Drives: '23 BRZ
215/45-17 Yok A052, on 17x9 or 17x7.5?
I blistered the outside tread of the outside front at Palmer MA in a few places last weekend. I'd like to replace a couple of tires before heading to Thompson CT next weekend. Unfortunately the only size A052 I could run that's available (at Tire Rack anyway) is 215/45-17. I don't mind running this size at the back of the car, question is which wheels, factory 17x7.5, or 17x9 track wheels.
I normally run 235/45-17 or 245/40-17 on 17x9. 225/45-17 I'd have no qualms running on 9" width. 215/45-17s and I'm on the fence here... A052s do like a little bit of stretch, I'm guessing 215 on 9" might be beneficial for grip and lap times. But it is an inch wider than max recommended... Opinions? |
#2 | |
Drives: '13 Whiteout
#3 |
Drives: '23 BRZ
Yeah, I'm totally comfortable with 225/45-17 on 9", not so much 215...
I may hold out, I do have other options with totally worn-slick set of 235s, could mount the best of those and rotate the outside front throughout the event to forestall/minimize blistering... Hopefully the set of 245/40-17 RE71RS I ordered way back when will actually show up for this event, then I'd be A-OK... |
#4 |
At the track
Drives: '14 FRS - Former e92 M3
Maybe get some Nankangs instead?
#ladydriven Nasa TT4 FRS // JRZ RS Pro // Karcepts Sway Bars // K24 Swap (in Progress) // AP Endurance BBK // Cobalt Friction brake pads // Safeplace Auto
#5 |
Look at some cheaper 660s
Sent from my Pixel 6 using Tapatalk
2013 Series 10 FRS #553
#6 |
Drives: '23 BRZ
New RE71RS are supposed to arrive at Tire Rack's CT warehouse tomorrow, fingers crossed... Nankang CR-1/CR-S or Falken RT660 are good recommendations but I'd like to stick with A052s for known-awesome wet lap times in addition to dry.
#7 |
If you needed something in a pinch. Dry and optimal conditions they are pretty close. BTW be sure to post your thoughts on the new RS's
#8 |
Drives: 2017 BRZ PP, 2004 WRX
215's on a 9" wheel (IMO) is nuts. That's 'stancy boi' stretch. I ran 225/45/17's on the stock 7.5" PP wheels and they're just about square as can be. A052, RT660, and RE-71. For a 9" wheel, it's 245's all the way.
If it boils down to not being able to get A052's, I'd rather be using a 245 RT660 vs a 215 A052.
#9 | ||
Drives: '23 BRZ
But I just got notification that brand new 245/40-17 RE71RS are at the warehouse in CT So I'm totally good for Friday/Saturday at Thompson |
#10 |
Definitely go with the 17x7.5 wheels. I would not want improperly fitting tires on a car seeing any track use.
| You A052, first laps fastest? | ZDan | Tracking / Autocross / HPDE / Drifting | 12 | 09-16-2021 12:22 PM |
| Nankank CR-1 vs. A052? | ZDan | Tracking / Autocross / HPDE / Drifting | 34 | 03-30-2021 05:16 PM |
| Would 245/40R17 A052 fit on 17' BRZ with OEM struts? | Samba | Tracking / Autocross / HPDE / Drifting | 11 | 01-30-2021 02:18 PM |
| Rays Gramslights 57DR 17x9.0 +35mm Gun Metal Vs Work Emotions 17x7 + 35mm Bronze | jflogerzi | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 02-09-2013 07:09 PM |
