Old 09-02-2022, 11:35 AM   #1
rm4g3d0n
Drives: BRZ 14
Supporting components
Hi, I'm have very minimal experience around modifying my car, and any advice would be appreciated.
I have a 2014 BRZ, no performance modifications. I bought some KWV3s with Raceseng camber plate for the front.
I don't initially plan on lowering the car, but may do so down the line.
My question is would I need adjustable end links (currently stock)? If so, what length should I be looking for. And can I keep my stock sway bar?
Do I need different rear LCA? Do they need to be adjustable.
I've looked around other posts, but of course everyone's situation is different, so hoping someone has insight into my particular setup.
And any additional info, advice or recommendations I'm not thinking about would be helpful. Thanks!
rm4g3d0n is offline   Reply With Quote
Old 09-02-2022, 01:01 PM   #2
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
If only stickling to that no.
If lowering the car. Maybe and why ask until that point.
Old 09-02-2022, 01:13 PM   #3
rm4g3d0n
Drives: BRZ 14
Thanks. I guess I didn't know if the bolt location for the links were the same KWs as they were on the stock.
Old 09-02-2022, 03:01 PM   #4
Decep
Drives: 2013 FR-S Series 10
Most people end up getting adjustable lower control arms to dial in whatever camber spec they want in the rear. Many people have uneven camber from the factory. As long as you keep your lowering to an inch or so you shouldn't need much of anything besides that. Welcome to the rabbit hole
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
The Following 2 Users Say Thank You to Decep For This Useful Post:
strat61caster (09-02-2022), x808drifter (09-03-2022)
Old 09-02-2022, 06:07 PM   #5
jflogerzi
jflogerzi's Avatar
Stock endlinks in the front are fine. In the rear get some LCA's to you can balance rear camber to the front if you don't plan to lower. Most ppl use LCA's to dial some rear camber out
2013 Series 10 FRS #553
Old 09-02-2022, 10:17 PM   #6
rm4g3d0n
Drives: BRZ 14
Yeah I realize when I want to do something, there's more that I have to consider lol.
When you guys are mentioning lower control arms, are you talking about adjustable ones? I guess I'm not sure if I have an incorrect understanding of LCA if not referring to adjustable ones, how would they adjust for camber?
Thanks.
Old 09-02-2022, 10:27 PM   #7
rm4g3d0n
Drives: BRZ 14
Okay I think I got my answer about the LCAs here:
Old 09-03-2022, 06:21 PM   #8
jflogerzi
jflogerzi's Avatar
Yes but don't need to spend alot of Money. SPC's are cheap and work just good. Just not as flashy.
The Following User Says Thank You to jflogerzi For This Useful Post:
NoHaveMSG (09-03-2022)
Old 09-04-2022, 12:08 AM   #9
Decep
Yep, SPC worked fine for me and no problems in the 50+k miles i had them installed for before selling the car.
RCE SS-1 Coilovers
Corsa Catback
Old 09-04-2022, 10:29 AM   #10
ZDan
ZDan's Avatar
Drives: '23 BRZ
Stock sway at links are fine. Rear LCAs are imo overprescribed, seldom needed. -2.5 rear camber you’d get with1” lowering is not a prob even for street only usage, and I don’t worry about asymmetric rear camber within about 0.3 degrees.
Turbo supporting mods mooseonskates Forced Induction 58 02-24-2020 11:04 AM
WTB Turbo and supporting mods OzzyGT86 Want-To-Buy Requests 2 08-26-2017 07:14 PM
E85, what are the best supporting mods? ProjectMidnight86 Engine, Exhaust, Transmission 9 06-25-2016 03:56 PM
What supporting Mods do you REALLY need? Adrian002 Forced Induction 27 05-09-2015 09:27 PM
Supporting Mods Double4Free Scion FR-S / Toyota 86 GT86 General Forum 5 02-21-2012 06:33 PM
