timurrrr
Old 08-09-2022, 11:41 AM   #575
@Tcoat, pretty much what I was thinking on the "self fix". Thanks for taking the time to dig up the warranty.
As far as off roading, yea not surprise there. You'll notice in the commercial it even looked like it was "off-roading" on a gravel trail.
Of course, just dropping it in by helicopter was probably enough to void the warranty.
soundman98 (08-09-2022), Tcoat (08-09-2022)
Old 08-09-2022, 01:39 PM   #576
ROFL it's Waffle
The guy w/o an FRS or BRZ
ROFL it's Waffle's Avatar
Drives: '23 GR86 Premium 6MT Halo White
Let's say I want my dealer to perform the oil pan sealant check. Let's also assume I have to pay out of pocket for this (chalk it up to preventative maintenance). Mine is on order, so I'd rather tackle this before any real miles are put on the car.
Ballpark, how much time + cost of parts + cost of labor = total $$$ does this effort entail?
ROFL it's Waffle is offline   Reply With Quote
The Following User Says Thank You to ROFL it's Waffle For This Useful Post:
Tcoat (08-09-2022)
Old 08-09-2022, 01:47 PM   #577
Code Monkey
Drives: Subaru BRZ
2.5 hours in labor + around $100 in parts and shop supplies.
Code Monkey is offline   Reply With Quote
The Following 3 Users Say Thank You to Code Monkey For This Useful Post:
DylanJZA (08-09-2022), ROFL it's Waffle (08-09-2022), Tcoat (08-09-2022)
Old 08-09-2022, 04:13 PM   #578
Cloven
Drives: 2023 GR86 6MT
What specifically would you be hoping to accomplish with this “check”? Once the pan is off the dealership will have to reseal. Is your goal to pay for them to remove whatever sealant was applied from factory and redo by hand? In terms of risk aversion this seems like a lateral move at best given it’s completely up to the tech to properly execute the second application.
Cloven is offline   Reply With Quote
The Following 12 Users Say Thank You to Cloven For This Useful Post:
Dadhawk (08-09-2022), DylanJZA (08-09-2022), FRSBRZGT86FAN (08-17-2022), gcmak (08-10-2022), MyHybridBurnsGasAndTires (08-09-2022), NyC Zn6 (08-09-2022), Ohio Enthusiast (08-09-2022), ROFL it's Waffle (08-09-2022), soundman98 (08-09-2022), Tcoat (08-09-2022), timurrrr (08-10-2022), Ultramaroon (08-09-2022)
Old 08-09-2022, 04:15 PM   #579
THIS^
As bad a job as the robot has done the techs have a proven track record of doing it even worse!
Scope it if possible but leave it alone otherwise.
Dadhawk (08-09-2022), DylanJZA (08-09-2022), PBR (08-09-2022), ROFL it's Waffle (08-09-2022)
Old 08-09-2022, 04:32 PM   #580
Surface prep
surface prep
surface prep....
There is no substitute for the factory-prepped virgin mating surfaces before filling with oil. If being re-sealed, great care must be taken, not only to remove all the old stuff. The surfaces above must also be cleaned enough to ensure no oil weeps down to contaminate the joint before it is fully cured.
The devil is very much in the details. Personally, I wouldn't consider doing this job with the engine in place. I would only do it with the engine inverted on a stand, but that's just me.
The Following 6 Users Say Thank You to Ultramaroon For This Useful Post:
JusTheG (08-11-2022), NoHaveMSG (08-09-2022), PBR (08-09-2022), Samba86 (08-10-2022), soundman98 (08-09-2022), Tcoat (08-09-2022)
Old 08-09-2022, 04:37 PM   #581
Cloven
Since there is no real solution at this time, scoping doesn’t really accomplish anything either. I guess increase anxiety if you’re in to that.
I’m not sure why people want a recall to be issued as history has shown human intervention is not a solution to this type of problem. For us, a recall accomplishes nothing beyond admittance of guilt. If you really want to take action your best bet will be a third party gasket which to my knowledge doesn’t exist yet or cracking the pan and resealing by hand yourself. Both will likely void warranty.
Otherwise sit tight, enjoy your car, and cross your fingers that your engine is unaffected or that it blows within warranty.
The Following 2 Users Say Thank You to Cloven For This Useful Post:
Dadhawk (08-09-2022), ROFL it's Waffle (08-09-2022)
Old 08-09-2022, 05:24 PM   #582
ROFL it's Waffle
THIS^
Don't fix what's not broken. That's a valid point, no sense on introducing a potential for problem. Unless I'm scoping it regularly (which I realistically won't be doing), I should just enjoy it while I can and deal with the problems as they arise.
