Old 11-26-2022, 09:57 PM   #1
FRS2SLOW
Drives: 2014 FRS, JRSC, Catless
Help - 2014 FRS Rough Idle and Cylinder 4 Misfire
Hi All,
I'm trying to diagnose a problem with my car. From my log I'm getting very rough idle after startup, high misfires on cylinder 4, and shows injection mode 1.
When I rev and hold the engine at 2000 rpm, then 3000rpm, then 4000rpm it moves to injection mode 3 and there are no misfires. After idling back down it again misfires in mode 1 and is smooth in mode 2.
Does this mean that my port injector in cylinder 4 is bad or clogged? Here's a link to the data log.
https://datazap.me/u/frs2slow/frs-ro...0&data=7-18-32
FRS2SLOW is offline   Reply With Quote
Old 11-27-2022, 04:07 AM   #2
FRS2SLOW
Pulled and cleaned the injector, but still have the problem. I recently also replaced the coil packs and spark plugs as well. Thoughts?
Old 11-27-2022, 10:52 AM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
what coil packs and spark plugs did you use?
Old 11-27-2022, 01:57 PM   #4
FRS2SLOW
Off the line racing coil packs (and adapter harness). Denso 3536 iridium plugs.
Old 11-27-2022, 03:29 PM   #5
soundman98
soundman98's Avatar
were the spark plugs purchased locally or online?
if locally, i suspect the coil packs/adapter harness.
if online, i suspect fraudulent plugs.
Old 11-27-2022, 06:29 PM   #6
FRS2SLOW
Thanks soundman. The spark plugs were purchased from local major brand auto store. I pulled the OTLR coil pack and put the oem coil pack back on. Idling well now with no misfires in the logs. I'm going to take her out for a spin and see if all stays well. If so, looks like I got a failed OTLR coil pack and/or harness.
Old 11-27-2022, 06:57 PM   #7
soundman98
soundman98's Avatar
yeah, unless you're heavily modded/tuned, keep the ignition system oem. aftermarket doesn't play nice without supporting stuff
2013 FR-S Misfire and Rough Idle aemravan Issues | Warranty | Recalls / TSB 98 12-12-2024 02:59 PM
Cylinder 1 Misfire Under Throttle Butterballz Issues | Warranty | Recalls / TSB 26 09-12-2022 01:03 PM
HELP P0354 Cylinder 4 Misfire isaiah990 Issues | Warranty | Recalls / TSB 17 12-28-2019 11:38 PM
ECU replaced. Still has slight misfire, rough idle xomp Issues | Warranty | Recalls / TSB 1 11-01-2012 09:53 AM
