Old 06-24-2022, 01:27 PM   #1
Essentials
Drives: Black FRS
Diagnostic help!
The problem:
I noticed I had intermittent heat (climate control) and so I thought I might have low coolant or a bubble in the system. I did have low coolant so I topped it off and that helped at first. Then it happened again so I looked into more. After some of the initial repairs I still had the same problem with the heat but noticed a bigger problem, the coolant had constant bubbles coming up through the coolant bleeder funnel I was using.
Things I’ve done so far:
-changed water pump
-changed thermostat
-flushed radiator, block, and heater core
-head gasket leak tester
None of these things have fixed the issue and with the head gasket leak test coming back negative it has left me stumped. I did do some research on here before posting and I found a post to where the guy had bubbling coolant but also had coolant sitting on top of the block (I do not have that issue) and it ended up being a seal on the intake. Idk if that would fix my issue. I really don’t want to waste more time replacing things that aren’t the issue. Hopefully this issue is very obvious to someone else, any help would be greatly appreciated. If any more information is needed let me know.
Essentials is offline   Reply With Quote
Old 06-24-2022, 02:27 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
You need to keep bleeding until it stops bubbling. How long did you bleed it for?
Ultramaroon (06-24-2022)
Old 06-24-2022, 03:31 PM   #3
Essentials
Drives: Black FRS
I bled it for well over thirty minutes and numerous times. The problem is that with the bubbles the coolant level never drops, only gets higher as the fluid heats up
Old 06-24-2022, 04:54 PM   #4
jrhudson
Drives: 2016 scion frs
You put the heat on without the ac? Perhaps heater core maybe has some air in it?
jrhudson is offline   Reply With Quote
Old 06-24-2022, 05:23 PM   #5
Coolant bleeder funnel? Have you cracked the high-point bleed valve? It's that right-angled fitting near the firewall.
Old 06-24-2022, 06:20 PM   #6
Essentials
Drives: Black FRS
I did. I had the heat on high every time I bled the coolant system. The bubbles are endless so I’m highly confident that some form of gas is getting into the system somehow.
Old 06-24-2022, 06:22 PM   #7
Essentials
Drives: Black FRS
Yeah it’s like a high walled funnel that you can over fill and should, in theory, allow for all the air to come out. And yes I also cracked the bleeder valve up near the fire wall on the heater core line.
The Following User Says Thank You to Essentials For This Useful Post:
Old 06-24-2022, 06:33 PM   #8
Bubbles even with a cold engine? A hot engine will simmer at atmospheric pressure (cap off)
Old 06-24-2022, 09:20 PM   #9
Essentials
Drives: Black FRS
I’m pretty sure yes, even cold. But it’s been a couple weeks since I have done anything with the car. I’ll test it tomorrow and post results.
Old 06-25-2022, 12:20 PM   #10
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Why do people insist on running engines with the rad cap off? The system needs to be pressurized or you will always be creating bubbles.
If you have no way of doing a proper vacuum fill, engine off, fill it up with your funnel and crack the bleeder valve. Once it's full and you've got no bubbles on either end, seal it back up and give it a steady 1000-1500 rpms to warm it up until the thermostat open (keeping an eye on the temp of course). Shut her down and let cool. Reinstall funnel, open bleeder and top off system.
The Following User Says Thank You to RZNT4R For This Useful Post:
Ultramaroon (06-25-2022)
Old 06-25-2022, 12:53 PM   #11
Essentials
Drives: Black FRS
Yeah even when cold and with the cap on it was sending bubbles into the over flow tank. I also noticed a little bit of moisture dripping out at the slip joint for my headers to the over pipe.
Old 06-25-2022, 03:18 PM   #12
Uh oh. Does your exhaust have that characteristic sweet smell? Any sheen on top of the coolant?
Old 06-25-2022, 03:31 PM   #13
Most people don't have a real understanding of those details. Even if someone is experienced with pressure cookers, it can be quite a leap from those to engine cooling systems.
Old 06-25-2022, 03:40 PM   #14
RZNT4R
Oh and since we're going on about that...
Even if the rad cap is installed, it means nothing if it's defective. A bad rad cap is a common issue that shows up as low coolant/no leaks. In my youngers days as a mechanic I had an experienced coworker who was adamant that my old and busted high KM 4Runner had a bad head gasket. It held pressure, had no leaks but was losing coolant long-term. I decided to test the rad cap, it failed, was replaced and the issue was resolved.
