timurrrr
Old 10-10-2022, 09:42 AM   #967
Robertw
Robertw's Avatar
Drives: 1996 Turbo Miata
Robertw is offline   Reply With Quote
The Following 4 Users Say Thank You to Robertw For This Useful Post:
DocWalt (10-10-2022), racingfool (10-11-2022), Stonehorsw (10-10-2022), Wally86 (10-12-2022)
Old 10-10-2022, 10:47 AM   #968
Petah78
Drives: 2022 BRZ sport-tech
Originally Posted by Robertw View Post
Good datapoint for sure but just want to note that pressure drop does not equate to added engine/bearing wear. This was heavily debated for the need for an oil cooler for tracked FA20 during high oil temp use. Lots of great UOA from these “low oil pressure FA20” survives to this day after being pounded at the track.
In addition, pressure difference can be a result of different oil brand, new/old oil, new/oil filter. Still too many variables.
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ
Current: 22 BRZ, 00 S2K - #0220
Petah78 is offline   Reply With Quote
The Following 4 Users Say Thank You to Petah78 For This Useful Post:
Chrisz5z (10-10-2022), Rainy (10-11-2022), Tcoat (10-10-2022), timurrrr (10-18-2022)
Old 10-11-2022, 11:47 AM   #969
Robertw
Robertw's Avatar
I believe in the comments I read 0w-20 and factory filters were used.
Old 10-11-2022, 12:14 PM   #970
Petah78
There is a wide range of actual weights even if it's labeled 0-20. And used oil wear (sheering) hence it's normal for new oil to have higher viscosity thus higher pressures.
Old 10-11-2022, 02:46 PM   #971
KillerBMotorsport
KillerBMotorsport's Avatar
and discuss...
KillerBMotorsport is offline   Reply With Quote
The Following 4 Users Say Thank You to KillerBMotorsport For This Useful Post:
gcmak (10-12-2022), Petah78 (10-11-2022), timurrrr (10-18-2022), Wally86 (10-12-2022)
Old 10-11-2022, 03:11 PM   #972
Petah78
Originally Posted by KillerBMotorsport View Post
and discuss...
Interesting design. I guess it snaps onto the existing pick up to give it a larger filter area. It's like an extension/steroid to the redesigned pick up. lol
What kind of plastic is this made from? Can it handle the high heat? What kind of testing was done on this?
Old 10-11-2022, 03:22 PM   #973
FrickingReallySlow
Drives: 2015 FR-S
Is it possible to have the strainer closer to the drain port in case you need to suction/scrap off some RTV without removing the pan in the future.
also do we need a strainer at all? wouldn't the oil pump just chew up any RTV into little bitty pieces that should easily pass through the main oil passage into the oil filter. If you big metal pieces that you need the strainer for then you're kinda already screwed no?
and discuss...
FrickingReallySlow is offline   Reply With Quote
Old 10-11-2022, 03:22 PM   #974
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I have the same pressure drop at RPM. I suspect it could be the the pressure transducer placement though others have commented on it and suspected pump cavitation on the FA before.
Thermoset plastics will burn before they melt. As long as it is stable for use in oil should be no worries. Likely nylon, sample looks 3d printed.
Old 10-11-2022, 05:34 PM   #975
KillerBMotorsport
The open area of the holes is larger than the OEM pickup's mesh, but chunks of RTV as shown in this thread will definitely be stopped by this pre-filter. Tough to see, but the external surface is also not flat (OEM is flat), so when the engine stops chunks can more easily fall away than on a flat surface vs stick to it. And being all external, much easier to clean than using a borescope, mirrors, and picks. There is also a LOT more open area on this pre-filter, so it would take a lot more RTV stuck to it before it will have any significant effect on flow.
Auto/Oil rated grade of Nylon. We've used them a lot from AOS', water pump inlets, and oil pans. The newer printing materials and process capabilities have come a long way. I never would have dreamed of bolting on printed plastic parts for real world testing 25 years ago!
There is an internal filter in the OEM pickup that can clog with debris. Large pieces never make it to the pump/filter.
AVCS. IIRC it's ~5K RPMs (under load/WOT) where the cams transition. The oil feed that supplies AVCS draws more oil, and the system pressure drops some. All Subaru AVCS engines do this: EJ20/25, FA20/24. The only time pressure climbs fairly linear with RPM is when AVCS is deleted.
These pumps don't cavitate, at least not up to 10K RPMs. Aeration typically happens when the pump is bigger than the lubrication system is designed for... Like putting an oversized pump on a stock (or built to stock specs) block. That only pushes more oil through the bypass valve, eventually aerating.
The Following 5 Users Say Thank You to KillerBMotorsport For This Useful Post:
DarkSunrise (10-11-2022), Dzmitry (10-12-2022), NoHaveMSG (10-11-2022), Petah78 (10-11-2022), Stonehorsw (10-12-2022)
Old 10-11-2022, 07:14 PM   #976
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Ahhh, that makes total sense. Mine seems to do it about 5800 but my AVCS tables are a bit different.
Old 10-11-2022, 07:51 PM   #977
whiplash willy
Drives: 2016 WRX
Kevin Vo's video he posted today on the FTspeed channel, on the partial engine tare-down has some good visuals on the excess RTV in other parts of the engine, like the timing cover and valve covers. It makes me think that dropping the pan to redo the RTV might be a bit pointless considering how much excess RTV is on the other larger surfaces.
whiplash willy is offline   Reply With Quote
Old 10-11-2022, 08:06 PM   #978
mpg9999
Drives: 2022 BRZ
and discuss...
Is the oil level always above the top of the strainer? What happens if the oil level drops below the top? I assume nothing good. This design seems like it would be a lot more resistant to RTV clogging, but maybe more prone to issues with low oil levels or high g's and sloshing? Or maybe not, not my area of expertise.
mpg9999 is offline   Reply With Quote
Old 10-11-2022, 08:36 PM   #979
KillerBMotorsport
It should be.
This pre-filter doesn't change how the pickup works at all, regardless of level.
In theory, the holes should reduce the probability of funneling (which is how starvation starts when the level drops really low) and reduce the likelihood of starvation under severe cornering loads.
Old 10-11-2022, 08:42 PM   #980
mpg9999
Drives: 2022 BRZ
It should be.
Wait, does the pickup extend down into the area behind the strainer? It looks like it does and I missed that the first time looking at it. You can really only see it in the second picture. If the pickup itself extends down inside the strained area then disregard my concerns.
oh no not again
New stock GR86 '22 Dyno Runs: Twins packing more power than advertised!! steel86gt GR86 General Topics (2nd Gen 2022+ Toyota 86) 14 03-09-2022 02:15 AM
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 07:09 PM
Is my engine blown? dallenj Engine, Exhaust, Transmission 39 01-30-2017 05:18 PM
Blown engine due to 0W-20? Benschneider06 Engine, Exhaust, Transmission 45 07-23-2015 03:33 AM
Subaru BRZ complete engine gasket & seal kit 2.0L JPxM0Dz Engine, Exhaust, Transmission 0 12-18-2012 12:11 PM
