midnightsky
Forsure that's the best option, I just haven't found an app that has worked for me yet. Old method yes, but still effective. Would I take that to a track day? No probably not, I would be building a custom bracket or case ect for that with a better mounting location.
Old 03-11-2022, 10:59 PM   #19
Flarpswitch
Flarpswitch's Avatar
Drives: 2022 BRZ Ltd, 2025 Ascent
Look again at page 153 of the BRZ manual. I assume it can toggle between Fahrenheit and Celsius. I will verify this for myself when my 2022 arrives next week.
Flarpswitch is offline   Reply With Quote
Old 12-18-2022, 07:51 AM   #20
86zn6
Drives: White GTS then Black GTS
Can Subaru dealer use their software to enable the numeric oil temp display? I know they can deactivate the active noise from their software.
86zn6 is offline   Reply With Quote
Old 12-19-2022, 08:49 PM   #21
Blighty
Drives: WR Blue Pearl 2022 Subaru BRZ
With the BRZ you can see your tire pressures while in track mode, I don't think that's possible with the GR86? (a complaint from throttle house iirc)
Can you actually change the display once your in track mode at all in a GR86?
Blighty is offline   Reply With Quote
Old 12-19-2022, 08:55 PM   #22
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
No
Follow the build thread for my GR86!
The Following User Says Thank You to timurrrr For This Useful Post:
Blighty (12-20-2022)
Old 12-20-2022, 07:47 PM   #23
Blighty
No
Kinda strange by toyota. I know they have a neat little combo info window that they want to show, but I'm sure people would like to have the option to see other stuff.
I would really be down for someone to hack the display control on these cars now that's its all digital.
Old 12-20-2022, 07:54 PM   #24
OkieSnuffBox
Drives: '23 BRZ Limited
You don't have to be in track mode to see tire pressures on the BRZ. At least not on my '23.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
Old 12-21-2022, 09:32 AM   #25
Blighty
Both cars can see it in standard mode, only the BRZ lets you show that while in track mode apparently. The GR86 has a special fixed gauge.
Old 12-29-2022, 03:59 PM   #26
Mcgiiver
Drives: 2022 BRZ Premium, 2009 Toyota Tacom
Yeah, but even once it goes off the car isn't anywhere near warm enough to start beating on.
I used to watch the oil temp gauge in my 135 on the way to work. This is a turbo car where the oil cooler thermostat didn't open until 235. Normal city driving the oil was barely at 165 after 6 miles.
On the BRZ, the cold engine light shuts off very early,no where near normal operating temp. Then the oil temp requires at least 5 miles driving to reach 190.
Mcgiiver is offline   Reply With Quote
Old 12-29-2022, 04:02 PM   #27
Mcgiiver
Just found out that on a GR86 the only mode for the left segment of the display is the one that shows the lap timer. You can't scroll to check the tire pressures the same way you can on the 2022 BRZ
The lap timer requires manually "starting" each lap, so it isn't very useful IMO.
Well short of having a transducer installed, how does the car know when the lap begins. Its a simple one push of a button to save the lap time.
Old 12-29-2022, 11:28 PM   #28
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
That light is in reference to the coolant. It basically encourages you to baby it more while that light is on. Has no reference to the oil temperature. But in any case, as you said, it takes a good 10 minutes total or so to get the oil up to temp before you want to start ripping the car up.
Dzmitry is offline   Reply With Quote
Is there a difference between gauge clusters UDSM brz vs EU/AU brz? wutangbrz BRZ First-Gen (2012+) — General Topics 1 01-24-2019 07:21 AM
Modded Gauge Clusters CThomas Cosmetic Modification (Interior/Exterior/Lighting) 2 03-21-2015 09:45 PM