I am not into that LOL
Old 08-09-2022, 06:19 PM   #583
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
Originally Posted by FrickingReallySlow View Post
There's 2 people who spun their bearings and pulled the pan / found RTV does that still count or only people with functioning engines lol
If it is on a Subaru BRZ and not a GR86 it counts...
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
Old 08-09-2022, 07:22 PM   #584
mycrors7
mycrors7's Avatar
Drives: zd8 brz
this doesnt automatically mean RTV was the reason for a spun bearing. it's being pointed to the first thing they see.
id wanna see how the rest of the bearings looked. if this RTV blockage at the oil pickup is the reason for the spun bearing, there should be signs of damage to the other bearings as well. if the other bearings are fine and only one bearing had a failure, then you cant blame the RTV for that, as the RTV in the pickup is affecting the entire system, not one bearing
mycrors7 is offline   Reply With Quote
The Following User Says Thank You to mycrors7 For This Useful Post:
Old 08-09-2022, 08:56 PM   #585
Lantanafrs2
Drives: 2013 frs red
Anyone else see this one?
https://www.google.com/amp/s/www.car...ealership/amp/
Lantanafrs2 is offline   Reply With Quote
Old 08-09-2022, 09:40 PM   #586
soundman98
ProCrastinationConsultant
soundman98's Avatar
Originally Posted by Lantanafrs2 View Post
in related news, i farted.
i'm suing toyota next week and have reported Domino's pizza to the BBB for this.
Opie (08-12-2022)
Old 08-09-2022, 11:39 PM   #587
mycrors7
mycrors7's Avatar
Drives: zd8 brz
owner of that car publicly posted videos of himself drifting/beating the piss out of his gr86 before breakin period. His motor blew literally a few days later. He was annoyed toyota couldnt replace his engine in a timely manner.(i wonder why... brand new car.. brand new motor..). he took all the videos down immediately(after getting clowned on in the brz/gr86 facebook groups)
He gets his car back and it combusts and is engulfed into flames the same day?
yea... no. there's some foul play going on somewhere. cars that had a new motor put in due to warranty get tested vigorously before being given back to a customer.
i dont know why it caught fire, but the only time ive seen a car engulf in flames like that is a fuel leak. a fuel leak would have been noticed when the car was being checked for leaks after the swap. any high pressure fuel line would have popped off immediately if it was loose. fuel lines are usually either fully seated or dripping fuel..
Yea the techs are his dealer were making fun of the car and making tiktok or whatever the hell they did, but this isnt an issue with the tech
then to top it off, apparently he DMed toyotaUSA on instagram, deleted his DM, then when toyotaUSA commented and asked him to get in contact, he proceeded to be a complete **** and say something along the lines of "if you want to get in contact with me, you can DM me"
either way his car is completely unrelated to the rtv issue
The Following 2 Users Say Thank You to mycrors7 For This Useful Post:
Opie (08-12-2022), soundman98 (08-10-2022)
Old 08-10-2022, 02:56 AM   #588
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Originally Posted by Petah78 View Post
From this very small group that have dropped their pans, you are already seeing people posting that they found RTV in their pick up. Keep in mind we are not talking about spun bearings/toast engines, we are just talking about finding RTV inside the pick up. Is this a problem? No one knows. But it does make you think if all these FA24s are on borrowed time.
In the interest of science, some folks who find and document RTV bits in their pickup tubes should leave those there, and see how long their engines survive!
Follow the build thread for my GR86!
The Following 6 Users Say Thank You to timurrrr For This Useful Post:
gcmak (08-10-2022), mycrors7 (08-10-2022), Samba86 (08-10-2022), soundman98 (08-10-2022), Sport-Tech (08-10-2022), Teseo (08-10-2022)
oh no not again
New stock GR86 '22 Dyno Runs: Twins packing more power than advertised!! steel86gt GR86 General Topics (2nd Gen 2022+ Toyota 86) 14 03-09-2022 02:15 AM
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 07:09 PM
Is my engine blown? dallenj Engine, Exhaust, Transmission 39 01-30-2017 05:18 PM
Blown engine due to 0W-20? Benschneider06 Engine, Exhaust, Transmission 45 07-23-2015 03:33 AM
Subaru BRZ complete engine gasket & seal kit 2.0L JPxM0Dz Engine, Exhaust, Transmission 0 12-18-2012 12:11 PM
