Old 06-11-2021, 06:17 PM   #71
Razorlor
Drives: 2017 BRZ Limited, Perf Package
Originally Posted by kask2_6.0 View Post
It's a modified corvette intake. They are pretty expensive but keep an eye out on ebay and sometimes you can come across a used one at decent price that just needs cleaning. Picked that one up for $250.
https://www.knfilters.com/chevrolet/...l-v8-gas/2008/
Yeah, that's an awful lot for a piece of plastic. I'll keep an eye out, thanks.
Razorlor is offline   Reply With Quote
Old 07-31-2021, 06:50 PM   #72
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
Needed a new project... LS3 soon!
Finally got around to fitting the strut braces. Had to make brackets to offset the firewall side of the oem braces up about 1” to clear the coils. With different coil mounting locations this wouldn’t have been an issue. May switch this up in the future.
kask2_6.0 is offline   Reply With Quote
The Following 2 Users Say Thank You to kask2_6.0 For This Useful Post:
ILLSMOQ (08-01-2021), Irace86.2.0 (06-29-2022)
Old 08-01-2021, 03:13 PM   #73
ILLSMOQ
Drives: 2017 WR BLUE BRZ
I’ve been wanting to put those strut braces back in as well. I think it just makes good sense to have them in place.
You came up with a great idea here. I’ll be doing the same thing.
Thanks!
ILLSMOQ is offline   Reply With Quote
Old 10-01-2021, 12:31 AM   #74
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
I just got the strut bars, brackets, throttle body, etc back from powder coating. Difference is subtle but it’s looking great with everything matching now! Also, swapped out the fuel rails and added a pulse damper to my distribution block. Just need to do something about that dipstick handle now..
The Following User Says Thank You to kask2_6.0 For This Useful Post:
Old 12-11-2022, 09:26 PM   #75
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
I guess I haven’t updated this thread in a long time. No major changes in the past year but still making some improvements here and there. Bought a 3D scanner so I’ve been playing with that a bit. Pretty awesome to be able to make parts accurately fit hard to measure spaces straight from CAD.
Irace86.2.0 (12-12-2022), TRS (12-13-2022)
Old 12-11-2022, 09:56 PM   #76
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
Also just made some brackets to bias the coils toward the front of the engine to allow for strut bar clearance. With the stock valve covers and new brackets the braces can fit without the adapters I made previously. Initial test fit is looking good. Using Katech TA2 plug wires. And the new color probably adds at least 30 hp.
The Following 5 Users Say Thank You to kask2_6.0 For This Useful Post:
gt5759 (12-12-2022), Irace86.2.0 (12-12-2022), pope (12-12-2022), RedReplicant (12-11-2022), TRS (12-13-2022)
Old 12-13-2022, 02:55 PM   #77
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
Toying with the idea of making these new hood vents to further improve cooling by using a larger opening and taller wicker/fin profile. Plus they might look kinda cool and different from what everyone else has. Some design limitations in trying to cover the existing holes but I think this look would work. Thoughts?
This was a little too square so I changed the leading edge angle to match the body line more.
With angled corners.
Old 12-13-2022, 04:11 PM   #78
TRS
TRS's Avatar
Drives: 2013' Toyota 86 (EU spec)
Nice one! I like your intake and radiator duct. Similar to my solution, but you obviously can make use of a little more freedom due to the non factory crash beam. Unfortunately thats something I cant do over here in Germany.
May I ask which 3d Scanner and software you are using? Is it able to generate a solid from the scan?
Concerning hood vents: Im using a hood similar to the Seibon TS Style combined with a similar radiator duct and Made good expierience with that. Only drifting especially with A/C in is still limited. Besides that it's working great. But I learned that massive oil cooling is needed in addition and also I will swap my Koyo Radiator for a more advanced unit. I hope to be able to drift the car with A/C on one day without Heat issues. We'll see...
TRS is offline   Reply With Quote
The Following User Says Thank You to TRS For This Useful Post:
kask2_6.0 (12-13-2022)
Old 12-13-2022, 04:46 PM   #79
all4spl
I'm working on a design that encompasses a HUGE increase in coolant capacity and retains hood latch. It does require a different crash beam though to keep AC condenser. You can either move the condenser or notch the crash beam slightly for it all to fit.
all4spl is offline   Reply With Quote
The Following User Says Thank You to all4spl For This Useful Post:
Old 12-13-2022, 10:03 PM   #80
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
I'm using the EinScan HX scanner and Geomagic Essentials for post processing. It doesn't generate a solid but you do get a nice point cloud. Using Geomagic I can then add planes, axis, cylinders, etc. to features I'm interested in. Then export as a surface or 3D image. Then with Solidworks I can use the features I mapped for mates mates and measurements and use the surface or image as more of visual references. Still learning the most efficient way to use this process but getting better at it.
I haven't had the car back on track yet since finishing the swap so I don't really know if the additional venting is required or not. But still doesn't hurt to try and improve the cooling as much as possible with a big engine in a small engine bay. My biggest hope is that it further drops under hood temps at low speeds. I've made some PDM logic changes to turn my radiator fans on at 15% speed any time I reduce speed below 10mph and coolant is above 180 to keep some air moving through there at least. I really need to get proper head shield on the headers like what you have on your car. The header wrap is more of a band aid for now.
