, dpfarr
Old 09-08-2022, 08:02 PM   #4663
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
@Colin86 It doesn't compare to the C8 in a straight line but the BRZ is way more fun around a corner. I also don't have to worry about wrecking it as much since parts are so much cheaper lol. @CSG Mike , Maybe you can clue me in as to what an LTR is?
B T is offline   Reply With Quote
Old 09-08-2022, 08:41 PM   #4664
CSG Mike
CSG Mike's Avatar
Low Temperature Radiator; called such as intercooler coolant is low temp relative to the higher temp of the engine coolant radiator.
Old 09-08-2022, 08:47 PM   #4665
B T
So just a secondary unit inline with the main unit? Kind of what I was thinking by tying into the unused heater core. It can provide my winter heat(that I don't need) lol
Old 09-08-2022, 08:51 PM   #4666
CSG Mike
CSG Mike's Avatar
Exactly that!
Ideally, you'll want to direct the airflow with a shroud, and then dump the heat out the wheel well through the fender liner. See M3/Supra/RS3/911/Ferrari/etc., as they all execute it the same way.
Old 09-09-2022, 11:56 AM   #4667
Swolzee
Swolzee's Avatar
Drives: Honda Insight
This discussion has peaked my interest, and it could turn a mistake into a asset for me.
I purchased a 25 row oil cooler that's too tall to fit under the bumper support and still have ground clearance when scrubbing. So I got an appropriate 10 row (like should've done all along) but now I have this cooler just laying around. Would running this in line with the heat exchanger be possible?
It has 10an sized fittings I just wonder if it would be restrictive to the pumps flow rate. If it is restrictive it seems like it would negate any possible benefits or make it worse. Has anyone done this on the E-Force yet?
Swolzee is offline   Reply With Quote
Old 09-09-2022, 02:05 PM   #4668
B T
As long as you keep the lines and cooler outlets the same size to minimize back pressure, the difference should be negligible. I don't have a spot to experiment right now, but if you try it, please report back!
Old 09-09-2022, 02:24 PM   #4669
GPhilly
GPhilly's Avatar
Drives: 2020 Subaru BRZ (Edelbrock SC)
Originally Posted by j123ic View Post
For those of you with idle / drivability issues, check your fuel injectors. They are directional and should only be installed at a fixed clocked position. There's a tab on the fuel rail that aligns with the fuel injector connectors.
If it's not clocked in the correct direction, the fuel spray will be facing the wrong direction and may hit the walls of the runner instead of the center of the valve.
I know this is a super old post but can someone show me a photo of what their injectors looks like?
I am having idle issues and working with Zach to sort them out. I think it has to do with my stock injectors for PI. I really don't know what that means specifically but PI is used during idle before it switches over to DI when driving is what Zach told me.
Thanks.
Codes I have been getting recently are:
P0171 System Too Lean Bank 1
P1170 Port injector fuel performance does not clear DTC
GPhilly is offline   Reply With Quote
Old 09-09-2022, 02:44 PM   #4670
Swolzee
Swolzee's Avatar
So would you want to T the inlet and oultlet's of the exchanger into the cooler, or have the cooler in line pre or post exchanger?
Old 09-09-2022, 04:56 PM   #4671
B T
@GPhilly, so you need a picture of the direct injector or port injector? Port injectors are the ones you use to add more fielding for your setup. DI systems stays stock.
@Swolzee nah, you want to put the heater core inline with the other intercooler. If you teed it off, you would be getting hot engine coolant into your supercharger. So, go from the outlet from the supercharger to the heater core, from the heater core to the filling reservoir. The stock lines that went to the heater core originally would just be routed together.
Old 09-12-2022, 12:57 AM   #4672
Brewster
Brewster's Avatar
Drives: 13 FRS AT, Edelbrock SC, Tomei EL
Thanks.
Step 114 in the Installation manual has pictures that may be helpful for PI positioning
The best thing about the future is that it comes one day (and curve) at a time.
Brewster is offline   Reply With Quote
Old 09-15-2022, 08:31 PM   #4673
Swolzee
Swolzee's Avatar
Errr mu gurd!
Ok, so do these style of pins push out the back of the module?
A gentle tug pulled it completely out.
Old 09-16-2022, 02:59 AM   #4674
dpfarr
Drives: BRZ ts
Bummer, is that too water pump?
dpfarr is offline   Reply With Quote
Old 09-16-2022, 11:51 AM   #4675
B T
Looks like you could probably grab some de-pinning tools and re-crimp the connection. Won't be fun with those short wires though.
Old 09-16-2022, 12:27 PM   #4676
Swolzee
Swolzee's Avatar
Any chance you know what type of pins these are?
It looks like it will have to be pushed through the back. If that's the case I'll have to strip the loom back far enough on all the wire leads to pull the white piece away from the pins.
I'm sure it won't be a tedious pain in the ass at all lol.
I'm assuming this module is a relay so therefore this ground is grounding the relay itself so there wouldn't be a way to ground it downstream somewhere else?
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 05:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 03:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
