timurrrr
Old 09-22-2022, 08:09 PM   #799
Originally Posted by KillerBMotorsport View Post
FSome call it a regulator, some call it a bypass. It's the same thing.
It does not open at 140psi.
Here's a plot showing oil pressure. Where the ramp rates change is where the bypass just cracks open and starts regulating. I would call it 75psi... which coincidentally, it right in line with 95% of the other oil pumps Subaru uses. The reason pressure keeps climbing after the bypass opens is because flow is increasing, further compressing the bypass spring, requiring more pressure to keep it open enough for the additional flow. Eventually what can happen is the bypass will aerate (if you have too big of a pump and an engine not made for it, for example), because flow out the bypass is horribly turbulent. Think of water coming out of a hose with your thumb covering the end. If you run too big of a pump AND shim it to increase pressure, then that inner rotor usually lives a short and violent life.
Flow is linear with RPM through the rotors (assuming constant temp and no AVCS). The bypass valve regulates the pressure and flow actually going into the engine.
I've read here that shimming the spring makes no difference. Also, with your mode of operation, especially considering the flow rate of the pump, it should compensate for viscosity (temp). It doesn't seem to.
Old 09-22-2022, 09:20 PM   #800
Petah78
Drives: 2022 BRZ sport-tech
^ correct. 2 gal/min is not a lot.
Sorry to be a noob but i am trying to understand. Are you suggesting that the dimensions of the pickup tube is limited oil flow of 2gal/min? Meaning that is the max that the engine is getting regardless how hard the oil is pumping? But if it's partially blocked, wouldn't that metric, 2gal/min be even lower?
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ
Current: 22 BRZ, 00 S2K - #0220
Petah78 is offline   Reply With Quote
Old 09-23-2022, 07:37 AM   #801
_____That_-_GUY_____
Drives: 2022 GR86
When the pump is at max PSI, it's only pushing 2 GPM through the engine, so that is all the pick up tube needs to pull from the oil pan. The tube with a partially blocked screen could most likely flow a lot more than that if it needed to, but the engine doesn't need more than that
_____That_-_GUY_____ is offline   Reply With Quote
The Following User Says Thank You to _____That_-_GUY_____ For This Useful Post:
Petah78 (09-23-2022)
Old 09-23-2022, 08:22 AM   #802
KillerBMotorsport
KillerBMotorsport's Avatar
A shim doesn't do much. If you over-shim, it can actually cause pressure to be excessive and split the inner pump gear. I've heard of shims also causing premature bypass valve spring fatigue (from over compression). IMO, a shim is not beneficial beyond marginal.
Subaru oil pump are unusual in the car world in that they have WAY more flow than is necessary 95% of the time. There are V8 engines that don't have nearly as much oil flow capacity as a Suby pump. They've always been this way, and yet, they have (by design) poor rod bearing oiling and marginal main oiling
Here's a plot comparing the same pump with 2 shims added...
Don't apologize, we've all been there!
No, not at all. From our testing the pickup is very little of a restriction when you look at the system as a whole. Can you pick up a couple psi and small % of flow by installing a performance high flow version, sure you can. Anytime you reduce a restriction on a pump's inlet, it becomes more efficient.
The systems flow limitations is really down to the engine's lubrication design: engine's clearances, and other things like AVCS, oil feed, etc... Those are all restrictive. The best way to improve oiling system performance is not by shimming or adding a bigger pump, it's rebuilding the engine with making modifications to the oiling system to improve its performance. One of the things we learned for example, is ALL engines (new used or otherwise) get a line bore (not a line hone). Once true, we actually close the main clearances below factory spec at ~.0007 +/-.0001. This smaller main clearance forces more oil to the rod bearings (the weak link). We've done this for stock engines running 0w20 to 760whp running 20w-60. We always run stock unshimmed pumps regardless or redline RPM or power level and have not had an oiling related failure in at least 10 years.
KillerBMotorsport is offline   Reply With Quote
The Following 7 Users Say Thank You to KillerBMotorsport For This Useful Post:
bcj (09-23-2022), JusTheG (09-29-2022), Petah78 (09-23-2022), PulsarBeeerz (09-27-2022), Tokay444 (09-23-2022), Ultramaroon (09-23-2022), Wally86 (09-27-2022)
Old 09-23-2022, 09:50 AM   #803
Petah78
That is some great explanation. The more I read/learn about this RTV/oiling issue, the more I think it's an overblown issue. Not ideal but also not a show stopper. Thanks again.
