Old 07-16-2022, 07:12 AM   #1
autosenses
autosenses's Avatar
Drives: 22 Raven 86, 19 STI, 15MK7 SE daily
22GR/BRZ Oil Temps
Hey,
Just wondering what's the range of oil temps people are seeing? Normal street driving temps are 195-210 depending on load.
When I was at the track I was experiencing temps as high as 235, maybe 240. 87 degrees ambient out. Oil temp would quickly dropped once I reduced load.
This a normal range?
autosenses is offline   Reply With Quote
Old 07-16-2022, 09:11 AM   #2
KillerBMotorsport
KillerBMotorsport's Avatar
Normal. You hit 260, it's time to think about a remote oil cooler.
KillerBMotorsport is offline   Reply With Quote
The Following 2 Users Say Thank You to KillerBMotorsport For This Useful Post:
autosenses (07-17-2022), jcw99 (08-07-2022)
Old 07-16-2022, 10:19 AM   #3
Code Monkey
Drives: Subaru BRZ
The highest I have seen so far at Road Atlanta is the very end of 2 in 270.
Rough calculation:
1 square = (340 - 120) / 74 = 2.97 degrees.
I am 47 squares in so 120 + 47*2.97 = 260 degrees.
Running Motul 300V 5w30 and will be switching to 5w40 in the future.
Code Monkey is offline   Reply With Quote
The Following User Says Thank You to Code Monkey For This Useful Post:
Old 07-16-2022, 02:40 PM   #4
MacSpeed
MacSpeed's Avatar
Drives: 2022 BRZ
235 wouldn’t be any concern. I’m debating a oil cooler for sure though.
At Sebring in 98* ambient, I hit 268 in 3 laps. Firm in 95* ambient I hit 253 in 7 laps.
MacSpeed is offline   Reply With Quote
Old 07-17-2022, 09:55 PM   #5
autosenses
autosenses's Avatar
Thanks for the input.
There's no way to get ambient intake temp readings right?
Old 07-18-2022, 02:49 AM   #6
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Provided your car is moving, the IAT (intake air temperature) reading should be close to ambient.
Or you can look at your ambient temperature readout on the dash (or your weather report)
EndlessAzure is offline   Reply With Quote
The Following User Says Thank You to EndlessAzure For This Useful Post:
jcw99 (08-07-2022)
Old 07-18-2022, 06:45 AM   #7
autosenses
autosenses's Avatar
Rough calculation:
Yes, lol. What I meant was, do our cars show intake temps?
Old 07-18-2022, 06:56 AM   #8
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
If you have an OBD-II reader, yes.
Old 07-18-2022, 03:31 PM   #9
CSG Mike
CSG Mike's Avatar
Hey,
Normal-ish, yes. Oil temp will only go up as you get faster. It's time for an oil cooler.
CSG has Color Fittings, Jackson Racing, and GReddy available.
Old 07-18-2022, 08:15 PM   #10
autosenses
autosenses's Avatar
Yes, most likely getting one in the future.
Old 07-19-2022, 09:35 AM   #11
ZDan
ZDan's Avatar
Drives: '23 BRZ
FWIW I always see temps of 270F-275F at the track with my '17, regardless of ambient temps. No oil cooler and not planning on one for my usage, which is 95% street with ~10-12 track days per year (consisting of 3-4x ~15-minute sessions per day). I run 5w30 synthetic. Currently at 70k miles and 48 track days.
Oil in the car now still looks remarkably "fresh" after ~2500 miles and 6 track days on this fill. Also, this is the first car I've ever dailied or tracked that seems to use NO oil whatsoever between changes. Even with the 6 track days thrown in it's still a bit above the "full" mark as it was when I checked it just after last oil change. Kind of amazing...
The Following 3 Users Say Thank You to ZDan For This Useful Post:
jcw99 (08-07-2022), KillerBMotorsport (07-19-2022), Teseo (07-26-2022)
Old 07-25-2022, 05:49 PM   #12
autosenses
autosenses's Avatar
That's awesome.
How often did you change the first couple oils?
Old 07-25-2022, 07:49 PM   #13
ZDan
ZDan's Avatar
Drives: '23 BRZ
That's awesome.
Changed factory fill out after ~5k miles with 5w30 for track season. Changed after two track events (4 days with ~4x15min stints/day) + ~3500 street miles. Changed oil ~ every 5k miles or every 2 or sometimes 3 track events since then, switching back to 0w20 for winter months.
Teseo (07-26-2022)
Old 07-25-2022, 08:26 PM   #14
Teseo
Drives: frs
I thought with new models having integrated oil cooler (Forester OEM like) Temps should be more lower
Oil temps gen3v8 Engine, Exhaust, Transmission 10 02-11-2021 06:54 PM
LED H11 Headlights in 3 Temps for $42 stevesnj Cosmetic Modification (Interior/Exterior/Lighting) 37 10-19-2015 12:03 PM
N/A typical oil temps JB86'd Engine, Exhaust, Transmission 13 12-16-2014 12:42 AM
Oil temps with JR SC and JR oil cooler dp1 Tracking / Autocross / HPDE / Drifting 87 11-14-2014 12:35 AM
Oil Temps Fish Eagle AFRICA 13 07-22-2014 05:53 PM
