Old 10-02-2022, 12:15 PM   #29
gpvecchi
gpvecchi's Avatar
Originally Posted by Favato View Post
I did read your comment and I appreciate, however I tried to search further info on that and could not find anything, also `probably` won`t work for me in terms of deciding what to do next.
Going to concentrate on my other projects and eventually either fit something, try to fix the hole or buy a new headliner.
Thanks for the support
Correct, I`m from Tasmania, I dare to say I can count the 86s with my hands in the whole state ha, probably no sub-forums
http://autogarage110.blog114.fc2.com...entry-386.html
They just cut the liner in another place.
The only way to fix it, as they said, is to replace or re-cover the hood liner. Or buy a useless ETC to put there. ETC=Electronic Toll Control.
Will this work for you? My "probably" was referred to the fact I don't know if your car is Japanese import car.
The Following User Says Thank You to gpvecchi For This Useful Post:
Favato (10-09-2022)
Old 10-02-2022, 12:31 PM   #30
soundman98
ProCrastinationConsultant
soundman98's Avatar
Thank you for the time and patience. I`m guessing this was fitted around 2014, reason? No idea. The tray doesn`t have any locking mechanism, unless the previous owner kept whatever there glued/velcro. And even if it was some boost controller, just seems very odd the location, I can only guess but I think he used to track this car, if anything useful could be used there, out of my knowledge. Also the install was 5/10, therefore I don`t think it came like that from factory nor specialised accessory fitting places, if that makes sense
There's small 'ridges' around the inside perimeter of the enclosure indicate whatever went there was a friction fit inside the enclosure. That would indicate it was intended to be removed, but also wasn't anticipated to be removed often beyond the initial install.
Second thought was a track transponder/lap counter, but all the one's I'm finding are more square than rectangular like that.
Favato (10-09-2022)
key fob, interior dome light not working superlords2 Scion FR-S / Toyota 86 GT86 General Forum 4 03-26-2022 10:07 PM
interior dome light danielremjativa Cosmetic Modification (Interior/Exterior/Lighting) 15 07-21-2016 01:52 PM
Interior Dome Light Issues Mongo Issues | Warranty | Recalls / TSB 3 03-19-2014 05:52 PM
Interior LED Dome Light Diffuser | DIY | 6X Brighter Dezoris Cosmetic Modification (Interior/Exterior/Lighting) 8 04-21-2013 09:59 PM