Old 09-27-2022, 01:07 PM   #804
BioRebel
Drives: Mini Cooper S
From the sounds of all this, it looks like this is only going to impact a small subset of cars. (ones with enough of a clogging issue and while they're being driven at the limit)
Honestly my only concern at this point is if this happens to me after the warranty expires.
BioRebel is offline   Reply With Quote
Old 09-27-2022, 02:17 PM   #805
Dake
Dake's Avatar
And this should be a concern because for those that don't track it or otherwise drive aggressively, it could just take longer to see the internal damage manifest at which point it might be too late.
Dake is offline   Reply With Quote
Old 09-27-2022, 02:30 PM   #806
Or more likely they will never see any damage at all because they never hit that combination of factors to cause the perfect storm for it to happen.
Notice that the reports dropped off after the bulk of the cars got some miles on them?
Dake (09-27-2022), JusTheG (09-29-2022), justinco (09-27-2022), Petah78 (09-27-2022), Rustyoid (09-27-2022), siko232 (10-02-2022)
Old 09-27-2022, 02:42 PM   #807
Petah78
Just keep monitoring your used oil via UOA to check the health of the engine and if everything is normal during the first 5 years, just drop the pan to clean out after warranty expires. If UOA indicates higher than normal wear, you can decide what to do then.
And some additional info, pretty sure he is a member on here.
And some additional info that i came across, though cannot be verified as fact or BS.
Old 09-27-2022, 03:20 PM   #808
The oil samples are great if it is a gradual thing but pretty sure that all the ones reported were sudden and catastrophic. Oil stopped flowing to that one bearing and within minutes it was toast. No oil test in the world would forecast that scenario.
Dake (09-27-2022), OkieSnuffBox (09-27-2022), Ultramaroon (09-27-2022)
Old 09-27-2022, 04:31 PM   #809
Petah78
How did you conclude on that?
Old 09-27-2022, 05:46 PM   #810
The info that we have got right now says:
All happened with prior zero indication of a problem at a very low mileage.
All the reports that gave details have said a single bearing went out.
All oil samples from engines with no problems have come up good.
Unless we get differing data the trend is glaring.
OkieSnuffBox (09-27-2022), Petah78 (09-27-2022)
Old 09-27-2022, 07:26 PM   #811
Petah78
I concur with all your stated facts. But what are possible warning signs for a spun rod bearing? All the reports of failure that i have seen are for a single rod BUT i have also not seen other bearings from the same engine (maybe i missed this?). My theory is that this can be a sudden or a gradual death, and in the event of a gradual problem, UOA will pick it up.
The Following User Says Thank You to Petah78 For This Useful Post:
Tcoat (09-27-2022)
Old 09-27-2022, 07:53 PM   #812
Agree there is a lack of info on other bearings since most find the one and "OK there is the problem we are done here" but there have been enough saying just the one that I am comfortable in making the statement.
If there was even one oil analysis that said "we have concerns" I may also change my outlook but there just isn't.
Failure mode and risk analysis of industrial processes are what I have done for 30 years and I will say that with what we have I am about 75% confident that these failures are sudden. I would be happy to change that level (up or down) with a nice big data set but I don't think we are going to get much more info than we already have. Really the only new data I expect is if the mileages go up and there are still multiple failures but at this point they seem to have stopped. Or at least no longer get reported!
JusTheG (09-29-2022), Petah78 (09-27-2022)
oh no not again
New stock GR86 '22 Dyno Runs: Twins packing more power than advertised!! steel86gt GR86 General Topics (2nd Gen 2022+ Toyota 86) 14 03-09-2022 02:15 AM
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 07:09 PM
Is my engine blown? dallenj Engine, Exhaust, Transmission 39 01-30-2017 05:18 PM
Blown engine due to 0W-20? Benschneider06 Engine, Exhaust, Transmission 45 07-23-2015 03:33 AM
Subaru BRZ complete engine gasket & seal kit 2.0L JPxM0Dz Engine, Exhaust, Transmission 0 12-18-2012 12:11 PM
