Old 11-21-2022, 02:03 PM   #1
GrandSport
GrandSport's Avatar
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
What differential gears are out there?
I've been doing some reading and it's a bit confusing.
I have a 2014 MT. I *think* that means I have 4.10 gears.
Are all the pre 2017 MT and AT cars the same 4.10?
And is it 2017+ that goes to 4.3? For AT and MT?
I need something different. Quite frankly, I dont care which way, as I'm currently bouncing off the rev limiter about 150ft before brake points at half the turns. So a little bit taller would be fine, or a good bit shorter. I'm willing to bet the extra shift with shorter gears will offset the the extra gearing from a shorter ratio, so I doubt there's much performance either way.
Thanks!
2014 BRZ: WRL Build (GP2) MCS, AP, Motec, race wiring harness, blah blah blah
2014 FRS: Similar WRL Build. Back up / parts / practice race car.
2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc.
1999 NB Spec Miata: 1.8 w/ all the goodies.
2022 CT5 Blackwing: Stock.
GrandSport is offline   Reply With Quote
Old 11-21-2022, 02:21 PM   #2
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
The early models 4.1. The refresh MT went to 4.3.
The 2022+ are AT 3.9 MT 4.1. Who knows what future models will do.
Old 11-21-2022, 03:12 PM   #3
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
4.3 was only in the 17 and up MT
Old 11-21-2022, 09:04 PM   #4
villainous_frx
Off to the track!
villainous_frx's Avatar
Drives: '14 Lava 86, '13 WRB BRZ
Several companies make 4.556 final drives as well, such as Cusco.
villainous_frx is offline   Reply With Quote
Old 11-21-2022, 09:09 PM   #5
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
There is also a 4.44 from Mfactory.
Jack's Transmissions has a good chart for reference showing MPH/RPM. OE 4.3 is not on there though.
https://www.jackstransmissions.com/b...ar-ratio-chart
villainous_frx (11-21-2022)
Old 11-22-2022, 08:38 AM   #6
ZDan
ZDan's Avatar
Drives: '23 BRZ
What size tires you on? If on 245/40-17, you might try 235/45-17. Not a huge change, would be like going from 4.1 to 3.97. Small step in the right direction anyway, made a noticeable difference for me at NHMS South Oval last year where I was in same situation as you for both before T1 into the oval, and also before T3. Running reverse stagger 245/40-17 fronts with 235/45-17 rears was a big improvement! This year I was on 245s all around and believe it was costing me a few tenths to half a second
Old 11-22-2022, 08:56 AM   #7
whataboutbob
AutoX-10/10ths every run
Originally Posted by dragoontwo View Post
The early AT was 3.9 with MT being 4.1. The refresh bumped AT to 4.1 and MT to 4.3.
The 2022+ are back to the early numbers. AT 3.9 MT 4.1. Who knows what future models will do.
The AT never came with a 3.9 final drive.
Build thread:Here
Old 11-22-2022, 09:03 AM   #8
dragoontwo
dragoontwo's Avatar
Oops.
The Following User Says Thank You to dragoontwo For This Useful Post:
whataboutbob (11-22-2022)
Old 11-23-2022, 11:32 AM   #9
GrandSport
GrandSport's Avatar
Funny you say that. That's exactly how I "solved" the problem. I bumped up to 245/45 and it fixed the problem with the horribly "timing" of the gears.
In about 3 weeks, I'm having a new motor and trans put in, and I suspect the LSD is toast. At this point, it's kind of silly not to throw in a new rear.
If I wasn't replacing everything, I'd stick with the 45 series tire, but I'd rather just get the gearing right and then go the correct sidewall tire. The higher sidewall also raises the car about half an inch. Not good for anything, especially front end grip with the splitter.
Old 11-23-2022, 11:35 AM   #10
GrandSport
GrandSport's Avatar
Did anything ever come with a 3.90? That would be perfect.
The 4.10 will mean an extra shift. It's fine, but I doubt I'll make up any time since the extra shift at the very end will cancel out the gearing advantage. It just means more shifting and more wear and tear on the weak point (transmissions).
IDK, there is a turn or two where a little more torque would help me rotate. It just doesn't have enough to rotate on some higher speed uphill stuff. If steeper is my only choice, it's my only choice.
Old 11-23-2022, 11:43 AM   #11
dragoontwo
dragoontwo's Avatar
The 22+ AT has it right now. https://www.caranddriver.com/subaru/...ubaru-brz_2022
Old 11-23-2022, 11:46 AM   #12
GrandSport
GrandSport's Avatar
Also, any reason to get an aftermarket cover with extra fluid capacity? It's stockish power levels (intake, headers, exhaust, tune). I guess a drain bolt would be nice.
is there a better fluid to use than OEM?
Old 11-23-2022, 11:47 AM   #13
GrandSport
GrandSport's Avatar
Got it. I'll keep my eyes out for one, but I'll prob not find a 22 on ebay very easily if it's only AT 22s. I can just get it and swap it later if one comes around
Old 11-23-2022, 11:52 AM   #14
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The stock torsen LSD doesn't really have anything to wear out outside an normal open diff. There are just a bunch of little gears in there.
You can always just do what I am doing, 4.3 diff, stiffer valve springs, 8K rev limit. YOLO
Out of the 4 tracks in my area the 4.3 is better at 2, the 4.1 is better at 2.
Review soon:OS Giken Super Lock Limited Slip Differential + Greddy differential cover mav1178 Engine, Exhaust, Transmission 5 02-11-2021 01:20 PM
Any one have 5.29 gears yet ? ogie Oglethorpe Engine, Exhaust, Transmission 13 09-17-2016 11:17 AM
What are the Factory differential gears worth? Fastbrz BRZ First-Gen (2012+) — General Topics 3 02-20-2015 03:46 PM
Anybody change rear gears or trans gears yet? ramosryan Scion FR-S / Toyota 86 GT86 General Forum 2 06-13-2014 12:48 AM
2nd gears a b*tch Carbon420 Scion FR-S / Toyota 86 GT86 General Forum 32 01-29-2013 05:09 PM
