Old 10-03-2022, 04:15 PM   #1
M0nk3y
Fatigue Failure JDL FP/OP Combo. Anyone else?
For the record, I have an email out to JDL as of this morning and they haven't had a chance to respond. Not in any way is this post a reflection against them.
With that being said - this past weekend at Mid-Ohio after I loaded my car on the trailer, I noticed an exhaust-leak sound coming from mid-body of the car.
Of course, after I got home, car cooled down upon start-up the exhaust definitely was leaking. Took a look and this is what I found:
At first I thought it was a curb hit or something, but based on the cracking and the extent of the cracking this isn't a 1 time thing, so it seems. The exhaust has had some time on the car. Since 2017 it's seen about 30k miles of various DDing, AutoX and Track Events
Anyone else have any issues with exhaust failing in similar fashion/form?
Kyle H. - #89 STX
Old 10-03-2022, 04:50 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Pretty sure Jesse offers a lifetime warranty on his stuff anyway.
I don't have the exhaust connected to the transmission because I was curious if this would happen. Probably a fluke, you're covered in either case.
Teseo (10-03-2022)
Old 10-03-2022, 04:58 PM   #3
e1_griego
e1_griego's Avatar
Drives: Many
What motor mounts? Any flex section in the exhaust?
e1_griego is online now   Reply With Quote
Old 10-03-2022, 05:00 PM   #4
Teseo
Drives: frs
Damn... the pipe went down before the welds.
Old 10-03-2022, 05:24 PM   #5
M0nk3y
STi Motor Mounts, stock transmission mount.
The rear exhaust session is a 2.5” Perrin, after the bolted flange connection there is a flex gasket right there
Kyle H. - #89 STX
The Following User Says Thank You to M0nk3y For This Useful Post:
e1_griego (10-03-2022)
Old 10-03-2022, 05:25 PM   #6
alphasaur
friendly
Drives: 17' 86
Seems like more of an issue with the metalurgy, maybe just a bad batch
Pretty sure @Tokay444 does metalurgy stuff
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
The Following User Says Thank You to alphasaur For This Useful Post:
Wally86 (10-05-2022)
Old 10-03-2022, 05:30 PM   #7
e1_griego
e1_griego's Avatar
Drives: Many
I figured that's what you had.
Just making sure!
The cat in my JDL ultra quiet front pipe exploded a couple years back before a Tour. I figure it's just the cost of doing business.
Old 10-03-2022, 06:02 PM   #8
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I am not a big fan of welding a bracket like that perpendicular to the direction of force. Especially one that small. It just increases the chance of a fatigue failure like what you see here and the crack continues to propagate. Even with a flat bracket, you can bend it and weld it along the same direction of force to give it more area to take the stress.
Kind of like this even though this is a round hanger. Or if you are going to do it like that anyway something larger to at least give it a chance. That is a pretty small bracket.
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
DarkPira7e (10-03-2022), soundman98 (10-03-2022), Ultramaroon (10-05-2022)
Old 10-04-2022, 04:15 AM   #9
Lucky21
vroooooooom
Lucky21's Avatar
Drives: 86
Had a similar failure a few months ago though this was just a fabricated fp/op. Just had another one made.
Lucky21 is offline   Reply With Quote
Old 10-04-2022, 07:48 AM   #10
KillerBMotorsport
KillerBMotorsport's Avatar
^ this is exactly why it failed.
Brackets like that should be boxed with multiple attachment points, L-shaped, or have a reinforcing saddle on the tube.
KillerBMotorsport is offline   Reply With Quote
The Following 2 Users Say Thank You to KillerBMotorsport For This Useful Post:
DarkPira7e (10-04-2022), NoHaveMSG (10-04-2022)
Old 10-04-2022, 03:51 PM   #11
M0nk3y
Jesse has already replied to me, he's going to replace that section of the pipe with a new reinforced bracket.
JDL is amazing as always
Kyle H. - #89 STX
The Following 4 Users Say Thank You to M0nk3y For This Useful Post:
DarkPira7e (10-04-2022), NoHaveMSG (10-04-2022), RToyo86 (10-04-2022), Teseo (10-05-2022)
Old 10-05-2022, 07:48 AM   #12
Tokay444
If the weld isn’t the strongest part, it’s a bad weld.
The Following User Says Thank You to Tokay444 For This Useful Post:
x808drifter (10-06-2022)
Coilover decision fatigue - would love a recommendation jkamelo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 38 01-04-2021 04:48 PM
Rocker Arm Failure Worstenemy453 Issues | Warranty | Recalls / TSB 65 10-12-2019 09:50 AM
Engine failure! mackeye Engine, Exhaust, Transmission 24 01-30-2018 12:48 AM
CV Joint Failure and Differential Failure AreteAuto Issues | Warranty | Recalls / TSB 26 06-16-2015 06:18 PM
Headlight Failure FRSNewb Issues | Warranty | Recalls / TSB 9 06-04-2015 10:39 PM
