Old 09-09-2022, 09:12 PM   #29
I have seen worse friction welds then that on parts that were supposed to be friction welded
Between the weight reduction and only having part of it make contact early I could really feel the engine rev up more freely.
NoHaveMSG (09-09-2022), soundman98 (09-09-2022)
Old 09-09-2022, 09:17 PM   #30
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
And people waste money on lightweight flywheels All they have to do is destroy a clutch.
NoHaveMSG is online now   Reply With Quote
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
soundman98 (09-09-2022), Tcoat (09-09-2022)
Old 09-09-2022, 09:23 PM   #31
Yep. Just ignore that squeal. It will go away eventually.
Old 09-09-2022, 10:01 PM   #32
soundman98
ProCrastinationConsultant
soundman98's Avatar
given enough time, all noises stop after you ignore them for long enough!
NoHaveMSG (09-10-2022)
Old 09-12-2022, 03:28 AM   #33
Nanofuzer
Nanofuzer's Avatar
Drives: Orange 2015 Scion FRS M/T
i just wanna day thanks for everyone who helped me try to figure this out before dropping transmission. i decided to upgrade to a 6-puck kit, currently just waiting on flywheel to come in and i should be done with transmission problems for a while, i hope. on that note, i was also told to not replace transmission oil and instead reuse the old oil? is this something i should do or should i flush it?
Nanofuzer is offline   Reply With Quote
Old 09-12-2022, 09:51 AM   #34
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Somewhere around is an article on clutch types. 6 puck clutches are for high power high heat usage. With street and light track usage it will probably wear out faster than an organic clutch. It will also chatter for about 2000 miles (ask me how I know). I had an ACT 6 puck clutch from another Subbie project. I put it in my na FRS with a light weight flywheel. (I installed an Aluminum driveshaft too! WOW, did THAT turn out BAD!) In hindsight, I would stick with the stock flywheel and a good quality organic clutch (and a stock driveshaft).
The Following User Says Thank You to blsfrs For This Useful Post:
Tcoat (09-12-2022)
Old 09-12-2022, 10:47 AM   #35
WNDSRFR
Drives: FR-S,GTI
Nothing wrong with the OEM clutch. If you have OEM power why go aftermarket?
Just because something costs more doesn't make it better.
The Following 2 Users Say Thank You to WNDSRFR For This Useful Post:
blsfrs (09-12-2022), soundman98 (09-15-2022)
Old 09-12-2022, 07:59 PM   #36
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
If your fluid is old (more than 30k miles), you should just replace it.
If the fluid is still pretty new and you want to save some money, you can reuse it as long as you can keep it clean while you drain and refill it
EndlessAzure is offline   Reply With Quote
Old 09-14-2022, 02:52 AM   #37
Nanofuzer
Nanofuzer's Avatar
it's not really as oem as i thought it would've been at this point and when i first blew my clutch was back in march with the stock clutch (aftermarket exhaust + a lot of spirited driving). then i replaced it with another oem organic (exhaust, catless headers, E85 tune + more spirited driving), then 2 weeks ago it blew again. so i wasn't sure if the clutch just couldn't handle how i drive maybe or i just don't know how to control my driving.
Old 09-14-2022, 02:53 AM   #38
Nanofuzer
Nanofuzer's Avatar
it's about less than 1k miles on it as i replaced it the first time around back in march.
Old 09-14-2022, 03:56 AM   #39
FrickingReallySlow
Drives: 2015 FR-S
curious are you launching the car a lot? And when you say OEM are you buying from Subaru/Toyota or someplace like rockauto and getting an OEM replacement?feel like something else could be causing this or there's a lot of bad quality parts out there right now with inflation/component shortages etc
FrickingReallySlow is offline   Reply With Quote
The Following User Says Thank You to FrickingReallySlow For This Useful Post:
blsfrs (09-14-2022)
Old 09-14-2022, 06:11 PM   #40
Sasquachulator
Pavement Grey
It cant make noise if it cant MAKE noise.
The Following User Says Thank You to Sasquachulator For This Useful Post:
Old 09-15-2022, 12:57 AM   #41
soundman98
soundman98's Avatar
Old 09-15-2022, 04:34 PM   #42
Nanofuzer
Nanofuzer's Avatar
bought directly from toyota, and i do launch it from time to time to get a kick out of it, but i made sure that i drove it regularly for 200 miles before doing so to break it in
Buddy Club Race Spec Coilover Problems on Problems on Problems mpross Suspension | Chassis | Brakes -- Sponsored by 949 Racing 48 09-05-2016 12:18 AM
VOTE: Your Transmission 6MT? Butter smooth? -or- Problems? hmong337 Engine, Exhaust, Transmission 111 07-27-2016 10:59 PM
Transmission problems M&W_FRS Issues | Warranty | Recalls / TSB 9 11-23-2014 11:29 PM
Transmission problems ofuts Issues | Warranty | Recalls / TSB 24 10-23-2014 12:44 PM
Transmission problems, oil leaks and detonation problems.. turboviper Issues | Warranty | Recalls / TSB 4 06-18-2014 05:01 PM
