06-13-2022, 08:40 AM | #211 | |
JHerbert Racing
Drives: 2013 Scion FRS
Contact a junkyard or salvage reseller to see if you can get some of those or a whole wing for less than Subaru.
06-14-2022, 08:48 AM | #212 | |
Drives: 17 BRZ
Mine are getting loose. I've resulted to new clamps but I am running out of inner plastic real estate. They get loose when the car is washed or rains. There is a demand if people know about these. I know a bunch of people that would buy including myself! |
06-14-2022, 09:23 AM | #213 |
1st86 Driver!
Do they serve a purpose where you would need to remove them? Seems like a little JBWeld or superglue would fix the problem if not.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
The Following User Says Thank You to Dadhawk For This Useful Post: | Espi (06-14-2022) |
06-14-2022, 03:56 PM | #214 |
Drives: 17 BRZ
Funny you say JBweld I thought about this myself! I've only had to remove mine when I decided to first raise the spoiler and then had to repair the 3M tape on the lip spoiler I have on mine. So I've had to remove it 3 times total - Wing risers, initial install of the lip spoiler, then a year later when I did the repair. Just like that its a little loose
The Following User Says Thank You to Espi For This Useful Post: | Dadhawk (06-15-2022) |
06-15-2022, 07:18 AM | #215 | |
1st86 Driver!
The Following User Says Thank You to Dadhawk For This Useful Post: | Espi (06-15-2022) |
06-17-2022, 01:59 PM | #216 | |
Drives: GR86
There's 2 ways: someone measures that with calipers and builds a model in 3D from those measurements, or someone uses a fairly expensive 3D scanner to automatically generate a 3D model. Once that's done the printing is fairly trivial. You just want to make sure the part is printed using weather-proof material (common PLA is, at least theoretically, biodegradable and will break down in UV light). A standard FDM printer will leave visible layer lines, but depending on the Z-axis resolution used, the quality of the printer, and the final location of the part (I'm not familiar with where it goes) that may be reduced or unimportant. |
06-17-2022, 04:02 PM | #217 |
Senior Citizen Member
Drives: Then-1977 Celica GT Now-2017 860SE
06-21-2022, 10:42 AM | #218 |
Drives: GR86
I would say for something like that the better option would be using a cheap(ish) hobby CNC to make aluminum molds for a cheap(ish) injection molder built out of a manual hobby hydraulic press.
Since it's going to be clearly visible the layer lines you'll get from 3D printing would be a detraction for most people, and sanding/filling those lines to eliminate them would be labor-intensive. Alternately, simply milling them out of aluminum might be preferred. Simpler process overall, and thus potentially competitive in terms of price. Also opens up the possibility of anodized finishes in addition to the typical paint options. And being made out of aluminum with that "bling" factor would support the higher per-pair cost. |
07-09-2022, 04:18 AM | #219 |
Drives: 86
Anyone able to make these for brake duct entry? *edit: This was 3D printed by a guy who only made it for his car and his friend, seems to fit perfectly and with the option of printing it to various duct sizes. He was not interested in making more for others unfortunately. Last edited by Pil; 07-09-2022 at 08:38 AM. Reason: more info |
07-09-2022, 08:00 AM | #220 |
ProCrastinationConsultant
i would take that bezel to the hardware store and start digging around in the plumbing section...
07-09-2022, 11:02 AM | #221 | |
Drives: GR86
Need ID, OD, and height of each section. |
07-09-2022, 11:42 AM | #222 |
Drives: 86
07-09-2022, 03:13 PM | #223 |
Drives: GR86
08-09-2022, 09:33 AM | #224 |
Drives: 2013 Subaru BRZ Premium 6MT
Side Marker Delete STL file
Hey all!
Been searching for the STL file for side marker deletes for a while. Wasn't sure if anyone on here happened to have the file for it. I would really appreciate it! Pic for reference: Thanks! |
Similar Threads | ||||
Official DTM Autobody Services Thread for FT86Club! | DTMAUTOBODY | Southern California | 9 | 12-31-2013 02:09 PM |
Official FT86Club Chatroom? | wrxgoose | Site Announcements / Questions / Issues | 13 | 09-15-2012 05:26 PM |
Official FT86Club decal idea? | Hanzo | Scion FR-S / Toyota 86 GT86 General Forum | 71 | 06-21-2012 08:09 PM |
