timurrrr
Old 08-22-2022, 11:30 AM   #729
KillerBMotorsport
KillerBMotorsport's Avatar
Putting vacuum into the pan's drain will only pull air through the PCV system and definitely NOT the pickup.
If the pump is a blockage, like some of us think it might be, then neither will do anything. The only way the vacuum could be an advantage is if you removed the pan and put it into the pickup to get to the screen. This is not something that could be done with simple shop-vac attachments though.
KillerBMotorsport is offline   Reply With Quote
The Following 3 Users Say Thank You to KillerBMotorsport For This Useful Post:
Petah78 (08-22-2022), Tcoat (08-22-2022), Tokay444 (08-22-2022)
Old 08-22-2022, 11:33 AM   #730
Petah78
Drives: 2022 BRZ sport-tech
Good catch on the PCV. I know on the S2K, the PCV is simply on the valve cover, where is it on the FA? Easily removed and blocked off?
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ
Current: 22 BRZ, 00 S2K - #0220
Petah78 is offline   Reply With Quote
The Following User Says Thank You to Petah78 For This Useful Post:
Tcoat (08-22-2022)
Old 08-22-2022, 11:38 AM   #731
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
If it is like the FA20, it is on the passenger side of the block towards the bell housing. It is a bit hidden by the intake manifold.
Tcoat (08-22-2022)
Old 08-22-2022, 11:40 AM   #732
Ahhh yes. I forgot the PCV system. Waste of time and wouldn't bother.
Old 08-22-2022, 11:41 AM   #733
KillerBMotorsport
The hose that goes to the top of the intake...
This shows with our AOS installed, but pinching that hose, or pulling and capping would do it.
BUT... if the oil pump IS a blockage, putting vacuum on the drain will still do nothing. Even with the PCV closed off.
The Following User Says Thank You to KillerBMotorsport For This Useful Post:
Tcoat (08-22-2022)
Old 08-22-2022, 11:42 AM   #734
KillerBMotorsport
If you pull vacuum on the crankcase, the PCV valve on the block will close. It's the other one that needs to be plugged or pinched closed.
Old 08-22-2022, 11:45 AM   #735
The strongest vacuum is only going to draw as far as the pump and the filter even with the PCV blocked. Never know what It may get out of the area in between though. Be an interesting experiment if nothing else. May do nothing at all but certainly wouldn't hurt anything either.
Old 08-22-2022, 11:50 AM   #736
Rustyoid
Drives: 2022 GR86
wait are we seriously talking about using a shop vac on the drain hole to suck out possible excess sealant on a brand new engine that has warranty when the OEM hasn't made an official statement yet?
or are you joking about that...
Rustyoid is offline   Reply With Quote
The Following 2 Users Say Thank You to Rustyoid For This Useful Post:
Opie (08-22-2022), Tcoat (08-22-2022)
Old 08-22-2022, 12:03 PM   #737
OH he is serious. I am more just curious if anything comes out!
Old 08-22-2022, 12:04 PM   #738
Petah78
It's definitely something i would consider doing on my next oil change, though it will likely not be until next year as the car is going to be stored soon anyways, OR i will end up doing nothing because i am too lazy. For me, this is more like a brain flexing exercise. lol Truth is that I am hoping that OE will announce something by then, if they were to announce anything.
Having said that, I don't see an issue with doing this as i can't see why it will jeopardized the warranty. If it wasn't for keeping my warranty intact, i would have dropped my pan already.
Old 08-22-2022, 12:14 PM   #739
In practical terms is not a terrible idea. Hell, you could even pressurize the block and use something like a Fumoto valve as the relief valve/drain. But that would require a whole lot of equipment and there's other variables to it.
Pressurizing was the first idea. Think it has way more risk to it.
Ideally one would vacuum out the drain hole while there was still some oil in it. Give the liquid a chance to pull any solids out with it.
As Petah said the whole thing is more of a thought exercise or experiment more than a practical way to pull sealant out.
Makes no difference to me since I have no stake in it anyway!
spcmafia (08-22-2022)
Old 08-22-2022, 12:20 PM   #740
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
Had to delete, because it came to me that there is risk on it, as I said, variables. Isn't there a sort of pump that circulates oil, I think its used on automatic transmissions? Might be completely wrong because Im only a 5x100 dirty 1st gen.
spcmafia is online now   Reply With Quote
The Following User Says Thank You to spcmafia For This Useful Post:
Tcoat (08-22-2022)
Old 08-22-2022, 12:41 PM   #741
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
If you blow or suck it out of the strainer into the pan, there's only a slightly smaller chance that it will get stuck in the pan drain hole.
Design an build a swarm of nano bots to scale the pickup tube (possibly a nano pyramid) and mine the silicon in the screen.
Then belay it back down the tube and out the drain without damaging the supporting structure.
Possibly hydraulic spiders. They've already got those. Simples.
The Following 2 Users Say Thank You to bcj For This Useful Post:
Rustyoid (08-22-2022), Tcoat (08-22-2022)
Old 08-22-2022, 01:18 PM   #742
Just run the engine backward
The Following 8 Users Say Thank You to Ultramaroon For This Useful Post:
bcj (08-22-2022), DylanJZA (08-23-2022), flippy (09-13-2022), NoHaveMSG (08-22-2022), Pete (08-25-2022), Spektyr (08-22-2022), Tcoat (08-22-2022), Tokay444 (08-22-2022)
oh no not again
New stock GR86 '22 Dyno Runs: Twins packing more power than advertised!! steel86gt GR86 General Topics (2nd Gen 2022+ Toyota 86) 14 03-09-2022 02:15 AM
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 07:09 PM
Is my engine blown? dallenj Engine, Exhaust, Transmission 39 01-30-2017 05:18 PM
Blown engine due to 0W-20? Benschneider06 Engine, Exhaust, Transmission 45 07-23-2015 03:33 AM
Subaru BRZ complete engine gasket & seal kit 2.0L JPxM0Dz Engine, Exhaust, Transmission 0 12-18-2012 12:11 PM
