Old 07-18-2022, 02:55 PM   #1
BonelessChickenStrips
Drives: 22 Neptune
Eyesight can’t see anything after mirror install
Hey everyone. I took my car in to get the stock mirror replaced by an auto dimming one. After I did this, eyesight keeps telling me it can’t see anything. Sometimes it will work for like 20 seconds after turning the car on, but then once again it says it can’t see anything. I cleaned the cameras with a micro fiber cloth and they look fine. I’m wondering if there’s an easy fix or if I need to take it in
BonelessChickenStrips is offline   Reply With Quote
Old 07-18-2022, 03:09 PM   #2
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
If the dealer did the work and it's not working, take it in. My guess is they didn't get a connector properly reconnected.
The Following User Says Thank You to dragoontwo For This Useful Post:
Dadhawk (07-18-2022)
Old 07-18-2022, 03:58 PM   #3
Drives: 22 Neptune
Taking it in tomorrow morning
Old 07-18-2022, 03:59 PM   #4
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Don't they have to re-calibrate everything after messing with that and/or the window?
Old 07-18-2022, 04:34 PM   #5
Drives: 22 Neptune
Idk, I thought the rear view mirror was separate from all that but since they had to plug it in maybe
Old 07-22-2022, 05:29 PM   #6
chipmunk
Drives: _
On a side note, is the Eyesight standard on all trim levels? What about Toyota versions?
chipmunk is offline   Reply With Quote
Old 07-22-2022, 07:33 PM   #7
dragoontwo
dragoontwo's Avatar
It is standard on all the automatics. Both nameplates.
The Following 2 Users Say Thank You to dragoontwo For This Useful Post:
chipmunk (07-23-2022), Tcoat (07-22-2022)
Old 07-22-2022, 08:29 PM   #8
Is the new mirror exactly the same size as the old one? Even slightly bigger and the cameras may be catching an edge. Those cameras do not play well with even the slightest deviation from the norm.
Don’t think it would be wired into the system but it is possible.
DIY: APR Door Mirror Install RallySport Direct DIY (Do-It-Yourself) Guides 53 04-26-2019 04:08 PM
Probability of Eyesight Tech in 2018 BRZ towch BRZ First-Gen (2012+) — General Topics 29 08-24-2017 10:45 AM
Homelink Mirror Install/Question JGalp Cosmetic Modification (Interior/Exterior/Lighting) 1 07-30-2015 12:14 PM
DIY JDM frameless mirror install ayau DIY (Do-It-Yourself) Guides 8 01-10-2014 09:36 PM
How to install Homelink mirror? Grimlock Electronics | Audio | NAV | Infotainment 10 06-10-2012 07:07 PM
