Woodruff Key Condition
Does my woodruff key look normal to you guys?
My crank pulley came loose while driving a week or so ago and caught it within a minute after it came loose. Luckily the crankshaft pulley spacer stayed in place flush on the engine, but the pulley completely separated from the spacer. Drained oil, no shards or metal. Put the car back together temporarily since my pulley damaged itself coming off along with the surface of the spacer. I did not drive it, just let it idle and revved to 3k and then backed it into my garage after the tow truck dropped it off at my house. Anyways, when the engine ran everything sounded perfect, no sign of spun bearings etc. The reason I make this post is because looking back at the pictures I took it looks a little weird. Maybe this won’t be a problem now but will be in the future? Can anybody help reassure that my engine is fine or would like to fuel my paranoia? Haha. Please let me know. Thank you all |
#2 |
That is clearly sheared.
#3 |
Thoughts on what I should do? I can replace just the key right or no? Also, added another better pic I took just now.
#4 |
Drives: Crapcan
Hate to be Debbie downer here but looks like the crank and timing gear is damaged. I would take it to a shop that is familiar with FA20's, they are going to need to pull the timing cover and access the damage and repair options.
| The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post: |
#5 | |
I called up a shop and they said they would get back to me. I explained the situation and am waiting for a call back. |
#6 | |
Drives: Crapcan
| The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | gm5oh (09-14-2022), x808drifter (09-15-2022) |
#7 |
Yeah, I figured. Rebuild time it is. Car sounded completely normal when I started it, which is why I was hopeful. It is what it is. Thanks for the help, I’ll post updates as time passes!
#8 |
Fingers crossed that the crank is salvageable.
| The Following 3 Users Say Thank You to Ultramaroon For This Useful Post: |
#9 |
Drives: Crapcan
It is pretty much still in time so it should run okay. I would just be worried about it cracking the timing gear or shearing the key the rest of the way. These are interference engines so it would be pretty bad if that happened. Hopefully the crank survived *crosses fingers*
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | gm5oh (09-17-2022) |
#10 |
Famous Potatoes
Drives: '15 ultramarine
So what do you all think is the cause of this problem?
| The Following User Says Thank You to Sapphireho For This Useful Post: | gm5oh (09-17-2022) |
#11 |
Drives: Crapcan
![]() You would think that it would be mostly fine. Possible the timing gear walks a bit without the crankshaft extension tight and puts load on the key way in ways it’s not designed for. I don’t really know. Just throwing a dart at a board.
| The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | gm5oh (09-17-2022), strat61caster (10-03-2022) |
#12 |
No idea. Maybe it had been run with a loose pulley long enough for it to wear like that.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | gm5oh (09-17-2022) |
#13 | |
I wonder how long I would be able to last with the former. |
| The Following User Says Thank You to gm5oh For This Useful Post: | NoHaveMSG (09-16-2022) |
#14 | |
Drives: Crapcan
| LF BRZ FRS 86 any condition for cheap | otacon | Want-To-Buy Requests | 1 | 09-24-2021 01:10 PM |
| WTB Any Condition 86 | bimmer86 | Want-To-Buy Requests | 3 | 02-23-2019 06:55 PM |
| used vehicle condition | zizon93 | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 03-07-2017 05:56 PM |
| FS: Beltronics RX 65 Red New Condition | halo13 | Audio/Visual, Electronics, Infotainment, NAV | 0 | 04-23-2016 06:31 PM |
| WTB: FRS or BRZ shell in any condition | Guildjs | Want-To-Buy Requests | 0 | 10-01-2013 08:33 AM |
