Old 10-31-2022, 12:47 AM   #1
Chezboat24
Click Here
What Oil Are You Running in Serious Cold?
I'm talking in the -40 range because it's fairly common here. Diagram in the owners manual only goes to -20F/-30C. I've run 0W20 the entire time as recommended but I feel like this is an exception.
Before there's an potential confusion, -40 is the same in C and F.
Chezboat24 is offline   Reply With Quote
Old 10-31-2022, 09:39 AM   #2
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Seeing as you can't go lower that 0W and AFAIK and can find multi grade oils are tested to -40 degrees. Why is this even a thread?
Serious question.
The Following 3 Users Say Thank You to x808drifter For This Useful Post:
DarkPira7e (10-31-2022), The Red One (10-31-2022), Tokay444 (12-14-2022)
Old 10-31-2022, 09:43 AM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Like I'm sure many people on here, I've had 0w-20 in my car and driven it at -20f without issue multiple times.
Old 10-31-2022, 10:06 AM   #4
Where do you live that -40 is "common"?
Are you using windchill temperatures? Windchill does not impact your oil viscosity so just use the actual temperature.
The 0W20 is fine for the temperatures anyplace in populated Canada. In fact we used 0W20 in the military vehicles in Alert where the temperatures are pushing -50 most of the winter. Mind you at that extreme hardly anything else worked properly anyway so oil was the least of the problems.
humfrz (11-29-2022), Overdrive (01-06-2023), SCFD (12-14-2022), soundman98 (10-31-2022), The Red One (10-31-2022), x808drifter (11-01-2022)
Old 10-31-2022, 10:43 AM   #5
The Red One
Pro Couch surfer
The Red One's Avatar
Drives: 2019 BRZ Sport-tech RS.City car:GD3
For the few very cold days to assist in a fast warm-up have you considered a block heater?
https://www.subarupartspros.com/part...ck-heater.html
I used to option my new cars with a block heater but have not needed to in the past 20 years. Reasoning when I will really need it there would be nothing to plug it in(winter camping anyone?) A good strong battery is more important when it gets that cold.
The Red One is offline   Reply With Quote
The Following 3 Users Say Thank You to The Red One For This Useful Post:
soundman98 (10-31-2022), Tcoat (10-31-2022), x808drifter (11-01-2022)
Old 10-31-2022, 12:31 PM   #6
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Some oils have shown to flow better at colder temperatures. Pennzoil Ultra platinum and amsoil signature are two I'm aware of that Excell in -40.
Project farm on YouTube did an oil analysis on a bunch of different brands and those two came out on top.
Old 10-31-2022, 02:44 PM   #7
Chezboat24
Click Here
There are frequently one-to-two week periods south of Calgary that get well in to the deep -30 range without windchill. There are stretches where I’ll be cold starting it without a block heater, though it’ll work most of the winter. I just use the Toyota stuff so wondered if there was any better oil. It seems to be answered later on down the thread so it’s all sorted.
The Following 2 Users Say Thank You to Chezboat24 For This Useful Post:
Old 10-31-2022, 02:47 PM   #8
Chezboat24
Click Here
Project farm did an oil analysis on a bunch of different brands and those two came out on top.
Thank you. Apparently, based on the responses, I didn’t word the initial post properly because this is the exact answer I’m looking for.
Old 11-01-2022, 12:03 AM   #9
Chezboat24
Click Here
Car already has a block heater. Won't be able to use it sometimes (nowhere to plug in at work). I've run cars at that temp before without a block heater but they're either bigger trucks with monstrous batteries or small Honda's that would literally start at 0 Kelvin.
Old 11-01-2022, 12:08 AM   #10
Chezboat24
Click Here
Serious question.
Was following the owners manual. If range only went down to -20, I was wondering if there was some other factor affecting the car's ability to run below that, potentially beyond just oil viscosity. No worries.
The Following User Says Thank You to Chezboat24 For This Useful Post:
Old 11-01-2022, 12:29 AM   #11
DrinkenBRZ
Drives: 10 RX-8 Spt, 20 BRZ Ltd, 21 Rubicon
You could try a 0w16 or 0w8 for those stints. You’d see very slightly better cold flow due to less polymer doping to make the viscosity index spread with minimal engine wear increase, if at all. But, as others have said 0w20 should suffice, especially after 1600km or so when it’s sheared from fuel dilution and mechanical shearing when it’s probably closer to 0w16 anyway.
DrinkenBRZ is offline   Reply With Quote
Old 11-01-2022, 07:02 AM   #12
Spairo
Drives: 2013 FR-S 6 spd in Halo
If it were me, I would use 0w-uHaul to move my butt someplace warmer.
Sent from my SM-G950U using Tapatalk
Spairo is offline   Reply With Quote
The Following 2 Users Say Thank You to Spairo For This Useful Post:
finch1750 (01-04-2023), humfrz (11-29-2022)
Old 11-01-2022, 10:52 AM   #13
Chezboat24
Click Here
Give it a few months and I may be moving somewhere colder haha
Old 11-01-2022, 08:29 PM   #14
soundman98
ProCrastinationConsultant
soundman98's Avatar
i'm sure he'd be ok with you donating the first $1,000 to his gofundme.
Cold cold(under 30dg) start sounds super weird vladniko86 Engine, Exhaust, Transmission 9 11-19-2020 09:08 PM
BREATHE IN THAT COLD AIR! AMAZING DEALS ON COLD AIR INTAKES AT EAST END RACESHOP! eastendraceshop Engine, Exhaust, Bolt-Ons 50 09-24-2019 06:45 PM
Running but going nowhere. VictorKassil Issues | Warranty | Recalls / TSB 60 02-04-2015 07:18 PM
How cold is too cold to seal and wax? Jertronic Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 11-01-2013 11:20 AM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 05:05 PM
