Old 10-26-2022, 09:03 AM   #337
fancymalard
fancymalard's Avatar
Drives: 2013 Scion FRS
TWS T66-F 18x8.5 +42
Looks like it clears.
fancymalard is offline   Reply With Quote
Old 10-26-2022, 02:38 PM   #338
Jo0
Drives: '17 CWP Limited w/ PP
Originally Posted by bubsterboo View Post
Does anyone know if the stock 2022 gr86 BRZ wheels clear the brembos on the older BRZ?
Would love to know this too. Not just for my BRZ, but I'd love to snag those for my 04 Forester XT where I know I'm going to get the brembos eventually
Jo0 is offline   Reply With Quote
Old 10-26-2022, 02:53 PM   #339
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
Yes, the wheels will fit. However the brakes are not a direct bolt us as far as I know. If you're looking to plop some 2022 wheels on a first gen PP, they should bolt right on.
Picture source:
https://www.ft86club.com/forums/show....php?p=3489094
cmiovino is offline   Reply With Quote
Old 11-02-2022, 03:59 AM   #340
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
2022 GR86 Base (17" wheels) with PP Brembos installed.
From the owner: "No spacer used. It fits and is probably OK for street. Too tight for track."
Follow the build thread for my GR86!
The Following User Says Thank You to timurrrr For This Useful Post:
RedReplicant (04-03-2023)
Old 11-02-2022, 04:12 AM   #341
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
I just checked and the top post in this thread has over 150 entries, that's incredible!
When I was starting, the largest list I've seen was ~10x smaller...
Thanks everyone for your contributions, and please keep them coming!
The Following 2 Users Say Thank You to timurrrr For This Useful Post:
Espi (11-02-2022), Tatsu333 (11-02-2022)
Old 11-02-2022, 12:45 PM   #342
APEX Race Parts
FT86Club Official Vendor
APEX Race Parts's Avatar
Drives: Launch-Year Whiteout FR-S
You can add all of the new APEX VS-5RS forged fitments to the list.
17x8.5" ET44
17x9" ET35
17x9" ET48
17x9.5" ET40
APEX Race Parts is offline   Reply With Quote
The Following User Says Thank You to APEX Race Parts For This Useful Post:
Old 11-02-2022, 09:20 PM   #343
PikachuBRZ
waiting on yellow gas
PikachuBRZ's Avatar
Drives: 2017 BRZ Series.Yellow #247
17x8.5" ET44
17x9" ET35
17x9" ET48
17x9.5" ET40
do you get any chassis/body rubbing with the 17x9 and 17x9.5?
PikachuBRZ is offline   Reply With Quote
Old 11-03-2022, 02:28 PM   #344
APEX Race Parts
Assuming we are talking about a first gen 86/BRZ, both the 17x9" ET35 and 17x9.5" ET40 fitments we offer can be used and choosing between them really comes down to how you are enjoying the car (street vs. track), tire size/model you plan to run, and how much sidewall support you want.
The 17x9" ET35 is certainly the easier fitment between the two, as it really just requires a little negative camber to prevent any rubbing (camber spec is determined by ride height, tire size/model). This fitment also offers quite a bit more inner clearance to the suspension, which means it clears the PP/TRD Sachs struts and a wide variety of aftermarket coilovers without the need for spacers. This fitment also has no problem clearing the front tire rods at full lock.
The 17x9.5" ET40 is really engineered for more hardcore track enthusiasts that want to maximize tire sidewall support for wider compounds. The fitment requires more attention to detail, but yields fantastic results with the proper supporting mods. More aggressive camber specifications are going to be required to prevent rubbing the fenders under suspension compression, but with track oriented wide wheel & tire fitments like this it is always still possible to scrub the inner plastic fender liners. This wider fitment will sit ~11mm closer to the suspension in comparison to the 17x9" ET35, so aftermarket coilovers with a slim silhouette are a requirement. Furthermore, the wheel can make contact with your front tie rods at full lock.
- Ryan
SuperTom (08-30-2025)
Old 11-06-2022, 07:50 PM   #345
lapsio
lapsio's Avatar
Drives: 2020 BRZ Final Edition, 1999 MX5 NB
ROTA Grid 8x17 et42 5x100 Matt Bronze. 225/45r17 tires.
lapsio is offline   Reply With Quote
Old 11-15-2022, 07:48 PM   #346
AndMsc
Drives: MY2018 GT86 EU
Hello,
Do WedsSport TC105X 17x8.5 +43 clear PP calipers?
Thank you
AndMsc is offline   Reply With Quote
Old 11-19-2022, 08:02 PM   #347
Wangspeed
Wangspeed's Avatar
Drives: 2022 BRZ
Enkei TFR 17x9 +45 with 12mm spacer. This is with Brembo BM4, which is much wider than a PP caliper. You can probably run with a much smaller spacer, like 5mm, but it would be very sunk in.
Wangspeed is offline   Reply With Quote
Old 11-24-2022, 07:36 PM   #348
cicada
cicada's Avatar
Drives: 2018 Subaru BRZ with Perf Package
Hello! Long time lurker here. Here is my first contribution:
Sparco Podio 18x8 +45 with 235/40/18 clears the Brembos and OEM perf package struts. Plenty of clearance
cicada is offline   Reply With Quote
The Following 3 Users Say Thank You to cicada For This Useful Post:
Busybee (01-13-2023), Dzmitry (11-29-2022), NaturallyAspirated (04-03-2023)
Old 01-05-2023, 07:55 PM   #349
N_Raged
Drives: 2019 BRZ Sport-Tech RS
Does anyone know if the base 17x7.0 ET48 factory wheels clear the Brembos if we use a spacer?
N_Raged is offline   Reply With Quote
Old 01-11-2023, 02:39 PM   #350
Drafter
Drives: 2017 Brz
Anyone know if the new Koenig Heliograms will fit over our Brembos?
Drafter is offline   Reply With Quote
brz, performance package, wheels
Finding wheels to clear brembos jojosbrz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 11-13-2018 09:46 AM
Performance package Brembos Ernest72 Want-To-Buy Requests 2 07-14-2018 09:06 AM
Performance Package Brembos Freezing to Wheels? texastwurkt3am Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 02-23-2018 09:31 AM
What pads fit the Performance Package Brembos? mistople Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 01-03-2018 06:15 PM
