| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: '16 FR-S
Doing a trans/diff fluid change, are these oil good?
Hello,
I'm dong my trans/diff fluid soon and I'm getting amsoil. 2x https://www.amsoil.com/p/severe-gear...?code=SVGPK-EA for my diff 2x https://www.amsoil.com/p/manual-tran...?code=MTGPK-EA for my trans I just want to make sure these are compatible with the f86 platform and I'm good to go to buy these |
#2 | |
Drives: 2018 Subaru BRZ
Trans and diff can use the same oil. 75W-90 is more than okay, brand is up to your choice. AMSOIL is pricey, but they make quality products.
#3 |
Drives: 2020 toyota 86
Some thing wrong with factory fill?
| The Following User Says Thank You to 54fighting For This Useful Post: | humfrz (08-03-2022) |
#4 |
Factory fill tends to keep the trans feeling notchy. Doing your LSD at the same time is just good practice and maintenance even though the manual states a "Check" at 30K miles. Switching to Motul, Amsoil, or Redline improves the feel and quality of both fluids. I switched them maybe 2 weeks after getting my BRZ with 13K miles and the difference when switching gears was improved compared with the factory fill.
#5 |
#6 |
The Dictater
Drives: '13 Red Scion FRS
You probably will need 3 quarts for the transmission.
My review here btw: https://www.ft86club.com/forums/showthread.php?t=127620 Edit: Damnit I necro-ed... |
#7 |
The Dictater
The bolded statement is a matter of contention. Yes it will function, but I think there are differences between the products listed. I forget what they are though lol.
#8 | |
I think for daily use, Motul 75W-90 should be more than okay. For other applications, I would recommend using a more refined product.
#9 |
Drives: Crapcan
I really didn't care for the motul trans oil and ditched it after a short time. I have been running redline MT-90 since I can get it anywhere, shifts nicer, and is a bit cheaper. I know other guys swear by Synchromesh for the same reasons.
| The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | spcmafia (08-11-2022), villainous_frx (08-15-2022) |
#10 | |
I'd have to check it out. I haven't really changed it since I got the vehicle with 13K Miles. It was an improvement from the OEM one and haven't had any issues ever since. I got about 5K miles until I change it again and I'll go with either Amsoil or Redline. My biggest grudge was a feeling of lack of leverage when shifting gears, which the Raceseng weighted knob took care off like a champ.
| The Following User Says Thank You to spcmafia For This Useful Post: | Capt Spaulding (08-11-2022) |
#11 | |
Persona Non Grata
Drives: '15 BRZ (WRB)
+1 on the Raceseng shift knob. Probably, dollar for dollar, the best single mod I’ve made to mine.
Slow is smooth, and smooth is fast
| The Following User Says Thank You to Capt Spaulding For This Useful Post: | spcmafia (08-12-2022) |
| Looking to change my trans and diff fluid soon, what your guy's go-to and why? | 1234eher | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 68 | 06-23-2023 12:34 AM |
| Trans and Diff fluid change feedback | Freedom | AFRICA | 0 | 08-07-2015 12:52 PM |
| Manual Trans./Diff. Fluid Change.?. | westmansweed | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 13 | 07-15-2015 09:02 AM |
| Replacing Trans & Diff Fluid, Hot vs Cold | BRZNutt | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 8 | 12-22-2013 10:04 PM |
| Trans/Diff Fluid. | DanoFA20 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 18 | 01-11-2013 04:11 PM |
