| GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
#967 |
Drives: 1996 Turbo Miata
| The Following 4 Users Say Thank You to Robertw For This Useful Post: |
#968 |
Drives: 2022 BRZ sport-tech
Good datapoint for sure but just want to note that pressure drop does not equate to added engine/bearing wear. This was heavily debated for the need for an oil cooler for tracked FA20 during high oil temp use. Lots of great UOA from these “low oil pressure FA20” survives to this day after being pounded at the track.
In addition, pressure difference can be a result of different oil brand, new/old oil, new/oil filter. Still too many variables.
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ Current: 22 BRZ, 00 S2K - #0220 |
#969 | |
#970 |
There is a wide range of actual weights even if it's labeled 0-20. And used oil wear (sheering) hence it's normal for new oil to have higher viscosity thus higher pressures.
#971 |
and discuss...
#972 |
Interesting design. I guess it snaps onto the existing pick up to give it a larger filter area. It's like an extension/steroid to the redesigned pick up. lol
What kind of plastic is this made from? Can it handle the high heat? What kind of testing was done on this?
#973 |
Drives: 2015 FR-S
Is it possible to have the strainer closer to the drain port in case you need to suction/scrap off some RTV without removing the pan in the future.
also do we need a strainer at all? wouldn't the oil pump just chew up any RTV into little bitty pieces that should easily pass through the main oil passage into the oil filter. If you big metal pieces that you need the strainer for then you're kinda already screwed no? |
#974 | |
Drives: Crapcan
Thermoset plastics will burn before they melt. As long as it is stable for use in oil should be no worries. Likely nylon, sample looks 3d printed.
#975 | ||||
These pumps don't cavitate, at least not up to 10K RPMs. Aeration typically happens when the pump is bigger than the lubrication system is designed for... Like putting an oversized pump on a stock (or built to stock specs) block. That only pushes more oil through the bypass valve, eventually aerating. |
| The Following 5 Users Say Thank You to KillerBMotorsport For This Useful Post: | DarkSunrise (10-11-2022), Dzmitry (10-12-2022), NoHaveMSG (10-11-2022), Petah78 (10-11-2022), Stonehorsw (10-12-2022) |
#976 | |
Drives: Crapcan
#977 |
Drives: 2016 WRX
Kevin Vo's video he posted today on the FTspeed channel, on the partial engine tare-down has some good visuals on the excess RTV in other parts of the engine, like the timing cover and valve covers. It makes me think that dropping the pan to redo the RTV might be a bit pointless considering how much excess RTV is on the other larger surfaces.
#978 |
Drives: 2022 BRZ
Is the oil level always above the top of the strainer? What happens if the oil level drops below the top? I assume nothing good. This design seems like it would be a lot more resistant to RTV clogging, but maybe more prone to issues with low oil levels or high g's and sloshing? Or maybe not, not my area of expertise.
#979 |
It should be.
This pre-filter doesn't change how the pickup works at all, regardless of level. In theory, the holes should reduce the probability of funneling (which is how starvation starts when the level drops really low) and reduce the likelihood of starvation under severe cornering loads. |
#980 | |
Drives: 2022 BRZ
| Tags |
| oh no not again |
| New stock GR86 '22 Dyno Runs: Twins packing more power than advertised!! | steel86gt | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 14 | 03-09-2022 02:15 AM |
| Driver's side window seal/door seal | KAB-FRS | Issues | Warranty | Recalls / TSB | 255 | 01-01-2021 07:09 PM |
| Is my engine blown? | dallenj | Engine, Exhaust, Transmission | 39 | 01-30-2017 05:18 PM |
| Blown engine due to 0W-20? | Benschneider06 | Engine, Exhaust, Transmission | 45 | 07-23-2015 03:33 AM |
| Subaru BRZ complete engine gasket & seal kit 2.0L | JPxM0Dz | Engine, Exhaust, Transmission | 0 | 12-18-2012 12:11 PM |
