Old 09-07-2022, 03:46 PM   #1
SpeBud07
Drives: 2013 FRS
Brake hose dilemma
After 3 months of scrounging up various parts from all over the country, I've finally got all of the parts to do my PP conversion on my '13 FRS. Great!
EXCEPT for brake hoses... not an OEM set to be had in the US. Since this is a street car first, autoX second, I was going to use OEM hoses, because it's been my experience that stainless/teflon turn the pedal into a rock. That's been years ago, so perhaps I'm just old and remembering wrong.
So, do I either a) just go with stainless and deal with the rock pedal, or b) find an aftermarket rubber alternative, or c) find a way to make the 2013 ones fit (which seems like a bad idea).
Thoughts?
SpeBud07 is offline   Reply With Quote
Old 09-07-2022, 05:04 PM   #2
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Spend a little extra money and get overseas???
Why is that not an option?
Where do you think OEM parts come from?
Old 09-07-2022, 05:31 PM   #3
SpeBud07
Drives: 2013 FRS
Evidently, it's a manufacturing thing I'm being told by Subaru. I can try to source them from overseas, worth a shot. I don't want someone to take my money only to have the order sit unfulfilled forever on backorder (learned that lesson already)
The Following User Says Thank You to SpeBud07 For This Useful Post:
x808drifter (09-07-2022)
Old 09-07-2022, 06:29 PM   #4
TommyW
TommyW's Avatar
Drives: '13 Whiteout
get SS, they're fine for the street.
TommyW is offline   Reply With Quote
The Following 2 Users Say Thank You to TommyW For This Useful Post:
SpeBud07 (09-08-2022), whataboutbob (09-10-2022)
Old 09-07-2022, 09:04 PM   #5
euniqe
euniqe's Avatar
Drives: 2012 Toyota 86 GT
I've fitted stainless braided lines to two different cars now including my 86 and noticed no significant change in pedal response. Both HEL brand, mind you. I think you'll be ok.
euniqe is offline   Reply With Quote
The Following User Says Thank You to euniqe For This Useful Post:
Old 09-08-2022, 04:54 AM   #6
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Try Toyota. They might have stock.
The only warning I have regarding SS lines is to watch them closely and make sure they don't wear through. Unlike OEM lines, SS lines typically are not fully restrained. They are free to slip through the retaining point. This can cause them to rub through and fail. This is probably why TRD no longer offers stainless steel lines for their brake kits.
See below image. These are Brembo-supplied Goodridge brake lines
EndlessAzure is offline   Reply With Quote
The Following User Says Thank You to EndlessAzure For This Useful Post:
Ohio Enthusiast (09-08-2022)
Old 09-08-2022, 01:36 PM   #7
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
I used Goodridge SS lines. They are fully restrained.
The Following User Says Thank You to blsfrs For This Useful Post:
villainous_frx (09-20-2022)
Old 09-10-2022, 06:23 PM   #8
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
Yes, try Toyota.
Not sure about elsewhere but here in the GTA (greater Toronto area) identical parts are significantly less at Toyota than at the Subaru parts counter. We’ll worth a try.
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos
Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms
235F/245R Conti ECS on TRD/Enkei wheels (street),
245/40 sq. ECF on 17x8 720Form GTF2 wheels (track)
Muskoka800 is offline   Reply With Quote
Old 09-20-2022, 09:03 PM   #9
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
100% this. I had a failure (in a parking garage thanfully and not while driving) on my second set of SS lines. I replaced the first set because of cracking/wear.
Brake Booster Hose T-Fitting Size? YamahaR86 Forced Induction 0 08-08-2019 02:47 PM
Brake booster hose missing? ldam Engine, Exhaust, Transmission 3 02-28-2019 09:12 AM
Brake Bleeder Hose? swift996 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 11-20-2017 12:44 PM
FS: APR Brake Duct Hose and Backing Kit BRZ / FR-S $275 kanundrum Brakes, Suspension, Chassis 4 04-24-2015 12:24 PM
Brake Ducting/Hose Routing? swift996 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 01-13-2014 04:20 PM
