Drives: 2014 FRS, JRSC, Catless
Help - 2014 FRS Rough Idle and Cylinder 4 Misfire
Hi All,
I'm trying to diagnose a problem with my car. From my log I'm getting very rough idle after startup, high misfires on cylinder 4, and shows injection mode 1. When I rev and hold the engine at 2000 rpm, then 3000rpm, then 4000rpm it moves to injection mode 3 and there are no misfires. After idling back down it again misfires in mode 1 and is smooth in mode 2. Does this mean that my port injector in cylinder 4 is bad or clogged? Here's a link to the data log. https://datazap.me/u/frs2slow/frs-ro...0&data=7-18-32 |
#2 |
Pulled and cleaned the injector, but still have the problem. I recently also replaced the coil packs and spark plugs as well. Thoughts?
#3 |
ProCrastinationConsultant
what coil packs and spark plugs did you use?
#4 |
Off the line racing coil packs (and adapter harness). Denso 3536 iridium plugs.
#5 |
were the spark plugs purchased locally or online?
if locally, i suspect the coil packs/adapter harness. if online, i suspect fraudulent plugs.
#6 |
Thanks soundman. The spark plugs were purchased from local major brand auto store. I pulled the OTLR coil pack and put the oem coil pack back on. Idling well now with no misfires in the logs. I'm going to take her out for a spin and see if all stays well. If so, looks like I got a failed OTLR coil pack and/or harness.
#7 |
yeah, unless you're heavily modded/tuned, keep the ignition system oem. aftermarket doesn't play nice without supporting stuff
| 2013 FR-S Misfire and Rough Idle | aemravan | Issues | Warranty | Recalls / TSB | 98 | 12-12-2024 02:59 PM |
| Cylinder 1 Misfire Under Throttle | Butterballz | Issues | Warranty | Recalls / TSB | 26 | 09-12-2022 01:03 PM |
| HELP P0354 Cylinder 4 Misfire | isaiah990 | Issues | Warranty | Recalls / TSB | 17 | 12-28-2019 11:38 PM |
| ECU replaced. Still has slight misfire, rough idle | xomp | Issues | Warranty | Recalls / TSB | 1 | 11-01-2012 09:53 AM |
