Old 06-17-2022, 11:15 AM   #1
haohmaru
Drives: Red 2024 GR86 Trueno
Recommendations on a tool kit for the car?
Hi Guys,
Any recommendations on a small tool kit to keep in the car? Couple screwdrivers, one ratchet, set of sockets. The sets I've seen so far a little more comprehensive than I would need. Something that fits in spare tire well would be great.
Thanks!
haohmaru is offline   Reply With Quote
The Following User Says Thank You to haohmaru For This Useful Post:
humfrz (06-20-2022)
Old 06-17-2022, 11:38 AM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I have one of these as my track day tool kit. Not a huge fan of the ratchets but they get the job done. In the winter time these usually go on sale for like 20 bucks off.
https://www.lowes.com/pd/Kobalt-309-...-in/5001996759
NoHaveMSG is online now   Reply With Quote
Old 06-18-2022, 01:37 PM   #3
e_lunatic
Drives: 2015 Scion FR-S
i would recommend getting a bag with a zipper from your local tool supply store and building your own kit, especially if room is a factor.
in the bag get a couple screwdrivers, a 3/8 ratchet, a socket rail to put some common sockets, some common wrenches, any other tools you may commonly use in a road side repair, maybe a bottle of fix-a-flat, or i have kept a 1/2" drive impact to change the tire easier.
It really depends on what you feel you are going to do roadside vs available space.
e_lunatic is offline   Reply With Quote
Old 06-18-2022, 05:35 PM   #4
soundman98
ProCrastinationConsultant
soundman98's Avatar
i've got a pretty typical tool bag i throw in all my vehicles.
it starts with a simple bag
https://www.harborfreight.com/tool-s...ets-61168.html
then 1/4 and 3/8" sockets
https://www.harborfreight.com/14-in-...-pc-62303.html
https://www.harborfreight.com/38-in-...-pc-61954.html
always a volt meter to troubleshoot electrical issues that arise
https://www.harborfreight.com/electr...ter-63759.html
a multi-bit screwdriver or two
https://www.harborfreight.com/4-in-1...dle-61988.html
wire stripper
https://www.harborfreight.com/7-inch...ter-98410.html
wire cutter
https://www.harborfreight.com/micro-...ter-90708.html
and some e-sockets for the seat bolts.
https://www.harborfreight.com/14-in-...-pc-67898.html
i also throw in a butane soldering iron, some solder, and a handful of zipties from my garage mega-bag as well for good measure.
https://smile.amazon.com/Soldering-M...NsaWNrPXRydWU=
https://www.harborfreight.com/11-inc...100-34637.html
this covers just about anything that is roadside-fixable for me at least. anything that needs more likely isn't much of a roadside fix anymore.
Old 06-18-2022, 06:48 PM   #5
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I put a fanny pack with a zipper around the passenger seat headrest (facing the back of the car) and put in 2 of each of the following short and long 3/8ths 10mm, 12mm,14mm sockets. I keep 16mm - 22mm 1/2" impact sockets as well. A 10mm, 12mm, and 14mm wrench.
Associated ratchets, zip ties, metal zip ties, and a foot of DEI sleeving.
In a little box in the trunk I keep spare plugs, hose clamps, wire strippers, needle nose pliers, an extending magnet, flashlight, vacuum caps, a spare cam position sensor, a spare MAP sensor.
Other notable mentions- a roll of shop towels goes under the passenger seat, jump pack goes under the passenger seat, and a spare quart of oil is tied up in a plastic bag in the trunk as well. A blanket and spare socks.
I've needed all these things and not had them in my life. Never again
soundman98 (06-18-2022)
Old 06-19-2022, 01:38 AM   #6
2020BRZtS
2020BRZtS's Avatar
Drives: '20 BRZ tS (15/300) / '09 Scion tC
Add a TP roll and you got everything I ever needed.
2020BRZtS is offline   Reply With Quote
The Following User Says Thank You to 2020BRZtS For This Useful Post:
soundman98 (06-19-2022)
Old 06-20-2022, 04:13 PM   #7
Originally Posted by haohmaru View Post
Hi Guys,
Thanks!
Here ya go -
The Following 4 Users Say Thank You to humfrz For This Useful Post:
Busybee (06-20-2022), Capt Spaulding (06-23-2022), Grady (06-20-2022), Teseo (06-20-2022)
Old 06-20-2022, 09:45 PM   #8
Teseo
Drives: frs
Lazy, smart but safe
The Following User Says Thank You to Teseo For This Useful Post:
humfrz (06-20-2022)
Old 06-21-2022, 03:32 AM   #9
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
I've got screwdrivers, pliers, jumper cables and a breaker bar/socket.
So far haven't needed them for my car. It's been fairly well made.
What's got the most use is an umbrella.
Old 06-21-2022, 03:13 PM   #10
Teseo
Drives: frs
That's something I would carry if my car was carburetor
Old 06-21-2022, 06:33 PM   #11
radroach
Drives: car
I wouldn't find a reason to carry too many tools. The most I would need is a 10mm wrench for changing a car battery, and a tire iron for changing flats.
Agreed what you really should have is AAA or roadside assistance.
Old 06-22-2022, 08:36 AM   #12
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
I keep one of these in my car at all times. I've used 3 times, mostly for helping other people out. Lots of goodies.
spcmafia is online now   Reply With Quote
Old 06-22-2022, 09:42 AM   #13
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
....tooth brush, tooth paste, bar of soap, bottle of wine, loaf of bread, pack of condoms, and thou.
blsfrs is online now   Reply With Quote
The Following 2 Users Say Thank You to blsfrs For This Useful Post:
DarkPira7e (06-22-2022), NoHaveMSG (06-22-2022)
Old 06-22-2022, 12:00 PM   #14
DarkPira7e
DarkPira7e's Avatar
Who brushes their teeth?
blsfrs (06-22-2022)
Best tool ecosystem? ZionsWrath Off-Topic Lounge [WARNING: NO POLITICS] 20 10-05-2021 06:36 AM
FS: OEM Trunk Tool Kit MicheleAbbate Interior Parts (Incl. Lighting) 7 09-12-2016 02:04 PM
pry tool jazztennor Cosmetic Modification (Interior/Exterior/Lighting) 5 12-15-2012 03:02 AM
What does this tool use to carscat Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 06-27-2012 10:24 PM
