#1303 | |
Drives: Subaru BRZ 2017
I will say that my 0 to 60 is around 4.6 which I must say it's quite impressive when there is no clutch dumping or any sort of launch control.. |
#1304 |
#1305 |
A realistic reference guide for people, using an internationally respected tuner.
The latest power run on E85 at around 15c on a Dynapack. 65mm pulley, built motor (etc), ACE headers, no cat, custom 2.75 single exhaust, 4.66 diff, on a Motec. (motor with about 10,000km hard use) 418.85 Nm @ 5035 rpm 374.27 hp (279 KW) @ 7000 rpm Its always about the torque
| The Following 2 Users Say Thank You to grumpysnapper For This Useful Post: | FunnyGopher (07-05-2022), Irace86.2.0 (07-05-2022) |
#1306 |
Drives: Q5 + BRZ + M796
Looks almost identical to my turbo K24 at 10psi E85 with one cat and 2.5” exhaust. I’m interested to see what Harrop will do on the FA24. I think this is their smallest pulley, so I would expect mid to high 400’s with the FA24. Should be a rocket with all that instant torque.
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | grumpysnapper (07-05-2022) |
#1307 | |
But then he taught me a lesson in humility when he overlaid some Nissan GTR dyno runs he did the day before, with some light mods (nothing internal) and a still fairly conservative tune...over 1000 Nm at under 3k rpm...and docile enough for your mum to drive to the shops. Last edited by grumpysnapper; 07-05-2022 at 05:59 AM. |
#1308 |
#1309 |
Drives: None
Dynojet with NASA classing settings
#1310 |
still pretty good nonetheless..
Mine running e70 with 85mm pulley can only garner 280/220 tuned and dyno-ed on Mustang dynanometer with ambient temp at around 100. so maybe that's the problem - the temp? well, kinda underwhelming..but it does pull though.. so idk I might go dyno it again around this time now that the temp has fallen. It's a +17 AT though. |
#1311 | |
Drives: None
When I dyno'd the car it was in the 60s ambient and the following things that might affect power: ACE A350 header Catless ACE front pipe 2.75" Catback OSGiken clutch/fw Jack's built stock 6spd transmission 255/35/18 Nankang AR1 tires If you want a more apples to apples comparison you could take the car to most any Dynojet shop and hand them this: https://nasa-assets.s3.amazonaws.com...m--3-14-22.pdf That'll let you compare numbers fairly closely to anyone else who was dyno'd on the same setup. There is also compliance database with the dyno data for everyone that competes with NASA to browse through if you want to go bench racing too. https://airtable.com/shrtuIZcugofvmC...gWtC3AQ0QAJPI0
#1312 |
Steve Bodalenko
Drives: Toyota 86 GTS
Slightly off subject given the last couple of pages, but interested in what plugs people are using in their Harrop fitted cars. Specifically when running e85 70 to 80% of the time. OEM of aftermarket? Considering changing mine @ 44k kms and some recent misfires at 2k rpm when under hard acceleration, sluggishness off the mark, and rough start up and idling. I know it sound like a dirty MAF or vacuum leak but I might as well do the entire job properly.
Harrop, with 85mm pulley, been on car for 2 years now and still best bang for buck I’ve spent. In case anyone was thinking of going that route. As a side question, is anyone else apart from me running the dual Radium catch can setup? Any issues re vacuum leaks associated for the fitment. Harrop in Melbourne, AU installed my kit and apparently connecting the Radium’s had them scratching their heads for a while before working it out. Seems to work as designed and I get very little, 1mm, oil every six months due to blow by. Last edited by Bodalenko; 10-07-2022 at 06:52 PM. |
#1313 | |
Just used the recommended OEM plugs, and they are fine. I use the dual Radium kit too, and I have always gotten significant oil from the (right hand side tank) PCV valve , but almost nothing from the other (left side tank) crank case breather side.... regardless of the pulley sizes I have fitted. |
| The Following User Says Thank You to grumpysnapper For This Useful Post: | Bodalenko (10-08-2022) |
#1314 | |
Steve Bodalenko
Nothing of note in my Radium’s though the cars done very little work or k’s, 2000kms, since install due to covid. |
#1315 | |
Changing the plugs is frustrating/annoying etc, but not the end of the world. Make sure you buy a thin walled, magnetic, long, and flexible ended 14mm socket. Take the time remove as much crap that is in the way as possible. And buy a small piece of plastic tubing that you can slip over the plugs end cap to help guide it into place. And if you do the hard side first, the next bank seems like a doddle! |
#1316 | |
Drives: 2015 BRZ Limited
For removal, slide a magnetic spark plug socket down the hole by itself. Slide a short 3" extension in after it, but don't let them fully engage each other. The extension should be slightly sticking out of the hole. Attach a socket wrench and loosen the spark plug. I prefer to use the socket wrench to just crack it loose and then take it off and loosen by hand, but either works. Once the spark plug is fully loosened, take off the socket wrench and pull out the extension. Use a short magnetic stick to pull the socket out. The spark plug should stay in the socket since it's magnetic. For installing a spark plug, slide a spark plug down the hole by itself first, and then follow all the steps for removing, obviously tightening the spark plug instead of loosening it. ![]() I was dumbfounded how quick I completed the last set using this method after struggling for hours the first few times. Removing all the stuff just to reach the spark plugs takes the majority of the time. Good luck!
Harrop Supercharger | Delicious Tuning Flex Fuel Kit | ACE Type-A 350 Header + OP | CSG Touring 86 Catback | RacerX Fabrication Catch Can | Jackson Racing Dual Radiator/Oil Cooler | Tuned by Zach from CSG
| JDL turbo kit owners thread | yomny | Forced Induction | 1352 | 01-08-2025 04:20 AM |
| HKS Supercharger owners thread | wbradley | Forced Induction | 1054 | 10-26-2024 01:18 PM |
| P&L Turbo kit Owners thread | Hawaiian | Forced Induction | 73 | 07-07-2018 02:31 AM |
| Harrop car lip kit? | djdnz | Cosmetic Modification (Interior/Exterior/Lighting) | 15 | 12-15-2015 02:50 PM |
| **Offical 213/323/626/818 owners thread** | mr. slim | Southern California | 71 | 10-07-2013 12:58 PM |
