| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
What differential gears are out there?
I've been doing some reading and it's a bit confusing.
I have a 2014 MT. I *think* that means I have 4.10 gears. Are all the pre 2017 MT and AT cars the same 4.10? And is it 2017+ that goes to 4.3? For AT and MT? I need something different. Quite frankly, I dont care which way, as I'm currently bouncing off the rev limiter about 150ft before brake points at half the turns. So a little bit taller would be fine, or a good bit shorter. I'm willing to bet the extra shift with shorter gears will offset the the extra gearing from a shorter ratio, so I doubt there's much performance either way. Thanks!
2014 BRZ: WRL Build (GP2) MCS, AP, Motec, race wiring harness, blah blah blah
2014 FRS: Similar WRL Build. Back up / parts / practice race car. 2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc. 1999 NB Spec Miata: 1.8 w/ all the goodies. 2022 CT5 Blackwing: Stock. |
#2 |
Drives: 22 BRZ limited
The early models 4.1. The refresh MT went to 4.3.
The 2022+ are AT 3.9 MT 4.1. Who knows what future models will do. Last edited by dragoontwo; 11-22-2022 at 10:04 AM. |
#3 |
Drives: Crapcan
4.3 was only in the 17 and up MT
#4 |
Off to the track!
Drives: '14 Lava 86, '13 WRB BRZ
Several companies make 4.556 final drives as well, such as Cusco.
#5 |
Drives: Crapcan
There is also a 4.44 from Mfactory.
Jack's Transmissions has a good chart for reference showing MPH/RPM. OE 4.3 is not on there though. https://www.jackstransmissions.com/b...ar-ratio-chart
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | villainous_frx (11-21-2022) |
#6 | |
Drives: '23 BRZ
#7 | |
AutoX-10/10ths every run
The AT never came with a 3.9 final drive.
#8 |
| The Following User Says Thank You to dragoontwo For This Useful Post: | whataboutbob (11-22-2022) |
#9 | |
In about 3 weeks, I'm having a new motor and trans put in, and I suspect the LSD is toast. At this point, it's kind of silly not to throw in a new rear. If I wasn't replacing everything, I'd stick with the 45 series tire, but I'd rather just get the gearing right and then go the correct sidewall tire. The higher sidewall also raises the car about half an inch. Not good for anything, especially front end grip with the splitter.
#10 |
Did anything ever come with a 3.90? That would be perfect.
The 4.10 will mean an extra shift. It's fine, but I doubt I'll make up any time since the extra shift at the very end will cancel out the gearing advantage. It just means more shifting and more wear and tear on the weak point (transmissions). IDK, there is a turn or two where a little more torque would help me rotate. It just doesn't have enough to rotate on some higher speed uphill stuff. If steeper is my only choice, it's my only choice.
#11 | |
#12 |
Also, any reason to get an aftermarket cover with extra fluid capacity? It's stockish power levels (intake, headers, exhaust, tune). I guess a drain bolt would be nice.
is there a better fluid to use than OEM?
#13 | |
#14 | |
Drives: Crapcan
![]() You can always just do what I am doing, 4.3 diff, stiffer valve springs, 8K rev limit. YOLO ![]() Out of the 4 tracks in my area the 4.3 is better at 2, the 4.1 is better at 2.
| Review soon:OS Giken Super Lock Limited Slip Differential + Greddy differential cover | mav1178 | Engine, Exhaust, Transmission | 5 | 02-11-2021 02:20 PM |
| Any one have 5.29 gears yet ? | ogie Oglethorpe | Engine, Exhaust, Transmission | 13 | 09-17-2016 12:17 PM |
| What are the Factory differential gears worth? | Fastbrz | BRZ First-Gen (2012+) — General Topics | 3 | 02-20-2015 04:46 PM |
| Anybody change rear gears or trans gears yet? | ramosryan | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 06-13-2014 01:48 AM |
| 2nd gears a b*tch | Carbon420 | Scion FR-S / Toyota 86 GT86 General Forum | 32 | 01-29-2013 06:09 PM |
