Old 09-01-2022, 11:00 PM   #1
Nanofuzer
Nanofuzer's Avatar
Drives: Orange 2015 Scion FRS M/T
transmission problems
hello guys, i’m pretty new here to the forum and i come here from time to time when i need to find something specific for my car. so currently i’m having transmission problems, not sure if this has been talked about in the forums before or not since i haven’t seen anything related to my problems so far.
so to begin, here are the problems i’m currently having:
-spongey clutch pedal (master cylinder is full)
-could hear a squealing noise from the transmission (which i think could be the TOB)
-won’t go in gear
-can go in gear if the car is off. but when i turn the car on, it forces the shifter to the neutral position and makes a sort of grinding sound.
-i seem to be leaking oil, but it’s not from the transmission assembly, but also not the engine?
so these are the problems i’m having right now. if anyone can help, please lmk. i don’t wanna have to see my car rot away in the garage. if it’s fixable, i would like to know the solution. or if y’all think it’s best to go to the mechanic then i’ll do that instead.
Nanofuzer is offline   Reply With Quote
Old 09-02-2022, 06:51 AM   #2
TOB
/thread
BAM_Nyblodx16 (09-02-2022), NoHaveMSG (09-02-2022), x808drifter (09-02-2022)
Old 09-03-2022, 10:06 PM   #3
Nanofuzer
Nanofuzer's Avatar
TOB
/thread
any thoughts on how i could maybe prevent this problem from reoccurring in the future? the TOB i have on it right now was installed back in may of this year so it’s pretty new.
Old 09-03-2022, 10:10 PM   #4
Make sure it is the new part number from the TSB. There are likely still a few of the old ones kicking around in stock.
https://www.ft86club.com/forums/showthread.php?t=117440
Old 09-03-2022, 11:43 PM   #5
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Does it have an aftermarket clutch? Who did your installation?
It's not normal for the car to pop out-of-gear when it gets started
EndlessAzure is offline   Reply With Quote
The Following User Says Thank You to EndlessAzure For This Useful Post:
Tcoat (09-06-2022)
Old 09-04-2022, 11:08 PM   #6
Nanofuzer
Nanofuzer's Avatar
yeah it has an aftermarket clutch because the stock TOB was shot back in march and i thought it was the entire clutch assembly so i replaced all of it. i also installed it myself, made sure to grease up all the things that needed grease and torqued to spec.
Old 09-04-2022, 11:22 PM   #7
soundman98
ProCrastinationConsultant
soundman98's Avatar
ACT clutch?
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
Tcoat (09-06-2022), x808drifter (09-05-2022)
Old 09-04-2022, 11:36 PM   #8
EndlessAzure
Wheels for Brains
If you did it yourself, something does not seem aligned properly. The car shouldn't ever pop out of gear
Not being able to get into gear when the engine is running is a sign of clutch drag. Can be caused by a number of things, but in a nutshell the clutch isn't fully releasing
The Following 2 Users Say Thank You to EndlessAzure For This Useful Post:
Old 09-06-2022, 12:05 PM   #9
Nanofuzer
Nanofuzer's Avatar
ACT clutch?
no, it was from clutchmaxpro on amazon. bad part on my end for not researching them first as i was in a rush to get it running. although this time around i did opt in for an ACT kit.
Old 09-06-2022, 12:08 PM   #10
Nanofuzer
Nanofuzer's Avatar
by not aligned, do you mean the input shaft to the clutch or something else? sorry, i’m pretty new to this so i’m still learning.
Old 09-06-2022, 12:54 PM   #11
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Check the master and slave cylinders. Did you remove the hose when you pulled the trans out?
Old 09-06-2022, 02:00 PM   #12
He asked because the ACT has a nasty reputation around here. They are known to be troublesome.
Opie (09-08-2022), soundman98 (09-06-2022), x808drifter (09-07-2022)
Old 09-06-2022, 09:53 PM   #13
soundman98
soundman98's Avatar
yep. prevailing theory seems to be them including a sloppy alignment tool that doesn't really align it properly. a few people swear they haven't had any issues once they reset with the OS Gilken billet alignment tool .
Tcoat (09-07-2022), x808drifter (09-07-2022)
Old 09-07-2022, 01:35 AM   #14
Nanofuzer
Nanofuzer's Avatar
did not remove any hoses when i pulled the trans. i just removed the slave cylinder off and set it to the side.
The Following User Says Thank You to Nanofuzer For This Useful Post:
blsfrs (09-07-2022)
Buddy Club Race Spec Coilover Problems on Problems on Problems mpross Suspension | Chassis | Brakes -- Sponsored by 949 Racing 48 09-04-2016 11:18 PM
VOTE: Your Transmission 6MT? Butter smooth? -or- Problems? hmong337 Engine, Exhaust, Transmission 111 07-27-2016 09:59 PM
Transmission problems M&W_FRS Issues | Warranty | Recalls / TSB 9 11-23-2014 10:29 PM
Transmission problems ofuts Issues | Warranty | Recalls / TSB 24 10-23-2014 11:44 AM
Transmission problems, oil leaks and detonation problems.. turboviper Issues | Warranty | Recalls / TSB 4 06-18-2014 04:01 PM
