Old 07-28-2022, 08:43 PM   #1
bakingpancake
Drives: '16 FR-S
Doing a trans/diff fluid change, are these oil good?
Hello,
I'm dong my trans/diff fluid soon and I'm getting amsoil.
2x https://www.amsoil.com/p/severe-gear...?code=SVGPK-EA
for my diff
2x https://www.amsoil.com/p/manual-tran...?code=MTGPK-EA
for my trans
I just want to make sure these are compatible with the f86 platform and I'm good to go to buy these
bakingpancake is offline   Reply With Quote
Old 08-01-2022, 08:13 AM   #2
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
Originally Posted by bakingpancake View Post
Hello,
for my diff
for my trans
Trans and diff can use the same oil. 75W-90 is more than okay, brand is up to your choice. AMSOIL is pricey, but they make quality products.
spcmafia is offline   Reply With Quote
Old 08-02-2022, 06:58 AM   #3
54fighting
Drives: 2020 toyota 86
Some thing wrong with factory fill?
54fighting is offline   Reply With Quote
The Following User Says Thank You to 54fighting For This Useful Post:
humfrz (08-03-2022)
Old 08-02-2022, 09:11 AM   #4
spcmafia
spcmafia's Avatar
Factory fill tends to keep the trans feeling notchy. Doing your LSD at the same time is just good practice and maintenance even though the manual states a "Check" at 30K miles.
Switching to Motul, Amsoil, or Redline improves the feel and quality of both fluids.
I switched them maybe 2 weeks after getting my BRZ with 13K miles and the difference when switching gears was improved compared with the factory fill.
Old 08-03-2022, 03:48 AM   #5
Nope. The factory fill has worked just fine in my 2013 FRS for the last 9 years.
Old 08-10-2022, 09:03 PM   #6
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
You probably will need 3 quarts for the transmission.
My review here btw:
https://www.ft86club.com/forums/showthread.php?t=127620
Edit: Damnit I necro-ed...
Spuds is online now   Reply With Quote
Old 08-10-2022, 09:09 PM   #7
Spuds
The Dictater
Spuds's Avatar
The bolded statement is a matter of contention. Yes it will function, but I think there are differences between the products listed. I forget what they are though lol.
Old 08-11-2022, 08:06 AM   #8
spcmafia
spcmafia's Avatar
I think for daily use, Motul 75W-90 should be more than okay. For other applications, I would recommend using a more refined product.
Old 08-11-2022, 12:20 PM   #9
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I really didn't care for the motul trans oil and ditched it after a short time. I have been running redline MT-90 since I can get it anywhere, shifts nicer, and is a bit cheaper. I know other guys swear by Synchromesh for the same reasons.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
spcmafia (08-11-2022), villainous_frx (08-15-2022)
Old 08-11-2022, 12:26 PM   #10
spcmafia
spcmafia's Avatar
I'd have to check it out. I haven't really changed it since I got the vehicle with 13K Miles. It was an improvement from the OEM one and haven't had any issues ever since. I got about 5K miles until I change it again and I'll go with either Amsoil or Redline.
My biggest grudge was a feeling of lack of leverage when shifting gears, which the Raceseng weighted knob took care off like a champ.
The Following User Says Thank You to spcmafia For This Useful Post:
Capt Spaulding (08-11-2022)
Old 08-11-2022, 04:40 PM   #11
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
+1 on the Raceseng shift knob. Probably, dollar for dollar, the best single mod I’ve made to mine.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
The Following User Says Thank You to Capt Spaulding For This Useful Post:
spcmafia (08-12-2022)
Looking to change my trans and diff fluid soon, what your guy's go-to and why? 1234eher Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 68 06-23-2023 12:34 AM
Trans and Diff fluid change feedback Freedom AFRICA 0 08-07-2015 12:52 PM
Manual Trans./Diff. Fluid Change.?. westmansweed Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 13 07-15-2015 09:02 AM
Replacing Trans & Diff Fluid, Hot vs Cold BRZNutt Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 12-22-2013 10:04 PM
Trans/Diff Fluid. DanoFA20 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 01-11-2013 04:11 PM