Old 12-14-2022, 03:45 AM   #81
TRS
TRS's Avatar
Sounds great! Unfortunately crash beam modifications are a nogo for a German street car. Though, there are some guys and even companys arround here doing some modifications anyway. But I dont wanna be that guy. Driving arround in a car thats highly modified in any case is kind of gamble in Germany, even If everything is approved. Cops are allowed to
challange any approval at will and seize the car for a review of the approvals.
Since there are also some guys arround in Germany which doesnt respect any rules of common sense and behave like idiots in the middle of the city, cops are sensitive for modified cars of any kind. Rules concerning charging someone for speeding are pretty strict, the cops are only able to do so If they have a proper measurement. Also the fines are not that high, even If they where raised multiple times druing the last years. The result is that they tend to use the modifications instead to get people of the road. Unfortunately the rules in that segment are that strikt, that even approvals which seem 100% correct can be rejected after review.
So BTT, sorry for offtopic.
Thanks for the Info about the 3d Scanner, I'll have a look on this model.
Concerning the hood vents: Believe me, you want to have them on a LS swapped car. Definately.
I also modified the switch on temps and speeds of the fans in a similar manor. But the ground speed Im switching on is even higher.
Again, oil cooling is crucial. Ive been through several oil cooler versions and increased size and airflow in multiple steps. I learned that better oil cooling had a big Impact to coolant temps, even If the oil temps itself didnt lower that much. Currently Im using the biggest version of the Setrab Slimline coolers (14rows, 592mm wide). Since also this didnt lower oil temps as far as I want to see it, I'll now add a second oil cooler of a similar size aß a final measure.
Old 01-14-2023, 10:22 PM   #82
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
The Following 3 Users Say Thank You to kask2_6.0 For This Useful Post:
Irace86.2.0 (01-15-2023), TRS (01-19-2023), x808drifter (01-15-2023)
Old 05-25-2023, 11:44 AM   #83
ballsdeep
ballsdeep's Avatar
Drives: Ocho-Seis
Awesome build!
Finished up the PDM wiring this weekend. PDM is controlling the radiator fans, motec ECU, coils, lambda controllers, and reverse lockout solenoid. Some sensors, gps module, and dash control buttons wired into it as well. It’s also taking data from two can buses. On the CAN1 bus I have the Motec and the factory Subaru bus. On CAN2 I have the two AEM lambda controllers and MSEL battery relay. Will be adding the Aim RIO02 module to that bus too when it’s finally released.
Been studying up on CAN bus and hope to learn from your setup. The A17 and D43 junction connections were used for your CAN1 and CAN2? Are the devices on CAN2 wired as a new main bus line from D43's 9 & 20 (lambda controllers as stubs, battery relay at the end), with a single terminating resistor?
ballsdeep is offline   Reply With Quote
Old 05-25-2023, 04:37 PM   #84
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
Originally Posted by ballsdeep View Post
Awesome build!
With the PDM CAN1 and CAN2 are completely different busses. On the CAN1 bus I am sharing the Motec and OEM signals. Luckily their CAN ID's don't have any overlap so it works out just fine. I tapped into the OEM bus at a junction behind the glovebox. Can't remember it's name off the top of my head but I believe that would be the D43 junction you are referring to. But from what I can tell in the wiring diagram the OBDII port is directly connected to the main bus without a buffer to block signals. You could potentially just connect directly to the port with the mating connector and save some hassle.
I have mine setup so that CAN2 is completely independent of anything that already existed on the vehicle. I have it reading all additional CAN based sensors and the keypad. On this bus I can send and receive any signals without any real worry of interfering with something on the main bus. Things like the AEM lambda controllers have fixed CAN ID's and formats so not all aftermarket CAN connections will play nice with the OEM bus (overlapping signal ID's). That is why I have them separated. That being said anything I read from CAN2 I can create my own ID and resend it to CAN1 with the ID, units, and scaling the Motec would expect, which is what I am doing for lambda and oil pressure signals.
My CAN bus knowledge is limited but from my experience it's best to minimize any additional signals sent on an existing critical bus if you can. Reading is one thing but sending signals can cause some unexpected problems. What hardware are you planning to add? @geraldjust should be able to answer any CAN bus specific questions much better than I can.
ballsdeep (05-25-2023)
What is needed for Aluma007 Engine, Exhaust, Transmission 9 11-25-2018 03:20 PM
Electric Power Steering Adjustment Project - Help Needed brillo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 12-07-2015 08:34 PM
Logged Track Time Datasets Needed for my Web Project! :) Zamyatin Scion FR-S / Toyota 86 GT86 General Forum 7 02-11-2015 02:59 PM
HELP NEEDED!!!! sklimo Issues | Warranty | Recalls / TSB 26 06-14-2013 12:48 PM
MOD's Needed. Help Please! GT-ROKIN Cosmetic Modification (Interior/Exterior/Lighting) 17 10-06-2012 02:18 AM
