Old 09-21-2022, 07:55 PM   #15
IsaiahW
IsaiahW's Avatar
Drives: 2013 Subaru brz limited
Originally Posted by blsfrs View Post
You might call All Aspects. They're in Greatbridge over in Chesapeake and do a lot of Subbie and Miata mtrsports work.
Gave them a call unfortunately they said they are too backed up so they dont wanna accept my car and have it for a while they recommended trust automotive but they quoted $900. I have it but definitely not paying that lol i was just being lazy and didnt wanna spend a weekend dropping the trans by myself anymore but I desperately wanna get this car on the road(been in my garage for 3 months)so i got a friend thatll help me.
IsaiahW is offline   Reply With Quote
The Following User Says Thank You to IsaiahW For This Useful Post:
blsfrs (09-21-2022)
Old 09-22-2022, 12:08 AM   #16
Let us know what you find. That's a lot of custom stuff to strap together at once.
Tcoat (09-26-2022)
Old 09-25-2022, 05:23 PM   #17
IsaiahW
IsaiahW's Avatar
Wont go into gear
Just an update!!
I removed the trans yesterday the input shaft is working properly and not damaged but when i unbolted the pressure plate i noticed that a few bolts were overly tightened which is supposed to be at 18ft lbs. when removing them it sort of relieved the pressure on the pressure plate if you get what im saying. I used a 1/2in torque wrench when i first installed it which was probably not a great idea so this time I purchased a digital 3/8in torque wrench ranged from 5-100ft lbs. i installed a new pilot bearing even though it already had a new one but why not right. I checked the clutch disks and pressure plate for damages, or warpage. All is good but i have a suspicion that the pressure plate bolts were tightened enough to not let the clutch disengage you can sort of tell by the picture because i dont think 18ft lbs is going to strip paint like that but i am a rookie so idk. So this time i will not rush this out of excitement and be very careful. Ill update when i finish battling a war with installing the cd009 back. Forgot to mention the disks were in fact oriented correctly
Old 09-26-2022, 03:31 AM   #18
I get what you're saying about using a torque wrench at the bottom of its range. It's good to have the overlap.
I don't think a slight over-torque did any damage, or would have rendered the clutch inoperative. When you get everything back together, and you're certain there is no air in the system, try adjusting the pedal to get as much throw as possible. Maybe you need a larger diameter master cylinder.
IsaiahW (09-26-2022)
FS Trd close ratio gear set 1-2, mfactory 6th gear AxisPower Transmission and Driveline 11 08-17-2024 07:45 PM
Car wont go into 2nd gear at all. airrick Engine, Exhaust, Transmission 4 04-29-2020 01:37 AM
Gear indicator not registering 5 th gear on 6mt sroby Engine, Exhaust, Transmission 20 03-19-2020 12:43 AM
Loud Hum/Grinding Noise + Vibration in 5-15mph gear range, in gear and rolling neutrl jakebrz Issues | Warranty | Recalls / TSB 14 06-06-2016 07:28 PM
After Market Problem Signals Fuse Popped- Car Wont Go into Gear ScionFR-S Issues | Warranty | Recalls / TSB 14 11-20-2012 03:34 PM
