timurrrr
Old 08-05-2022, 03:03 PM   #519
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
It's probably hard to find a specification for the Toyota/Subaru filters, but looking at the WIX application catalog, they spec a 30 PSI relief pressure for a WL10078.
The FA24 probably has oil pressure relatively close to the FA20, so let's say slightly <10 PSI at idle slightly >70 PSI at 6000 RPM, unless the filter media is clogged, you're not going to push open a 30 PSI bypass with less than 30 PSI of pressure ...
Old 08-05-2022, 03:50 PM   #520
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Here you go. Scroll up one post from there for the FA20 filter.
Old 08-05-2022, 04:19 PM   #521
RZNT4R
So what you're saying is, if you're worried, buy the NAPA Gold filter :lol
Old 08-05-2022, 04:54 PM   #522
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Originally Posted by Ronac View Post
He probably added more silicone than was there in the first place…
Also, the silicone that gets stuck in the pickup doesn’t only come from the oil pan. It can come from the front timing cover mating surface as well. It can continue to break off from there and plug up the pickup.
I probably didn't...I re-applied the RTV per the service manual, and presented that page of the manual in the video. Yes, I added a little RTV around the bolt holes, not in them (a practice I've done for 20+ years, but admitedly probably should have left out here). If you actually saw what I took off compared to the new application, there is absolutely not more silicone than what was originally there. I removed ropes of RTV and the bolts were also covered in it.
You are right in that the pan is only one potential issue. I'm guessing RTV scraps are more likely coming from those other places you mentioned.
My video states (multiple times) to contact your dealer if you are concerned about this potential issue, and that a DIY could have negative warranty implications. I am aware of that risk and did it myself because I want to bring the info to the community. Plus, those with older cars and no warranty, now know how to clean their oil pickup if they choose to DIY.
justinco is offline   Reply With Quote
The Following 9 Users Say Thank You to justinco For This Useful Post:
Chrisz5z (08-05-2022), Dake (08-06-2022), Dylans47 (08-06-2022), gcmak (08-08-2022), JusTheG (08-05-2022), NoHaveMSG (08-05-2022), Petah78 (08-05-2022), Re_Invention (08-06-2022), Samba86 (08-05-2022)
Old 08-05-2022, 05:02 PM   #523
dragoontwo
dragoontwo's Avatar
I don't think it's that simple. I believe that the bypass works off of a pressure delta, not straight pressure.
Old 08-05-2022, 05:15 PM   #524
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
To be fair to Justin, that spot you are trying to apply the FIPG is less then 1/2 wide and the bead is called out to be 5/16-1/4 diameter. Doing it on your back under the car has to suck.
I also recommend dropping the tube of FIPG into a bucket of warm water for 15min or so to soften it. It’s really hard to squeeze out. Also using a caulking gun that has the bars down the sides of the tube helps, using one like in the video tends to push the tube sideways so you end up working against yourself even more.
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
JusTheG (08-05-2022), justinco (08-05-2022), soundman98 (08-06-2022)
Old 08-05-2022, 05:19 PM   #525
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Noted, thanks!
The Following User Says Thank You to justinco For This Useful Post:
Old 08-05-2022, 05:36 PM   #526
22 BRZ
22 BRZ's Avatar
Drives: 2022 Subaru BRZ 6MT IR
Originally Posted by mycrors7 View Post
Or just full send cause it being a Subaru boxer it’s likely going to go kaboom one way or another
Let's see if I get this meme right...
***Looks at 2 car garage consisting of a ZD8 BRZ and a VA WRX***
***Cries in FA20F and FA24D***
2022 BRZed, Red, Base, Manual, Simple
22 BRZ is offline   Reply With Quote
The Following 2 Users Say Thank You to 22 BRZ For This Useful Post:
mycrors7 (08-05-2022), soundman98 (08-06-2022)
Old 08-05-2022, 05:58 PM   #527
Originally Posted by justinco View Post
Noted, thanks!
Now go do it over and make it look pretty this time.
justinco (08-06-2022), NoHaveMSG (08-05-2022)
Old 08-05-2022, 08:50 PM   #528
pq86
Drives: 2023 GR86
There have been repeated issues with the new chain subaru engines leaking (even lawsuits about it in the Outback)- it would be interesting if Subaru responded to that by just designing the oiling system to tolerate partial stripping and blockage and then increased rtv application everywhere to get closer to 100% no-leak and the failures we’re seeing are due to typical factors and not blocked passages/low pressure
pq86 is offline   Reply With Quote
The Following User Says Thank You to pq86 For This Useful Post:
Old 08-05-2022, 09:00 PM   #529
Petah78
Drives: 2022 BRZ sport-tech
I actually thought about this as well. You will think they have learned from their previous experience with excess RTV cause starvation.
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ
Current: 22 BRZ, 00 S2K - #0220
Petah78 is offline   Reply With Quote
Old 08-06-2022, 10:14 AM   #530
OkieSnuffBox
Drives: '23 BRZ Limited
Sounds like a terrible idea. Small pieces could still get through the pickup and clog oil passages.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
Old 08-06-2022, 10:26 AM   #531
chipmunk
Drives: _
Better yet, just switch to all gaskets! Ban the damn RTV!
Make Gaskets Great Again!
chipmunk is offline   Reply With Quote
Old 08-06-2022, 10:52 AM   #532
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Here's an idea:
Why not a paper-type gasket coated with pre-cured high-temp RTV a few thousandths of an inch thick?
It would be the perfect amount of sealant needed, and would seal the two halves with no chance of squeeze out. These gaskets could be used on every mating surface to replace the existing sealant.
That would fix this issue permanently.
Oh, and Mr. Lehto followed up his video from the other day.
@Tcoat, I hope you weren't aiming that "one post wonder" comment at me. No more free wire harnesses for you!
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
oh no not again
New stock GR86 '22 Dyno Runs: Twins packing more power than advertised!! steel86gt GR86 General Topics (2nd Gen 2022+ Toyota 86) 14 03-09-2022 01:15 AM
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 06:09 PM
Is my engine blown? dallenj Engine, Exhaust, Transmission 39 01-30-2017 04:18 PM
Blown engine due to 0W-20? Benschneider06 Engine, Exhaust, Transmission 45 07-23-2015 02:33 AM
Subaru BRZ complete engine gasket & seal kit 2.0L JPxM0Dz Engine, Exhaust, Transmission 0 12-18-2012 11:11 AM
