| GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
#519 |
Professional Mechanic
Drives: 2017 86 6MT Oceanic
It's probably hard to find a specification for the Toyota/Subaru filters, but looking at the WIX application catalog, they spec a 30 PSI relief pressure for a WL10078.
The FA24 probably has oil pressure relatively close to the FA20, so let's say slightly <10 PSI at idle slightly >70 PSI at 6000 RPM, unless the filter media is clogged, you're not going to push open a 30 PSI bypass with less than 30 PSI of pressure ... |
#520 | |
Drives: 22 BRZ limited
#521 |
So what you're saying is, if you're worried, buy the NAPA Gold filter :lol
#522 | |
btr.life
Drives: 2022 GR86
You are right in that the pan is only one potential issue. I'm guessing RTV scraps are more likely coming from those other places you mentioned. My video states (multiple times) to contact your dealer if you are concerned about this potential issue, and that a DIY could have negative warranty implications. I am aware of that risk and did it myself because I want to bring the info to the community. Plus, those with older cars and no warranty, now know how to clean their oil pickup if they choose to DIY.
#523 |
#524 |
Drives: Crapcan
To be fair to Justin, that spot you are trying to apply the FIPG is less then 1/2 wide and the bead is called out to be 5/16-1/4 diameter. Doing it on your back under the car has to suck.
I also recommend dropping the tube of FIPG into a bucket of warm water for 15min or so to soften it. It’s really hard to squeeze out. Also using a caulking gun that has the bars down the sides of the tube helps, using one like in the video tends to push the tube sideways so you end up working against yourself even more.
| The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post: |
#525 | |
btr.life
Drives: 2022 GR86
| The Following User Says Thank You to justinco For This Useful Post: | NoHaveMSG (08-05-2022) |
#526 | |
Drives: 2022 Subaru BRZ 6MT IR
***Looks at 2 car garage consisting of a ZD8 BRZ and a VA WRX*** ... ***Cries in FA20F and FA24D***
2022 BRZed, Red, Base, Manual, Simple
| The Following 2 Users Say Thank You to 22 BRZ For This Useful Post: | mycrors7 (08-05-2022), soundman98 (08-06-2022) |
#527 |
Now go do it over and make it look pretty this time.
#528 |
Drives: 2023 GR86
There have been repeated issues with the new chain subaru engines leaking (even lawsuits about it in the Outback)- it would be interesting if Subaru responded to that by just designing the oiling system to tolerate partial stripping and blockage and then increased rtv application everywhere to get closer to 100% no-leak and the failures we’re seeing are due to typical factors and not blocked passages/low pressure
| The Following User Says Thank You to pq86 For This Useful Post: | Petah78 (08-05-2022) |
#529 | |
Drives: 2022 BRZ sport-tech
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ Current: 22 BRZ, 00 S2K - #0220 |
#530 | |
Drives: '23 BRZ Limited
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
#531 |
Drives: _
Better yet, just switch to all gaskets! Ban the damn RTV!
Make Gaskets Great Again! |
#532 | |
Master Collaborator
Why not a paper-type gasket coated with pre-cured high-temp RTV a few thousandths of an inch thick? It would be the perfect amount of sealant needed, and would seal the two halves with no chance of squeeze out. These gaskets could be used on every mating surface to replace the existing sealant. That would fix this issue permanently. Oh, and Mr. Lehto followed up his video from the other day. @Tcoat, I hope you weren't aiming that "one post wonder" comment at me. No more free wire harnesses for you!
| Tags |
| oh no not again |
| New stock GR86 '22 Dyno Runs: Twins packing more power than advertised!! | steel86gt | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 14 | 03-09-2022 02:15 AM |
| Driver's side window seal/door seal | KAB-FRS | Issues | Warranty | Recalls / TSB | 255 | 01-01-2021 07:09 PM |
| Is my engine blown? | dallenj | Engine, Exhaust, Transmission | 39 | 01-30-2017 05:18 PM |
| Blown engine due to 0W-20? | Benschneider06 | Engine, Exhaust, Transmission | 45 | 07-23-2015 03:33 AM |
| Subaru BRZ complete engine gasket & seal kit 2.0L | JPxM0Dz | Engine, Exhaust, Transmission | 0 | 12-18-2012 12:11 PM |
